查看: 3970|回复: 2
打印 上一主题 下一主题
UMTS-HSDPA中的TCP性能
跳转到指定楼层
楼主
发表于 2009-3-19 10:33:01 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
TCP Performance over UMTS-HSDPA Systems
The Authors
Dr. Mohamad Assaad received a B.S. in electrical engineering with
highest honors from Lebanese University in Beirut, in 2001. In 2002 and
2006, he received a M.Sc. degree with highest honors and a Ph.D., both
in telecommunications, from the Ecole Nationale Sup´erieure des T´el´ecommunications
(ENST) in Paris, France. While pursuing his Ph.D., he
was a research assistant in the wireless networks & multimedia services
department at the Institut National des T´el´ecommunications (INT) in Evry,
France, working on cross-layer design in UMTS/HSDPA system and interaction
of TCP with MAC/RLC and physical layers. He has published several
international journal and conference papers in this area and worked
in collaboration with some academic and industrial partners. Since April
2006, he is assistant professor in the telecommunications department at
the Ecole Sup´erieure d’Electricit´e (Sup´elec) in Gif-sur-Yvette, France. His
research interests include 3G systems and beyond, TCP protocol in wireless
networks, cross-layer design, resource allocation in wireless systems,
multiuser detection, and MIMO techniques.
Dr. Djamal Zeghlache graduated from Southern Methodist University in
Dallas, Texas, in 1987 with a Ph.D. in electrical engineering and the same
year joined Cleveland State University as assistant professor in the area of
digital communications in the Department of Electrical Engineering. During
the summer of 1990 and 1991 he was a summer faculty fellow at the NASA
Lewis Research Center where he conducted research and development on
a portable terminal for satellite communications in the Ka Band. In 1992 he
joined the Institut National des T´el´ecommunications in Evry, France, where
he currently heads the Wireless Networks & Multimedia Services Department.
He is actively involved in European funded projects, is a member
of IEEE Technical Committee on Personal Communications of the IEEE
Communications Society, and a member of the Wireless World Research
Forum. He has coauthored papers on multiple access, wireless resource management, wireless network planning, and networking for personal networks.
He also regularly partakes in the technical management of most IEEE
conferences as member of technical program committees and as reviewer
in conferences such as ICC, Globecom, PIMRC, ASWN, WPMC, and WCNC,
to name a few. He was cotechnical chair of the wireless communications
symposium of Globecom 2003 and cofounder of the ASWN workshop that
he cochaired in 2001, 2002, and 2005. Dr. Zeghlache’s research interests
and activities span a broad spectrum of issues related to wireless networks
and services including radio access (cross-layer design, resource management,
and planning) and core networks with emphasis on end-to-end issues
such as cooperation between networks and dynamic adaptation of context
aware wireless networks and services.
Contents
The Authors . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . xiii
Preface . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . xv
1 Wireless Radio Channel . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 1
1.1 Large-Scale Fading Models . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 4
1.1.1 Path Loss Models for UMTS . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 4
1.1.1.1 Path Loss Model for Indoor
Office Environment . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 5
1.1.1.2 Path Loss Model for Urban and
Suburban Environment . . . . . . . . . . . . . . . . . . . . . . . . . . 5
1.1.1.3 Path Loss Model for Outdoor to Indoor and
Pedestrian Environment . . . . . . . . . . . . . . . . . . . . . . . . . 6
1.2 Small-Scale Fading Characterization and Channel Model . . . . . . . . 7
1.2.1 Statistics of the Received Signal Envelope . . . . . . . . . . . . . . . . 8
1.2.2 Characterization of the Radio Channel Response . . . . . . . . 10
References . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .12
2 CDMA in Cellular Systems . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 13
2.1 CDMA Principle. . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .13
2.2 Benefits of CDMA. . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .15
2.3 CDMA Codes . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 17
2.3.1 Orthogonal Codes . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 17
2.3.2 Scrambling Code . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 19
2.3.2.1 Scrambling Codes of UMTS Uplink Channels. . . .20
