查看: 2937|回复: 2
AX88796B网络接口电路图
发表于 2010-5-17 16:39:54 | 显示全部楼层 |阅读模式
The AX88796B is a low-pin-count (64-pin LQFP) non-PCI Ethernet controller for the Embedded and Industrial Ethernet applications. The AX88796B supports 8/16-bit SRAM-like host interface, providing a glue-less connection to most common embedded MCUs. The AX88796B integrates on-chip Fast Ethernet MAC and PHY, which is IEEE802.3 10Base-T and IEEE802.3u 100Base-TX compatible and 8Kx16 bits embedded SRAM for packet buffering to accommodate high bandwidth applications. The AX88796B has a wide array of features including support for Twisted Pair Crossover Detection and Auto-Correction, Wake-on-LAN power management and IEEE 802.3x and backpressure flow control. The AX88796B supports two operating temperature ranges, namely, commercial grade from 0 to 70 ?XC and industrial grade from -40 to 85 ?XC. The small form factor of 64-pin LQFP package helps reduce the overall PCB space. The programming of AX88796B is simple and compatible with NE2000, so the users don't need any modification and can easily port the software drivers to many embedded systems very quickly. Combining these features with ASIX's free TCP/IP software stack for 8-bit microcontrollers, AX88796B provides the best Ethernet solution for embedded networking applications
AX88796B_SMDK2440_PCB2_SCHEMATI-2010.pdf
180.01 KB, 下载次数: 12
AX88796B_STI5100_REFERENCE_SCHE-2010.pdf
148.59 KB, 下载次数: 2
AX88796B_TI_DM355_REFERENCE_SCH-2010.pdf
177.81 KB, 下载次数: 4
发表于 2010-7-12 15:06:11 | 显示全部楼层
RE:AX88796B网络接口电路图
谢谢分享,收藏了
发表于 2010-8-7 09:55:43 | 显示全部楼层
回复:AX88796B网络接口电路图
回复第 1 楼 focus2009于2010-05-17 08:39:54发表:
好东西,谢谢
GMT+8, 2024-11-24 12:29 , Processed in 0.134771 second(s), 20 queries , MemCache On.
