The world leader at the high end of precision frequency control, Rakon offers a range of frequency control solutions for the base station and telecom infrastructure markets. Rakon is committed to providing technology leading solutions at competitive prices.
- Self calibrating OCXOs
- Double oven replacements
- Standard OCXOs
- Temperature compensated OCXOs
- Ultra-stable TCXOs
Versatile standard ocxos
Rakon's cost effective single oven OCXOs offer frequency, stability and form factor
options to suit a wide range of telecommunications applications. The compact
CFPO-5 and miniature CFPO-6 (20.7 x 20.7 x 10.5 mm) are inexpensive OCXOs,
tailored for applications such as cellular base stations, where space is at a premium.
Ultra-stable tcxos
Ultra-stable TCXOs based on Rakon's proprietary Pluto technology address high
volume applications where very high stability is required. Pluto incorporates tilt
compensation to eliminate the detrimental effects of adjusting a TCXO's control
voltage to allow for long term drift. The Pluto-based 7.0 x 5.0 mm CFPT-9000 series
and 5.0 x 3.0 mm CFPT-9300 series TCXOs offer stability better than ¡À100 ppb over
commercial temperature ranges.
Self calibrating ocxos
Rakon¡¯s range of self calibrating OCXOs can replace expensive rubidium clocks in
Stratum 2 and other high precision applications. They compensate internally for
crystal ageing effects, achieving free running lifetime stability better than ¡À16 ppb
(¡À1.6 x 10-8) without the need for any recalibration of equipment.
Rakon's CFPO-DO series ¡®super single oven'OCXOs deliver performance as good
or better than double oven OCXOs, but from a smaller, lower cost device. The
CFPO-DO offers stability of ¡À0.1 ppb (¡À1.0 x 10-10) over its operating temperature
range, while its superior stability under all operating conditions yields 24 hour
holdover better than 7¦Ìs. It is suitable as a frequency source and time keeping
reference for all synchronization systems. A self calibrating version is available.
temperature compensated ocxos
Rakon's ¡®Triton¡¯ series of low cost OCXOs bridge the gap between ultra-stable
TCXOs and traditional high end OCXOs in terms of cost, stability, size, weight, and
power consumption. Combining oven technology with Rakon¡¯s proprietary Pluto
temperature compensation, Triton delivers stability better than ¡À50 ppb in a DIL-14
leaded package (RFPO-20) and now in a new 14.6 x 9.7 mm refowable surface
mount package (RFPO-30).
Jesse-wu@hotmail.com MT:13032180675 |
