查看: 2581|回复: 0
AX88782网络接口电路图
发表于 2010-5-17 16:31:23 | 显示全部楼层 |阅读模式
The AX88782 is a single-chip 2-port 10/100M Ethernet Switch controllers featuring a 3-port switching fabric with QoS priority management, three 10/100M MACs, two 10/100M PHYs, and 8/16-bit Non-PCI host interface. The AX88782 supports checksum offload engine and burst-mode access making it easy to provide a high performance 2-port Ethernet connectivity solution for any embedded MCU. The built-in switching fabric in the AX88782 supports non-blocking wire-speed forwarding and offers an advanced switch feature set that includes tag/port-based VLAN, spanning tree, rate control, port security, port mirroring, IGMP snooping, MIB counters and four priority queues for QoS functions including Port-Based, 802.1p VLAN, IPv4 TOS and IPv6 COS to prioritize voice, video, audio and data traffic delivery.
The AX88782 have integrated a voltage regulator and provide support for programmable I/O voltage options of 3.3V/2.5V/1.8V to enable a highly optimized system design. As semiconductor designs migrate to advanced process geometries like 90nm, 65nm, 45nm and beyond, many of today's higher performance ASICs, SoCs and FPGAs require lower I/O voltages.
The AX88782 combine the benefits of high integration and small form factor making them ideal single-chip solutions for designing high performance, QoS-aware and cost effective 2-port Ethernet functions for embedded system applications such as VoIP phone/ATA adapters, surveillance IP cameras, next-generation IP-STB/IPTV, industrial controller/network sensors, port redundancy/port monitoring and Single Board Computers (SBC)
AX88782_SMDK2440_DEMOBOARD_PCB2-4-5.pdf
221.72 KB, 下载次数: 0
AX88783_SMDK2440_DEMOBOARD_PCB2-2010.pdf
237.11 KB, 下载次数: 0
GMT+8, 2024-11-28 08:46 , Processed in 0.116462 second(s), 16 queries , MemCache On.