2.3.2.2 Scrambling Codes of UMTS
Downlink Channels . . . . . . . . . . . . . . . . . . . . . . . . . . . . 21
2.4 CDMA Receiver . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 22
References . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .24
vii
viii  Contents
3 Universal Mobile for Telecommunications System . . . . . . . . . . 25
3.1 UMTS Services . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 28
3.1.1 Conversational Class Applications . . . . . . . . . . . . . . . . . . . . . . 28
3.1.2 Streaming Class Applications . . . . . . . . . . . . . . . . . . . . . . . . . . . 29
3.1.3 Interactive Class Applications . . . . . . . . . . . . . . . . . . . . . . . . . . 30
3.1.4 Background Class Applications . . . . . . . . . . . . . . . . . . . . . . . . . 31
3.1.5 Quality of Service (QoS) Parameters . . . . . . . . . . . . . . . . . . . . 31
3.2 General Architecture . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 32
3.2.1 User Equipment Domain . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 33
3.2.2 UTRAN Domain . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 33
3.2.3 Core Network Domain . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 34
3.2.4 Interfaces. . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .35
3.2.4.1 Iu Interface . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 35
3.2.4.2 Iur Interface . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 36
3.2.4.3 Iub Interface. . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .37
3.3 UTRAN Protocol Architecture . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .37
3.4 UMTS Channels . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 38
3.4.1 Logical Channels. . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .38
3.4.1.1 Logical Control Channels. . . . . . . . . . . . . . . . . . . . . . .38
3.4.2 Transport Channels . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 39
3.4.3 Physical Channels . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 42
3.4.3.1 Dedicated Physical Channel . . . . . . . . . . . . . . . . . . . . 44
3.5 Physical Layer . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 46
3.6 Medium Access Control . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 47
3.6.1 MAC Architecture . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 48
3.6.2 Protocol Data Unit . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 49
3.7 Radio Link Control . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 53
3.7.1 Transparent Mode (TM) . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 54
3.7.2 Unacknowledged Mode (UM) . . . . . . . . . . . . . . . . . . . . . . . . . . 55
3.7.3 Acknowledged Mode (AM). . . . . . . . . . . . . . . . . . . . . . . . . . . . .56
3.7.4 SDU Discard at the RLC Sender . . . . . . . . . . . . . . . . . . . . . . . . 57
3.7.4.1 Timer-Based Discard with Explicit Signaling . . . . 58
3.7.4.2 Timer-Based Discard without
Explicit Signaling . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 58
3.7.4.3 SDU Discard after MaxDAT Transmissions . . . . . . 59
3.7.4.4 No Discard after MaxDAT Transmissions . . . . . . . . 59
3.8 Packet Data Convergence Protocol (PDCP) . . . . . . . . . . . . . . . . . . . 59
3.9 Broadcast/Multicast Control (BMC) and Multimedia
Broadcast/Multicast Service (MBMS) . . . . . . . . . . . . . . . . . . . . . . . . . . 60
3.10 Radio Resource Control (RRC) . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 61
3.11 Automatic Repeat Request Protocol . . . . . . . . . . . . . . . . . . . . . . . . . . 62
3.11.1 SW Protocol . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 63
3.11.2 Sliding Window Protocol. . . . . . . . . . . . . . . . . . . . . . . . . . . . . .64
Contents  ix
3.12 Power Control . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 65
3.12.1 Open-Loop Power Control . . . . . . . . . . . . . . . . . . . . . . . . . . . . 65
3.12.2 Closed-Loop Power Control . . . . . . . . . . . . . . . . . . . . . . . . . . . 66
3.13 Handover. . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .67
3.14 Modeling and Cell Capacity . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 69
3.14.1 Uplink Capacity . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 70
3.14.2 Downlink Capacity . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 71
References . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .72
4 High-Speed Downlink Packet Access . . . . . . . . . . . . . . . . . . . . . . . 77
4.1 HSDPA Concept . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 78
4.2 HSDPA Structure . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 80
