楼主 |
发表于 2008-6-26 21:05:36
只看该作者
RE:3GPP2 C.S0011-B IS-98E免费发放CDMA标准了
x
4.4.7.1 1 Definition ............................................................................................... 4-39
2 4.4.7.2 Method of Measurement......................................................................... 4-39
3 4.4.7.3 Minimum Standard ................................................................................ 4-41
4 4.4.8 Power Up Function Output Power ............................................................... 4-42
5 4.4.8.1 Definition ............................................................................................... 4-42
6 4.4.8.2 Method of Measurement......................................................................... 4-42
7 4.4.8.3 Minimum Standard ................................................................................ 4-43
8 4.4.9 Code Channel to Reverse Pilot Channel Output Power Accuracy................ 4-44
9 4.4.9.1 Definition ............................................................................................... 4-44
10 4.4.9.2 Method of Measurement......................................................................... 4-44
11 4.4.9.2.1 Code Channel Output Power for the Enhanced Access Channel
12 Header, Enhanced Access Channel Data, and Reverse Common
13 Control Channel Data ........................................................................ 4-44
14 4.4.9.2.2 Code Channel Output Power for the Reverse Traffic Channel ........... 4-46
15 4.4.9.3 Minimum Standard ................................................................................ 4-48
16 4.4.10 Reverse Pilot Channel Transmit Phase Discontinuity.................................. 4-50
17 4.4.10.1 Definition ............................................................................................... 4-50
18 4.4.10.2 Method of Measurement......................................................................... 4-51
19 4.4.10.3 Minimum Standard ................................................................................ 4-52
20 4.4.11 Reverse Traffic Channel Output Power During Changes in Data Rate ........ 4-52
21 4.4.11.1 Definition ............................................................................................... 4-52
22 4.4.11.2 Method of Measurement......................................................................... 4-53
23 4.4.11.3 Minimum Standard ................................................................................ 4-53
24 4.5 Limitations on Emissions................................................................................... 4-54
25 4.5.1 Conducted Spurious Emissions................................................................... 4-54
26 4.5.1.1 Definition ............................................................................................... 4-54
27 4.5.1.2 Method of Measurement......................................................................... 4-54
28 4.5.1.3 Minimum Standard ................................................................................ 4-56
29 4.5.1.3.1 Spreading Rate 1................................................................................ 4-57
30 4.5.1.3.2 Spreading Rate 3................................................................................ 4-60
31 4.5.2 Radiated Spurious Emissions ...................................................................... 4-61
32 4.5.3 Occupied Bandwidth.................................................................................... 4-61
3GPP2 C.S0011-B
CONTENTS
xi
4.5.3.1 1 Definition................................................................................................4-61
2 4.5.3.2 Method of Measurement.........................................................................4-61
3 4.5.3.3 Minimum Standard ................................................................................4-62
4 5 CDMA ENVIRONMENTAL REQUIREMENTS ..............................................................5-1
5 5.1 Temperature and Power Supply Voltage ..............................................................5-1
6 5.1.1 Definition .......................................................................................................5-1
7 5.1.2 Method of Measurement.................................................................................5-1
8 5.1.3 Minimum Standard ........................................................................................5-2
9 5.2 High Humidity......................................................................................................5-2
10 5.2.1 Definition .......................................................................................................5-2
11 5.2.2 Method of Measurement.................................................................................5-2
12 5.2.3 Minimum Standard ........................................................................................5-3
13 5.3 Vibration Stability ................................................................................................5-3
14 5.3.1 Definition .......................................................................................................5-3
15 5.3.2 Method of Measurement.................................................................................5-3
16 5.3.3 Minimum Standard ........................................................................................5-3
17 5.4 Shock Stability.....................................................................................................5-3
18 5.4.1 Definition .......................................................................................................5-3
19 5.4.2 Method of Measurement.................................................................................5-3
20 5.4.3 Minimum Standard ........................................................................................5-3
21 6 CDMA STANDARD TEST CONDITIONS .....................................................................6-1
