查看: 2056|回复: 1
二合一组合天线
发表于 2009-4-10 14:17:19 | 显示全部楼层 |阅读模式
[table=560]            [tr]            [td=1,1,127]
            [/td]            [td=1,1,171]
GPS
            [/td]            [td=1,1,162]
            [/td]            [td=2,1,204]
GSM
            [/td]        [/tr]        [tr]            [td=1,1,127]
中心频率
Center Frequency
            [/td]            [td=1,1,171]
1575.42MHz
            [/td]            [td=1,1,162]
中心频率
Center Frequency
            [/td]            [td=1,1,105]
824~896MHz
            [/td]            [td=1,1,100]
1850~1990MHz
电压驻波比
V.S.W.R
            [/td]            [td=1,1,171]
≤1.8
            [/td]            [td=1,1,162]
电压驻波比
V.S.W.R
            [/td]            [td=1,1,105]
≤1.8
            [/td]            [td=1,1,100]
≤1.8
Band Width
            [/td]            [td=1,1,171]
±5 MHz
            [/td]            [td=1,1,162]
Impendence
            [/td]            [td=1,1,105]
50ohm
            [/td]            [td=1,1,100]
50ohm
Axial Ratio
            [/td]            [td=1,1,171]
3dB
            [/td]            [td=1,1,162]
3dB水平波束
3dB honrizontal wave
(0°)
            [/td]            [td=1,1,105]
360
            [/td]            [td=1,1,100]
360
带外衰减
Attenuation
            [/td]            [td=1,1,171]
fo±100MHz>30dB
            [/td]            [td=1,1,162]
3dB/6 dB垂直波束
3dB/6dB vertical wave
(0°)
            [/td]            [td=1,1,105]
60
            [/td]            [td=1,1,100]
60
<font size="3">
GMT+8, 2024-11-23 02:20 , Processed in 0.130242 second(s), 15 queries , MemCache On.