4.3 Channels Structure . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 82
4.3.1 HS-DSCH Channel . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 82
4.3.2 HS-SCCH Channel . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 83
4.3.3 HS-DPCCH Channel . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 84
4.3.4 Timing of HSDPA Channels . . . . . . . . . . . . . . . . . . . . . . . . . . . . 86
4.4 MAC-hs. . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .87
4.4.1 MAC Architecture at the UTRAN Side . . . . . . . . . . . . . . . . . . . 88
4.4.2 MAC Architecture at the User Equipment Side . . . . . . . . . . 91
4.5 Fast Link Adaptation . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 91
4.6 Adaptive Modulation and Coding . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 94
4.7 HARQ . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 95
4.7.1 HARQ Types . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 96
4.7.2 HARQ Protocol . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 97
4.7.3 HARQ Management . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 101
4.8 Packet Scheduling . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 101
4.8.1 Scheduling Constraints and Parameters . . . . . . . . . . . . . . . . 103
4.8.2 Selected Scheduling Algorithms . . . . . . . . . . . . . . . . . . . . . . . 104
4.8.2.1 Round Robin . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 104
4.8.2.2 Fair Throughput . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 104
4.8.2.3 Max C/I . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 104
4.8.2.4 Proportional Fair . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 105
4.9 HSDPA Modeling and Cell Throughput . . . . . . . . . . . . . . . . . . . . . . 106
4.9.1 HARQ. . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .106
4.9.2 AMC . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 106
4.9.3 Scheduling . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 107
4.9.3.1 Round Robin Scheduler . . . . . . . . . . . . . . . . . . . . . . . 107
4.9.3.2 Fair Throughput Scheduler . . . . . . . . . . . . . . . . . . . . 107
4.9.3.3 Max C/I Scheduler . . . . . . . . . . . . . . . . . . . . . . . . . . . . 108
4.9.3.4 Proportional Fair Scheduler . . . . . . . . . . . . . . . . . . . 109
4.9.4 Results . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 110
References. . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .111
x  Contents
5 Applications and Transport Control Protocol . . . . . . . . . . . . . . 115
5.1 UDP Services . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 116
5.2 TCP Services. . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .116
5.2.1 World Wide Web . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 118
5.3 TCP . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 120
5.3.1 Connection Establishment and Termination . . . . . . . . . . . . 120
5.3.2 TCP Segmentation . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 122
5.3.3 Flow Control and Sliding Window Mechanisms . . . . . . . . 124
5.3.4 Acknowledgment and Error Detection . . . . . . . . . . . . . . . . . 125
5.3.5 Congestion Control and Retransmission Mechanism . . . . 127
5.3.5.1 Slow Start . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 127
5.3.5.2 Congestion Avoidance . . . . . . . . . . . . . . . . . . . . . . . . 128
5.3.5.3 Retransmission Timeout. . . . . . . . . . . . . . . . . . . . . . .128
5.3.5.4 Triple Duplicate . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 129
5.4 TCP Modeling . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 130
5.4.1 Independent Packet Loss Models . . . . . . . . . . . . . . . . . . . . . . 130
5.4.2 Random Loss Model . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 133
5.4.3 Network Model. . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 134
5.4.4 Control System Model . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 134
References. . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .135
6 TCP over Wireless Systems: Problems
and Enhancements . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 139
6.1 Wireless Environment Factors . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 140
6.1.1 Limited Bandwidth and Long RTT . . . . . . . . . . . . . . . . . . . . . 140
6.1.2 High Loss Rate . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 141
6.1.3 Mobility . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 142
6.1.4 Asymmetric Links Bandwidth . . . . . . . . . . . . . . . . . . . . . . . . . 142
6.2 TCP Performance Enhancements . . . . . . . . . . . . . . . . . . . . . . . . . . . . 143
