查看: 1952|回复: 0
菜鸟问题,高手来帮帮忙吧
发表于 2008-12-1 23:15:26 | 显示全部楼层 |阅读模式
External code file (doppler_shift) compilation failed
Source code was unavailable to the compiler
Object repository construction failed
External code file (doppler_shift) compilation failed, no source code found.
Error encountered rebuilding repository -- unable to proceed
遇到了上面这个问题,现在我想找doppler_shift这个变量,看看是不是没有对它赋值,应该去哪里找?
GMT+8, 2024-11-25 19:42 , Processed in 0.107512 second(s), 15 queries , MemCache On.
