TA的每日心情 | 开心 2014-4-3 10:09 |
签到天数: 149 天 连续签到: 1 天 [LV.7]常住居民III
发表于 2013-9-9 17:20:40
显示全部楼层
#include <stdio.h> #include <windows.h> SERVICE_STATUS m_ServiceStatus; SERVICE_STATUS_HANDLE m_ServiceStatusHandle; BOOL bRunning=true; void WINAPI ServiceMain(DWORD argc, LPTSTR *argv); //服务主函数 void WINAPI ServiceCtrlHandler(DWORD Opcode); //服务控制函数 void WINAPI CmdStart(void); //要启动的程序函数 BOOL InstallService(); //安装服务的函数 BOOL DeleteService(); //删除服务的函数 int main(int argc, char* argv[]) { printf("\twindows based service demo\n"); printf("\tgxisone@hotmail.com\n"); if(argc!=3) { printf("usage: %s -install[remove]",argv[0]); return 0; } if(strcmp(argv[1],"-install")==0) //安装 { if(InstallService()) printf("\n\nService Installed Sucessfully\n"); else printf("\n\nError Installing Service\n"); } else if(strcmp(argv[1],"-remove")==0) // 删除 { if(DeleteService()) printf("\n\nService remove sucessfully\n"); else printf("\n\nError removing Service\n"); } else { printf("\nusage: %s -install[remove]\n",argv[0]); return 0; } //在进入点函数里面要完成ServiceMain的初始化, //准确点说是初始化一个SERVICE_TABLE_ENTRY结构数组, //这个结构记录了这个服务程序里面所包含的所有服务的名称 //和服务的进入点函数 SERVICE_TABLE_ENTRY DispatchTable[]={{"WindowsMgr",ServiceMain},{NULL,NULL}}; //最后的NULL指明数组的结束 StartServiceCtrlDispatcher(DispatchTable); return 0; } void WINAPI ServiceMain(DWORD argc, LPTSTR *argv) { m_ServiceStatus.dwServiceType = SERVICE_WIN32; m_ServiceStatus.dwCurrentState = SERVICE_START_PENDING; m_ServiceStatus.dwControlsAccepted = SERVICE_ACCEPT_STOP; m_ServiceStatus.dwWin32ExitCode = 0; m_ServiceStatus.dwServiceSpecificExitCode = 0; m_ServiceStatus.dwCheckPoint = 0; m_ServiceStatus.dwWaitHint = 0; m_ServiceStatusHandle = RegisterServiceCtrlHandler("WindowsMgr",ServiceCtrlHandler); if (m_ServiceStatusHandle == (SERVICE_STATUS_HANDLE)0)return; m_ServiceStatus.dwCurrentState = SERVICE_RUNNING; //设置服务状态 m_ServiceStatus.dwCheckPoint = 0; m_ServiceStatus.dwWaitHint = 0; //SERVICE_STATUS结构含有七个成员,它们反映服务的现行状态。 //所有这些成员必须在这个结构被传递到SetServiceStatus之前正确的设置 SetServiceStatus (m_ServiceStatusHandle, &m_ServiceStatus); bRunning=true; //* CmdStart(); //启动我们的服务程序 //* return; } void WINAPI ServiceCtrlHandler(DWORD Opcode) //服务控制函数 { switch(Opcode) { case SERVICE_CONTROL_PAUSE: m_ServiceStatus.dwCurrentState = SERVICE_PAUSED; break; case SERVICE_CONTROL_CONTINUE: m_ServiceStatus.dwCurrentState = SERVICE_RUNNING; break; case SERVICE_CONTROL_STOP: m_ServiceStatus.dwWin32ExitCode = 0; m_ServiceStatus.dwCurrentState = SERVICE_STOPPED; m_ServiceStatus.dwCheckPoint = 0; m_ServiceStatus.dwWaitHint = 0; SetServiceStatus (m_ServiceStatusHandle,&m_ServiceStatus); bRunning=false; break; case SERVICE_CONTROL_INTERROGATE: break; } return; } BOOL InstallService() //安装服务函数 { char strDir[1024]; SC_HANDLE schSCManager,schService; GetCurrentDirectory(1024,strDir); GetModuleFileName(NULL,strDir,sizeof(strDir)); char chSysPath[1024]; GetSystemDirectory(chSysPath,sizeof(chSysPath)); strcat(chSysPath,"\\WindowsMgr.exe"); if(!CopyFile(strDir,chSysPath,FALSE))printf("Copy file OK\n"); // 把我们的服务程序复制到系统根目录 strcpy(strDir,chSysPath); schSCManager = OpenSCManager(NULL,NULL,SC_MANAGER_ALL_ACCESS); if (schSCManager == NULL) { printf("open scmanger failed,maybe you do not have the privilage to do this\n"); return false; } LPCTSTR lpszBinaryPathName=strDir; schService = CreateService(schSCManager,"WindowsMgr","Windows Manger Control", //将服务的信息添加到SCM的数据库 SERVICE_ALL_ACCESS, SERVICE_WIN32_OWN_PROCESS, // 服务类型 SERVICE_AUTO_START, // 启动类型 SERVICE_ERROR_NORMAL, lpszBinaryPathName, // 服务名 NULL, NULL, NULL, NULL, NULL); if (schService == NULL) { printf("faint,we failed just because we invoke createservices failed\n"); return false; } CloseServiceHandle(schService); return true; } BOOL DeleteService() { SC_HANDLE schSCManager; SC_HANDLE hService; schSCManager = OpenSCManager(NULL,NULL,SC_MANAGER_ALL_ACCESS); char chSysPath[1024]; GetSystemDirectory(chSysPath,sizeof(chSysPath)); strcat(chSysPath,"\\WindowsMgr.exe"); if (schSCManager == NULL) { printf("faint,open scmanger failed\n"); return false; } hService=OpenService(schSCManager,"WindowsMgr",SERVICE_ALL_ACCESS); if (hService == NULL) { printf("faint,open services failt\n"); return false; } if(DeleteFile(chSysPath)==0) { printf("Dell file Failure !\n"); return false; } else printf("Delete file OK!\n"); if(DeleteService(hService)==0) return false; if(CloseServiceHandle(hService)==0) return false; else return true; } void WINAPI CmdStart(void) { //把你的要做成服务启动的程序代码添加到这里 //那么你的代码就可以作为NT服务启动了 }
转发至微博
