查看: 2811|回复: 0
打印 上一主题 下一主题
BeiDou Navigation Satellite System Signal In Space Interface Control Document
    跳转到指定楼层
    楼主
    发表于 2012-1-4 09:36:18 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
    BeiDou Navigation Satellite System Signal In Space Interface Control Document (Test Version)
    China Satellite Navigation Office
    December 2011
    1 Scope
    The BeiDou Navigation Satellite System (hereinafter referred to
    as BeiDou system) has followed the development roadmap of
    starting with regional services first and expanding to global services
    later. A three-step development strategy has been taken. Phase I is
    BeiDou Navigation Satellite Demonstration System, which was been
    established in 2000. Phase II is BeiDou Navigation Satellite
    (regional) System to provide service for areas in China and its
    surrounding areas from 2012. Phase III is BeiDou Navigation
    Satellite System to be established completely and provide global
    service by 2020.
    This interface document defines the specification related to B1
    carrier signal between the space segment and the user segment of the
    BeiDou Navigation Satellite (regional) System.
    2 System Overview
    2.1 Space Constellation
    The nominal constellation of BeiDou Navigation Satellite
    (regional) System is composed of fourteen satellites, including five
    Geostationary Earth Orbit (GEO) satellites and nine
    Non-Geostationary Earth Orbit (Non-GEO) satellites. The Non-GEO
    satellites include four Medium Earth Orbit (MEO) satellites and five
    Inclined Geosynchronous Satellite Orbit (IGSO) satellites. The GEO
    satellites are positioned at 58.75°E, 80°E, 110.5°E, 140°E and 160°E
    respectively.
    2.2 Coordinate System
    The BeiDou system adopts the China Geodetic Coordinate
    System 2000 (CGCS2000), the definition of which is listed below:
    The origin is located at the mass center of the Earth;
    The Z-axis is in the direction of the IERS (International Earth
    Rotation Service) Reference Pole (IRP);
    The X-axis is directed to the intersection of IERS Reference
    Meridian (IRM) and the plane passing through the origin and normal
    to the Z-axis;
    The Y-axis, together with Z-axis and X-axis, constitutes a right
    handed orthogonal coordinate system.
    The origin of the CGCS2000 is also the geometric center of the
    CGCS2000 ellipsoid, and the Z-axis is the rotation axis of the
    CGCS2000 ellipsoid. The parameters of the CGCS2000 ellipsoid are
    as follows:
    Semi-major axis: a = 6378137.0 m
    Geocentric gravitational constant (mass of the earth atmosphere
    included): GM = 398600.4418´109 m3/s2
    Flattening: f = 1/298.257222101
    Rate of earth rotation: w = 7.2921150´10-5 rad/s
    2.3 Time System
    The BeiDou Time (BDT) System is a continuous timekeeping
    system, with its length of second being a SI second. BDT zero
    time-point started at 00:00 UTC on January 1st, 2006. BDT is
    synchronized with UTC in 100 nanoseconds (modulo one second).
    3 B1 Signal Specifications
    3.1 Signal Structure and Basic Characteristics
    3.1.1 Signal Structure
    The B1 signal is the sum of channel I and Q which are in phase
    quadrature of each other. The ranging code and navigation message
    is modulated on B1 carrier signal. The signal is composed of the
    carrier frequency, ranging code and navigation message.
    The B1 signal is expressed as follows:
    j j ( ) j ( )cos (2 j ) j ( ) j ( )sin (2 j )
    C C C P P P S = A C t D t p ft +j + A P t D t p ft +j
    Where,
    j: Satellite number
    A : Amplitude of ranging code in channel I of carrier B1
    P A : Amplitude of ranging code in channel Q of carrier B1
    C : Ranging code in channel I
    P : Ranging code in channel Q
    C D : Data modulated on ranging code of channel I
    P D : Data modulated on ranging code of channel Q
    f : B1 carrier frequency
    C j : Initial phase of channel I of carrier B1
    P j : Initial phase of channel Q of carrier B1
    3.1.2 Basic Signal Characteristics
    The basic characteristics and parameters of B1 signals are
    shown in Table 3-1.
    北斗卫星导航系统空间信号接口控制文件-EN.pdf
    72.42 KB, 下载次数: 4
    举报
    站长推荐上一条 2/5 下一条
    「工聚四方·创见未来」欧时RS入驻四方维创新中心线下沙龙
    查看 »
    GMT+8, 2025-4-30 04:15 , Processed in 0.114647 second(s), 18 queries , MemCache On.
