查看: 2667|回复: 0
AX88796网络接口电路图-2
发表于 2010-5-17 16:35:42 | 显示全部楼层 |阅读模式
The AX88796 Fast Ethernet Controller is a high performance and highly integrated local CPU bus Ethernet Controller with embedded 10/100Mbps PHY/Transceiver and 8K*16 bit SRAM. The AX88796 supports both 8 bit and 16 bit local CPU interfaces include MCS-51 series, 80186 series, MC68K series CPU and ISA bus. The AX88796 implements both 10Mbps and 100Mbps Ethernet function based on IEEE802.3 / IEEE802.3u LAN standard. The AX88796 also provides an extra IEEE802.3u compliant media-independent interface (MII) to support other media applications. Using MII interface, Home LAN PHY type media can be supported
AX88796_STI5100_REFERENCE_SCHEM-2010.pdf
162.89 KB, 下载次数: 1
AX88796B_8051_SCHEMATIC_V13-2010.pdf
191.74 KB, 下载次数: 1
AX88796B_ALI_M3602_REFERENCE_SC-2010.pdf
179.27 KB, 下载次数: 1
GMT+8, 2024-11-28 08:37 , Processed in 0.125153 second(s), 16 queries , MemCache On.