6.2.1 Link-Layer Solutions . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 143
6.2.1.1 Snoop Protocol . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 144
6.2.1.2 Transport Unaware Link Improvement
Protocol (TULIP) . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 145
6.2.1.3 Delayed Duplicate Acknowledgments . . . . . . . . . 146
6.2.1.4 Scheduling over Reliable Shared Channel . . . . . . 147
6.2.1.5 Other Link-Layer Solutions . . . . . . . . . . . . . . . . . . . . 149
6.2.2 Split Solutions . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 150
6.2.2.1 Indirect-TCP . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 150
6.2.2.2 Mobile-TCP. . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .151
6.2.2.3 Mobile End Transport Protocol (METP) . . . . . . . . 152
6.2.3 End-to-End Solutions . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 153
Contents  xi
6.2.3.1 TCP SACK. . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 153
6.2.3.2 Forward Acknowledgment . . . . . . . . . . . . . . . . . . . . 154
6.2.3.3 SMART Retransmissions . . . . . . . . . . . . . . . . . . . . . . . 154
6.2.3.4 Eiffel . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 154
6.2.3.5 Explicit Congestion Notification . . . . . . . . . . . . . . . 155
6.2.3.6 Explicit Bad State Notification (EBSN) . . . . . . . . . 156
6.2.3.7 Explicit Loss Notification . . . . . . . . . . . . . . . . . . . . . . 157
6.2.3.8 TCP over Wireless Using ICMP
Control Messages . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 158
6.2.3.9 Noncongestion Packet Loss
Detection (NCPLD) . . . . . . . . . . . . . . . . . . . . . . . . . . . 158
6.2.3.10 Explicit Transport Error Notification . . . . . . . . . . 159
6.2.3.11 Multiple Acknowledgments . . . . . . . . . . . . . . . . . . 159
6.2.3.12 Negative Acknowledgments . . . . . . . . . . . . . . . . . . 160
6.2.3.13 Freeze TCP . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 160
6.2.3.14 TCP Probing. . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .161
6.2.3.15 Wireless TCP . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 162
6.2.3.16 TCP Peach . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 163
6.2.3.17 TCP Vegas. . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .164
6.2.3.18 TCP Santa Cruz . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 165
6.2.3.19 TCP Westwood . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 165
6.2.3.20 TCP Veno . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 166
6.2.3.21 TCP Jersey . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 166
6.2.3.22 TCP Pacing . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 167
6.2.3.23 TCP Real . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 167
6.2.3.24 Ad Hoc TCP. . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 168
References. . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .169
7 TCP Performance over UMTS-HSDPA System . . . . . . . . . . . . . . . 177
7.1 TCP Performance . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 178
7.2 General Architecture of TCP Connection
over UMTS-HSDPA . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 179
7.3 Comparison among RLC, MAC-hs, and TCP . . . . . . . . . . . . . . . . . . 183
7.3.1 Reliability . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 183
7.3.2 Flow Control and Sliding Window. . . . . . . . . . . . . . . . . . . . .184
7.3.3 Segmentation . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 184
7.4 Modeling of TCP over UMTS-HSDPA . . . . . . . . . . . . . . . . . . . . . . . . 185
7.4.1 Timeout . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 185
7.4.1.1 Proposition . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 185
7.4.1.2 Proof . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 186
7.4.2 Slow Start . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 186
7.4.3 Recovery Time of the First Loss . . . . . . . . . . . . . . . . . . . . . . . 188
xii  Contents
7.4.4 Steady-State Phase . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 189
7.4.5 Effect of TCP on Wireless Network . . . . . . . . . . . . . . . . . . . . 190
7.5 Other Analyses of TCP over UMTS-HSDPA. . . . . . . . . . . . . . . . . . .193
References. . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .195
Index . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 199
UMTS-HSDPA中的TCP性能.rar
1.79 MB, 下载次数: 9
举报
发表于 2011-3-19 18:44:49 | 只看该作者
RE:UMTS-HSDPA中的TCP性能
很给力的书,3Q!!
举报
站长推荐上一条 1/4 下一条
有奖活动|英飞凌智能座舱直播活动
查看 »
GMT+8, 2025-4-5 05:22 , Processed in 0.124859 second(s), 22 queries , MemCache On.
