1. Peripherals IP cores
PCI express Solutions:
- Endpoint controller/Rootmode/Switch Bridge Controller
- PCIe1.0 PHY hard IP
SATA Solutions:
- SATA host controller
- SATA device controller
- SATA PHY hard IP
USB2.0 Solutions:
- USB2.0 OTG controller
- USB2.0 host controller
- USB2.0 device controller
- USB2.0 PHY hard IP
- USB2.0 OTG PHY hard IP
- USB2.0 mobile PHY hard IP (small dieszie)
USB1.0 Solutions:
- USB1.0 host controller
- USB1.0 device controller
- USB1.0 HUB controller
- USB1.0 FullSpeed/Low Speed PHY
Wireless USB2.0 Solutions:
- Wireless USB host controller
- wireless USB device controller
- wireless USB Host+device controller
SDRAM memory controller Solutions
-Support Mobile DDR-SDRAM (LPDDR)
-Support Mobile SDR-SDRAM
-Support DDR-SDRAM
-Support SDR-SDRAM
-Support Async-SRAM/Flash
DDRn Memory controller Solutions
-DDR2/DDR SDRAM controller IP
-DDR3/DDR2 SDRAM controller IP
-DDR2/DDR SDRAM PHY hard IP
-DDR3/DDR2 SDRAM PHY hard IP
Nand Flash Controller IP
AMBA2.0/AMBA3.0 Peripherals IP cores (DMA/I2S/GPIO/SSI etc.)
SDIO Device 2.0 Controller IP
Mobile Storage host controller (Support SDIO/CEVA/MMC etc.)
SD_MMC host controller IP
Sony MemoryStick host controller IP
Ethernet IP controller Solutions
-10M/100M Ethernet MAC controller IP
-10M/100M/1000M Ethernet MAC controller IP
-10G Ethernet MAC controller IP
Analog IO IP solutions:
-DDR2 IO hard IP
-DDR IO hard IP
-Mobile DDR IO hard IP
-LVDS IO hard IP
2. Multimedia IP cores
GPU IP solutions
-ATI 2D GPU IP
-ATI 3D GPU IP
-Img PowerVR MBX 3D GPU IP
-Img PowerVR MBX-Lite 3D GPU IP
Video IP Solutions
-MPEG2 Decoder IP
-MPEG4 Encoder IP
-Video Decoder IP (Support H264/MEPG4 etc.)
-Video Codec IP (Support H264/MPEG4 etc. Decoder/Encoder)
Image Processing IP Solutions:
-JPEG Encoder IP
-JPEG Decoder IP
-JPEG Codec IP
-Motion JPEG Codec IP
3. CPU/MCU/DSP IP cores
24bit CoolFlux DSP soft core
8bit 8051 MCU IP
PowerPC 460/440/405 soft CPU IP
PowerPC PLB4 Peripherals
ARC6xx/ARC7xx CPU IP
MIPS4K CPU IP
ARM9xx/ARM11xx CPU IP
PrimeCell IP (Uart/GPIO/SSI/DC-DC converter/Audio Codec Interface etc.)