22 6.1 Standard Equipment ............................................................................................6-1
23 6.1.1 Basic Equipment ............................................................................................6-1
24 6.1.2 Associated Equipment....................................................................................6-1
25 6.2 Standard Environmental Test Conditions ............................................................6-1
26 6.3 Standard Conditions for the Primary Power Supply.............................................6-1
27 6.3.1 General...........................................................................................................6-1
28 6.3.2 Standard DC Test Voltage from Accumulator Batteries .................................6-1
29 6.3.3 Standard AC Voltage and Frequency..............................................................6-2
30 6.4 Standard Test Equipment ....................................................................................6-2
31 6.4.1 Standard Channel Simulator .........................................................................6-2
3GPP2 C.S0011-B
CONTENTS
xii
6.4.1.1 Channel 1 Model Parameters ...................................................................... 6-2
2 6.4.1.2 Channel Model Parameter Conditions and Tolerances............................. 6-4
3 6.4.1.3 Channel Simulator Configurations........................................................... 6-5
4 6.4.2 Waveform Quality Measurement Equipment ................................................. 6-5
5 6.4.2.1 Rho Meter for Radio Configuration 1 and 2.............................................. 6-5
6 6.4.2.2 Rho Meter for Radio Configuration 3 through 9 ....................................... 6-7
7 6.4.2.2.1 The Ideal Composite Reference Signal ................................................. 6-7
8 6.4.2.2.2 The Transmitter Signal-Under-Test ..................................................... 6-8
9 6.4.2.2.3 Active Code-Channel Identification, Symbol Detection and
10 Parameter Estimation .......................................................................... 6-9
11 6.4.2.2.4 Rho (ρ) ................................................................................................ 6-10
12 6.4.2.2.5 Code-domain Power (CDP) ................................................................. 6-10
13 6.4.2.2.6 Power in Undesired Channels............................................................ 6-12
14 6.4.2.2.7 Code Domain Time Offsets and Phase Offsets Relative to Reverse
15 Pilot Channel ..................................................................................... 6-12
16 6.4.2.3 Code Domain Measurement Equipment Accuracy................................. 6-13
17 6.4.3 Base Station Equipment .............................................................................. 6-13
18 6.4.3.1 Transmitter Equipment .......................................................................... 6-13
19 6.4.3.2 Receiver Equipment ............................................................................... 6-15
20 6.4.3.3 Protocol Support..................................................................................... 6-15
21 6.4.3.4 Timing Signals........................................................................................ 6-15
22 6.4.4 AWGN Generator.......................................................................................... 6-15
23 6.4.5 CW Generator............................................................................................... 6-16
24 6.4.6 Spectrum Analyzer....................................................................................... 6-17
25 6.4.7 Average Power Meter.................................................................................... 6-18
26 6.4.8 Phase Transient Measuring Equipment ....................................................... 6-19
27 6.5 Functional System Set-ups................................................................................ 6-19
28 6.5.1 Functional Block Diagrams.......................................................................... 6-19
29 6.5.2 General Comments ...................................................................................... 6-21
30 6.6 Confidence Limits .............................................................................................. 6-33
31 6.6.1 Confidence Level of Error Rate..................................................................... 6-33
32 6.6.2 Confidence on Power Measurement During Fading..................................... 6-37
3GPP2 C.S0011-B
CONTENTS
xiii
6.6.3 Confidence Level 1 of Detection Time .............................................................6-39
2 ANNEX A: SELECTED PERFORMANCE REQUIREMENTS TABLES ...............................A-1
3 A.1 Forward Common Channel Performance Tables ..................................................A-1
4 A.1.1 Non-Slotted Mode Paging Channel Performance Requirements.....................A-1
5 A.1.1.1 Method of Measurement Test Parameters .............................................A-1
6 A.1.1.2 Minimum Standards Requirements.......................................................A-1
7 A.1.2 Slotted Mode Paging Channel Performance Requirements ............................A-2
8 A.1.2.1 Method of Measurement Test Parameters .............................................A-2
9 A.1.2.2 Minimum Standards Requirements.......................................................A-5
10 A.1.3 Forward Broadcast Control Channel Performance Requirements in
11 AWGN Channel ..............................................................................................A-6
12 A.1.3.1 Method of Measurement Test Parameters .............................................A-7
13 A.1.3.2 Minimum Standards Requirements.......................................................A-9
14 A.1.4 Forward Broadcast Control Channel Performance Requirements in
15 Multipath Fading Channel ...........................................................................A-11
