查看: 3417|回复: 5
GSM符号与缩略语
发表于 2008-11-6 15:25:59 | 显示全部楼层 |阅读模式
AB:  Access Burst  接入突发脉冲序列AC:  Authentication Center  鉴权中心ARFCN:  Absolute Radio Frequency Channel Number  绝对射频频道号AOC:  Advice of Charge  计费通知ARL:  Audio Reference Level  声参考电平BAIC:  Barring of all Incoming Calls  闭锁所有入呼叫BAOC:  Barring of all Outgoing Calls  闭锁所有出呼叫BCCH:  Broadcast Control Channel  广播控制信道BER:  Bit Error Rate  比特误码率BFI:  Bad Frame Indication  坏帧指示BOIC:  Barring of Outgoing International Calls  闭锁出国际呼叫BP:  Burst Period  突发脉冲序列周期BSC:  Base Station Controller  基站控制器BSS:  Base Station sub-System  基站子系统BTS:  Base Transceiver Station  基站收发信台CC:  Call Control  呼叫控制CCCH:  Common Control Channel  公共控制信道CELPC:  Code Excited Linear Prediction(Coding)  码激励线性预测(编码)CF:  Call Forwarding  呼叫转移
 楼主| 发表于 2008-11-6 15:26:26 | 显示全部楼层
RE:GSM符号与缩略语
CFB:  Call Forwarding on Mobile Subscriber Busy  遇移动用户忙呼叫转移
CFC:  Call Forwarding Conditional  有条件呼叫转移
CFNRc:  Call Forwarding on Mobile Subscriber Not Reachable  移动用户不可及呼叫转移
CFNRy:  Call Forwarding on No Reply  无应答呼叫转移
CFU:  Call Forwarding Unconditional  无条件呼叫转移
CLIP:  Calling Line Identification Presentation  主叫号码识别显示
CLIR:  Calling Line Identification Restriction  主叫号码识别限制
COLP:  Connected Line Identification Presentation  连接号码识别显示
COLR:  Connected Line Identification Restriction  连接号码识别限制
CRC:  Cyclic Redumdancy Check  循环冗余校验
CUG:  Closed User Group  闭合用户群
CW:  Call Waiting  呼叫等待
DAI:  Digital Audio Interface  数字音频接口
DCS:  Digital Cellular System  数字蜂窝系统
DL:  Downlink  下行链路
DTX:  Discontinuous Transmission  非连续发射
emf:  electromotive force  电动势
EL:  Echo Loss  回波损耗
ERP:  Ear Reference Point  耳参考点
EQ50:  Equalization test 50  多径条件(均衡测试) 50km/h
FACCH:  Fast Associated Control Channel  快速随路控制信道
FCCH:  Frequency Correction Channel  频率校正信道
FER:  Frame Erase Ratio  帧擦除率
 楼主| 发表于 2008-11-6 15:26:48 | 显示全部楼层
RE:GSM符号与缩略语
FH:  Frequency Hopping  跳频
GMSK:  Gaussian Filtered Minimum Shift Frequency Keying  高斯滤波最小移频键控
GSM:  Global System for Mobile Communication  全球移动通信系统
HLR:  Home location Register  归属用户位置寄存器
HO:  Hand Over  越区切换
HOLD:  Call Hold  呼叫保持
HT100:  Hilly Terrain 100  丘陵地区100km/h
IMEI:  International Mobile Station Equipment Identity  国际移动台设备识别
IMSI:  International Mobile Subscriber Identity  国际移动用户识别
LRGP:  Loudness Rating Guarding Position  响度评定值保护环
LSTR:  Listener Side Tone Rating  听者侧音评定值
MCI:  Malicious Call Identification  恶意呼叫识别
ME:  Mobile Equipment  移动设备
MM:  Mobility Management  移动性管理
MMI:  Man Manchine Interface  人机接口
MOC:  Mobile Originating Call  移动主叫
MRP:  Mouth Reference Point  嘴参考点
MS:  Mobile Station  移动台
MSC:  Mobile Switch Center  移动交换中心
MT:  Mobile Termination  移动终端
MTC:  Mobile Termination Call  移动被叫
 楼主| 发表于 2008-11-6 15:27:13 | 显示全部楼层
RE:GSM符号与缩略语
OC:  Originating Call  主叫
PAD:  Packet Assembly/Disassembly  分组装拆包
PCH:  Paging Channel  寻呼信道
PCM:  Pulse Code Modulation  脉码调制
PIN:  Personal Identification Number  个人识别号码
PLMN:  Public Land Mobile Network  公共陆地移动网络
PSTN:  Public Switch Telephone Network  公共交换电话网
3PTY:  Three Party Service  三方业务
RA250:  Rural Area 250  郊区250km/h
RA130:  Rural Area 130  郊区130km/h
RBER:  Residual Bit Error Rate  残余比特误码率
RMS:   Root Mean Square  均方根值
RPE-LTP:  Regular Pulse Excite Linear Prediction Coding with Long Term Prediction  带
有长期预测的规则脉冲激励线性预测编码
RLR:  Receiving Loudness Rating  接收响度评定值
SACCH:  Slow Associated Control Channel  慢速随路控制信道
SCH:  Synchronization Channel  同步信道
SDCCH:  Stand-alone Dedicated Control Channel  独立专用控制信道
 楼主| 发表于 2008-11-6 15:27:30 | 显示全部楼层
RE:GSM符号与缩略语
SID:  Silence Descriptor  静寂描述帧
SIM:  Subscriber Identity Module  用户识别卡
SLR:  Sending Loudness Rating  发送响度评定值
SMS:  Short Message Service  短消息业务
SS:  System Simulator  系统模拟器
STMR:  Side Tone Masking Rating  侧音掩蔽评定值
TAL:  Telephone Acoustic Loss  电话声耦合损耗
TC:  Terminating Call  被叫
TCH:  Traffic Channel  业务信道
TCH/F:  Traffic Channel/Full  全速率业务信道
TCH/H:  Traffic Channel/Half  半速率业务信道
TDMA:  Time Division Multiple Access  时分多址
TE:  Terminal Equipment  终端设备
TU50:  Urban Area 50  城区50km/h
TU3:  Urban Area 3  城区3km/h
TU1.5:  Urban Area 1.5  城区1.5km/h
UFI:  Unreliable Frame Indication  不可靠帧指示
UL:  Uplink  上行链路
VAD:  Voice Activity Detection  话音激活检验
VLR:  Visitor Location Register  访问用户位置寄存器
UFR:  Unreliable Frame Ratio  不可靠帧率
 楼主| 发表于 2008-11-6 15:27:54 | 显示全部楼层
RE:GSM符号与缩略语
呵呵,一起学习吧
GMT+8, 2024-11-25 19:46 , Processed in 0.158737 second(s), 25 queries , MemCache On.
