[table=98%] [tr] [td] [table=98%] [tr] [td]卫星导航相关术语速查表[/td] [/tr] [tr] [td] [table=98%] [tr] [td=2,1,589] A
[/td] [/tr] [tr] [td=1,1,306] absolute positioning
[/td] [td=1,1,284] 绝对定位
[/td] [/tr] [tr] [td=1,1,306] Aeronautical Radio Navigation Service (ARNS)
[/td] [td=1,1,284] 航空无线电导航服务
[/td] [/tr] [tr] [td=1,1,306] Allan variance
[/td] [td=1,1,284] 阿伦(Allan)方差
[/td] [/tr] [tr] [td=1,1,306] almanac
[/td] [td=1,1,284] 历书
[/td] [/tr] [tr] [td=1,1,306] ambiguity function
[/td] [td=1,1,284] 模糊度函数
[/td] [/tr] [tr] [td=1,1,306] Ambiguity Function Method (AFM)
[/td] [td=1,1,284] 模糊度函数方法(AFM)
[/td] [/tr] [tr] [td=1,1,306] amplitude spectrum
[/td] [td=1,1,284] 振幅谱
[/td] [/tr] [tr] [td=1,1,306] analog-to-digital converter
[/td] [td=1,1,284] 模数变换
[/td] [/tr] [tr] [td=1,1,306] antenna gain
[/td] [td=1,1,284] 天线增益
[/td] [/tr] [tr] [td=1,1,306] antenna phase center
[/td] [td=1,1,284] 天线相位中心
[/td] [/tr] [tr] [td=1,1,306] antenna swap
[/td] [td=1,1,284] 天线互换
[/td] [/tr] [tr] [td=1,1,306] anti-aliasing filter
[/td] [td=1,1,284] 反锯齿滤波器
[/td] [/tr] [tr] [td=1,1,306] anti-spoofing (AS)
[/td] [td=1,1,284] 反欺骗
[/td] [/tr] [tr] [td=1,1,306] argument of latitude
[/td] [td=1,1,284] 升交角距
[/td] [/tr] [tr] [td=1,1,306] argument of perigee
[/td] [td=1,1,284] 近地点角距
[/td] [/tr] [tr] [td=1,1,306] astronomical time
[/td] [td=1,1,284] 天文时
[/td] [/tr] [tr] [td=1,1,306] atomic clock
[/td] [td=1,1,284] 原子钟
[/td] [/tr] [tr] [td=1,1,306] atomic time
[/td] [td=1,1,284] 原子时
[/td] [/tr] [tr] [td=1,1,306] attitude determination
[/td] [td=1,1,284] 定姿(态)
[/td] [/tr] [tr] [td=1,1,306] auto-correlation
[/td] [td=1,1,284] 自动相关
[/td] [/tr] [tr] [td=1,1,306] auto-correlation sidelobes
[/td] [td=1,1,284] 自相关旁瓣
[/td] [/tr] [tr] [td=1,1,306] autonav function
[/td] [td=1,1,284] 自导航函数
[/td] [/tr] [tr] [td=1,1,306] averaging time
[/td] [td=1,1,284] 平均时间
[/td] [/tr] [tr] [td=2,1,589] B
[/td] [/tr] [tr] [td=1,1,306] bandpass filter
[/td] [td=1,1,284] 带通滤波器
[/td] [/tr] [tr] [td=1,1,306] bandpass sampling
[/td] [td=1,1,284] 带通采样
[/td] [/tr] [tr] [td=1,1,306] bandpass signals
[/td] [td=1,1,284] 带通信号
[/td] [/tr] [tr] [td=1,1,306] bandwidth
[/td] [td=1,1,284] 带宽
[/td] [/tr] [tr] [td=1,1,306] bandwidth, null-to-null
[/td] [td=1,1,284] 带宽,零点至零点
[/td] [/tr] [tr] [td=1,1,306] bandwidth expansion
[/td] [td=1,1,284] 带宽扩展
[/td] [/tr] [tr] [td=1,1,306] baseband
[/td] [td=1,1,284] 基带
[/td] [/tr] [tr] [td=1,1,306] baseband sampling
[/td] [td=1,1,284] 基带采样
[/td] [/tr] [tr] [td=1,1,306] baseline
[/td] [td=1,1,284] 基线
[/td] [/tr] [tr] [td=1,1,306] basis functions
[/td] [td=1,1,284] 基本函数
[/td] [/tr] [tr] [td=1,1,306] BeiDou
[/td] [td=1,1,284] 北斗
[/td] [/tr] [tr] [td=1,1,306] binary offset carrier (BOC)
[/td] [td=1,1,284] 双相偏置载频(BOC)
[/td] [/tr] [tr] [td=1,1,306] binary phase shift keying (BPSK)
[/td] [td=1,1,284] 双相移键控(BPSK)
[/td] [/tr] [tr] [td=1,1,306] bit shift register
[/td] [td=1,1,284] 比特移位寄存器
[/td] [/tr] [tr] [td=1,1,306] Block I, II, IIA, IIR, IIR-M, IIF satellites
[/td] [td=1,1,284] BlockI,II,IIA,IIR,IIR-M,IIF(型)卫星
[/td] [/tr] [tr] [td=1,1,306] BOC(m,n) codes
[/td] [td=1,1,284] BOC(m,n)码
[/td] [/tr] [tr] [td=1,1,306] boxcar filter
[/td] [td=1,1,284] boxcar滤波器
[/td] [/tr] [tr] [td=1,1,306] Bureau International des Poids et Mesures (BIPM)
[/td] [td=1,1,284] 国际时间局
[/td] [/tr] [tr] [td=1,1,306] Butterworth filter
[/td] [td=1,1,284] 巴特沃思(Butterworth)滤波器