16 A.1.4.1 Method of Measurement Test Parameters ...........................................A-12
17 A.1.4.2 Minimum Standards Requirements.....................................................A-32
18 A.1.5 Forward Common Control Channel Performance Requirements..................A-41
19 A.1.5.1 Method of Measurement Test Parameters ...........................................A-42
20 A.1.5.2 Minimum Standards Requirements.....................................................A-44
21 A.1.6 Common Assignment Channel and Common Power Control Channel
22 Performance Requirements ..........................................................................A-47
23 A.1.6.1 Method of Measurement Test Parameters ...........................................A-48
24 A.1.6.2 Minimum Standards Requirements.....................................................A-49
25 A.2 Forward Traffic Channel Demodulation Performance Tables .............................A-51
26 A.2.1 Forward Traffic Channel Performance Requirements in AWGN ...................A-51
27 A.2.1.1 Method of Measurement Test Parameters ...........................................A-51
28 A.2.1.2 Minimum Standards Requirements.....................................................A-68
29 A.2.2 Forward Traffic Channel Performance Requirements in Multipath Fading
30 Channel........................................................................................................A-90
31 A.2.2.1 Method of Measurement Test Parameters ...........................................A-91
32 A.2.2.2 Minimum Standards Requirements...................................................A-100
3GPP2 C.S0011-B
CONTENTS
xiv
A.2.3 Forward Fundamental Channel Performance 1 Requirements During Soft
2 Handoff.......................................................................................................A-105
3 A.2.3.1 Method of Measurement Test Parameters .........................................A-105
4 A.2.3.2 Minimum Standards Requirements ..................................................A-106
5 A.2.4 Power Control Bit Performance Requirements for Channels Belonging to
6 Different Power Control Sets During Soft Handoff .....................................A-106
7 A.2.4.1 Method of Measurement Test Parameters .........................................A-106
8 A.2.4.2 Minimum Standards Requirements ..................................................A-106
9 A.2.5 Power Control Bit Performance Requirements for Channels Belonging to
10 the Same Power Control Set.......................................................................A-107
11 A.2.5.1 Method of Measurement Test Parameters .........................................A-107
12 A.2.5.2 Minimum Standards Requirements ..................................................A-107
13 A.2.6 Power Control Subchannel Performance Requirements During Soft
14 Handoff.......................................................................................................A-107
15 A.2.6.1 Method of Measurement Test Parameters .........................................A-108
16 A.2.6.2 Minimum Standards Requirements ..................................................A-108
17 A.2.7 Forward Traffic Channel Performance Requirements in Multipath Fading
18 Channel with Closed Loop Power Control (FPC_MODE = ‘000’) .................A-108
19 A.2.7.1 Method of Measurement Test Parameters .........................................A-108
20 A.2.7.2 Minimum Standards Requirements ..................................................A-114
21 A.2.8 Forward Traffic Channel Performance Requirements in Multipath Fading
22 Channel with Closed Loop Power Control (FPC_MODE = ‘010’) .................A-119
23 A.2.8.1 Method of Measurement Test Parameters .........................................A-119
24 A.2.8.2 Minimum Standards Requirements ..................................................A-127
25 A.2.9 Forward Traffic Channel Performance Requirements in Multipath Fading
26 Channel with Outer Loop Power Control and Closed Loop Power Control
27 (FPC_MODE = ‘000’, ‘001’ and ‘010’) ..........................................................A-134
28 A.2.9.1 Method of Measurement Test Parameters .........................................A-135
29 A.2.9.2 Minimum Standards Requirements ..................................................A-138
30 A.2.10 Forward Traffic Channel Performance Requirements in Multipath Fading
31 with Closed Loop Power Control (FPC_MODE = ‘000’) and Transmit
32 Diversity (OTD or STS) ...............................................................................A-140
33 A.2.10.1 Method of Measurement Test Parameters .........................................A-140
34 A.2.10.2 Minimum Standards Requirements ..................................................A-144
3GPP2 C.S0011-B
CONTENTS
xv
A.2.11 Forward Traffic Channel Performance Requirements 1 in Multipath Fading
2 with Closed Loop Power Control (FPC_MODE = ‘010’) and Transmit
3 Diversity (OTD or STS) ...............................................................................A-149
4 A.2.11.1 Method of Measurement Test Parameters .........................................A-149
5 A.2.11.2 Minimum Standards Requirements...................................................A-153
6 A.2.12 Power Control Subchannel Performance Requirements During Reverse
7 Pilot Channel Gating ..................................................................................A-154
8 A.2.12.1 Method of Measurement Test Parameters .........................................A-155
9 A.2.12.2 Minimum Standards Requirements...................................................A-155
10 A.2.13 Power Control Subchannel Performance Requirements During Reverse
11 Fundamental Channel Gating....................................................................A-155
12 A.2.13.1 Method of Measurement Test Parameters .........................................A-155
13 A.2.13.2 Minimum Standards Requirements...................................................A-156 |