[/td] [/tr] [tr] [td=2,1,589] C
[/td] [/tr] [tr] [td=1,1,306] Coarse/Acquisition (C/A)-code
[/td] [td=1,1,284] 粗捕获(C/A)码
[/td] [/tr] [tr] [td=1,1,306] C/N0
[/td] [td=1,1,284] 载噪比(C/N0)
[/td] [/tr] [tr] [td=1,1,306] carrier phase measurements
[/td] [td=1,1,284] 载波相位测量
[/td] [/tr] [tr] [td=1,1,306] carrier tracking loop (CTL)
[/td] [td=1,1,284] 载波跟踪环
[/td] [/tr] [tr] [td=1,1,306] carrier wipeoff
[/td] [td=1,1,284] 载波消除
[/td] [/tr] [tr] [td=1,1,306] cesium atomic clock
[/td] [td=1,1,284] 铯原子钟
[/td] [/tr] [tr] [td=1,1,306] characteristic equation
[/td] [td=1,1,284] 特征方程(式)
[/td] [/tr] [tr] [td=1,1,306] chip
[/td] [td=1,1,284] 码片
[/td] [/tr] [tr] [td=1,1,306] chipping rate
[/td] [td=1,1,284] 码率
[/td] [/tr] [tr] [td=1,1,306] chip-scale atomic clocks (CSAC)
[/td] [td=1,1,284] 片式原子钟(CSAC)
[/td] [/tr] [tr] [td=1,1,306] circular error probable (CEP)
[/td] [td=1,1,284] 园误差概率
[/td] [/tr] [tr] [td=1,1,306] clock noise
[/td] [td=1,1,284] 钟噪声
[/td] [/tr] [tr] [td=1,1,306] closed loop transfer function
[/td] [td=1,1,284] 闭环转移函数
[/td] [/tr] [tr] [td=1,1,306] code-carrier divergence
[/td] [td=1,1,284] 码-载波发散
[/td] [/tr] [tr] [td=1,1,306] code clock
[/td] [td=1,1,284] 码钟
[/td] [/tr] [tr] [td=1,1,306] code division multiple access (CDMA)
[/td] [td=1,1,284] 码分多址(CDMA)
[/td] [/tr] [tr] [td=1,1,306] code generator
[/td] [td=1,1,284] 码发生器
[/td] [/tr] [tr] [td=1,1,306] code phase measurements
[/td] [td=1,1,284] 码相位测量
[/td] [/tr] [tr] [td=1,1,306] code transform
[/td] [td=1,1,284] 码转换
[/td] [/tr] [tr] [td=1,1,306] code wipeoff
[/td] [td=1,1,284] 码消除
[/td] [/tr] [tr] [td=1,1,306] coherent signal tracking
[/td] [td=1,1,284] 相干信号跟踪
[/td] [/tr] [tr] [td=1,1,306] cold start
[/td] [td=1,1,284] 冷启动
[/td] [/tr] [tr] [td=1,1,306] comb function
[/td] [td=1,1,284] 梳状函数
[/td] [/tr] [tr] [td=1,1,306] common view time transfer
[/td] [td=1,1,284] 共视时间传递
[/td] [/tr] [tr] [td=1,1,306] complex exponential
[/td] [td=1,1,284] 复指数
[/td] [/tr] [tr] [td=1,1,306] constructive interference
[/td] [td=1,1,284] 结构干涉
[/td] [/tr] [tr] [td=1,1,306] controlled radiation pattern antenna (CRPA)
[/td] [td=1,1,284] 辐射(方向)图可控天线
[/td] [/tr] [tr] [td=1,1,306] Control Segment
[/td] [td=1,1,284] 控制段
[/td] [/tr] [tr] [td=1,1,306] Control Segment errors
[/td] [td=1,1,284] 控制段误差
[/td] [/tr] [tr] [td=1,1,306] Conventional Inertial Reference System (CIRS)
[/td] [td=1,1,284] 传统惯性参考系统
[/td] [/tr] [tr] [td=1,1,306] Conventional Terrestrial Reference System (CTRS)
[/td] [td=1,1,284] 传统陆地参考系统
[/td] [/tr] [tr] [td=1,1,306] convolution
[/td] [td=1,1,284] 卷积
[/td] [/tr] [tr] [td=1,1,306] Coordinated Universal Time (UTC)
[/td] [td=1,1,284] 协调世界时
[/td] [/tr] [tr] [td=1,1,306] correlator spacing
[/td] [td=1,1,284] 相关器间距
[/td] [/tr] [tr] [td=1,1,306] Costas discriminator
[/td] [td=1,1,284] 科斯塔斯鉴别器
[/td] [/tr] [tr] [td=1,1,306] cross-correlation
[/td] [td=1,1,284] 交叉相关
[/td] [/tr] [tr] [td=1,1,306] cycle slip
[/td] [td=1,1,284] 周跳
[/td] [/tr] [tr] [td=2,1,589] D
[/td] [/tr] [tr] [td=1,1,306] datum
[/td] [td=1,1,284] 基准
[/td] [/tr] [tr] [td=1,1,306] dead reckoning
[/td] [td=1,1,284] 航位推算(法)
[/td] [/tr] [tr] [td=1,1,306] Defense Mapping Agency (DMA)
[/td] [td=1,1,284] 国防地图局(DMA)
[/td] [/tr] [tr] [td=1,1,306] delay lock loop (DLL)
[/td] [td=1,1,284] 延迟锁定环
[/td] [/tr] [tr] [td=1,1,306] delta pseudorange
[/td] [td=1,1,284] 伪距增量
[/td] [/tr] [tr] |
