The E5515C is a multiple format manufacturing test set designed for high
volume production testing of cellular and PCS telephone handsets. Depending
on installed test application, the E5515C can test AMPS, GSM, TDMA,
cdma2000, WCDMA, HSDPA, UMTS, EGPRS and GPRS handsets.
Option 4 (Digital bus) enables fading in cdma2000, 1xEV-DO, WCDMA,
GSM/GPRS/EGPRS lab applications and lab application suites.
Class 10 phones or above require 4.8HW option V48
Option V50 (5.0 hardware) is standard with units beginning with
serial number GB46040101 or above.
5.0HW is also available as an upgrde option E5515CU/285.
Option V48 (4.8 hardware) is standard with units beginning with
serial number GB45070001 or above.
4.8HW is also available as an upgrade option E5515CU/185.
Option H03 (EGPRS) capable hardware is standard with units beginning with
serial number GB44050001
Test Applications are described as:
E1960A GSM test application
E1961A No option required E1961A AMPS/136 test application
E1961A No option required E1962B cdma2000 test application
E1962B Requires option 003 E1962B-401 cdma2000 Rel A new control channels
E1962B1 Requires option 003, E1962B, and V48 or above(GB45070001、185) E1962B-402 cdma2000 Advanced AMPS
E1962B2 Requires option 003, E1962B, and V48 or above(GB45070001、185) E1962B-403 cdma2000 Authentication
E1962B3 Requires option 003, E1962B, and V48 or above(GB45070001、185) E1963A W-CDMA test application
E1963A Requires option 3 E1963A-401 W-CDMA video phone test
E1963A1 Requires option 3, E1963A, and V48 or above(GB45070001、185) E1963A-403 HSDPA test mode
E1963A2 Requires option 3, E1963A, V50(GB46040101、285) E1966A 1xEV-DO test application
E1966A Requires option 3 E1968A GSM/GPRS test application
E1968A-101 GSM test application
E1968A1 Requires option 2 E1968A-102 GPRS test application
E1968A2 Requires option 2 E1968A-201 GSM/GPRS test application
E1968A3 Requires option 2 E1968A-103 EGPRS test application
E1968A4 Requires option 2 and H03(GB44050001) E1968A-202 GSM/GPRS/EGPRS test application
E1968A5 Requires option 2 and H03(GB44050001) E1968A-410 EGPRS phase and amplitude vs time
E1968A6 Requires option 2, H03, and V48 or above(GB45070001、185) E1991B Test application suite
E1991B Requires option 2, 3, H03 and V48 or above(GB45070001、185) E1993A UMTS test application suite
E1993A Requires option 2, 3, H03 and V48 or above(GB45070001、185) E1996A CDMA/1xEV-DO test application suite
E1996A Requires option 3, and V48 or above(GB45070001、185) E1987A fast switch:
E1961A AMPS/136, E1962B cdma2000/IS-95/AMPS, E1963A W-CDMA,
E1968A GSM/GPRS/EGPRS, E1966A-1xEV-DO
E6785C GSM/GPRS/W-CDMA
E1987A Requires option H03 and V48 or above(GB45070001、185) Lab Applications are described as: (option 4 required to do fading)
E6701D GSM/GPRS Lab application
E6701D Requires option 2
E6702B cdma2000 Lab application
E6702B Requires option 3, recommened V48 for class 10 phones and up
E6703C WCDMA Lab application
E6703C Requires option 3, recommened V48 for class 10 phones and up
E6704A EGPRS Lab application requires E6701C or E6701D
E6704A Requires option 2, 3 and H03
E6706A 1xEV-DO requires E1966A test application
E6706A Requires option 3, V48 or above
E6716A cdma2000/1xEV-DO Lab application suite
E6716A Requires option 3, and V48 or above
E6717A UMTS Lab application suite
E6717A Requires option 2,3,H03,(V48 for class 10 phones and up).
E6719C Lab application suite
E6719C Requires option 2, 3, H03, and V48 or above
E6785C Lab application fast switching
Agilent defined bundle suites:
E1991A test application suite includes:
E1964A GPRS test application
E1985A Add new fast switching Tas
E1991B test application suite includes:
E1968A5 GSM/GPRS/EGPRS test application
E1987A Fast switching test application
E1993A UMTS test application suite includes (requires revision 4.8HW):
E1963A W-CDMA mobile test application
E1968A5 GSM, GPRS, EGPRS test applications
E6716A cdma2000/1xEV-DO Lab application suite includes:
E6702B cdma2000 lab application
E6706A 1xEV-DO lab application
E6717A UMTS Lab application suite includes:
E6701D GSM/GPRS lab application
E6703C W-CDMA lab application
E6704A EGPRS lab application
E6785C GSM/GPRS, W-CDMA lab application fast switching
E6719C Lab application suite includes:
Discontinued Test/Lab applications
E1960A has been replaced by E1968A1
E1964A has been replaced by E1968A2
E1985A has been replaced by E1985D
E1985A-E has been replaced by E1987A
E1991A has been replaced by E1991B
E6701B has been replaced by E6701D
E6701C has been replaced by E6701D
E6702A has been replaced by E6702B
E6703B has been replaced by E6703C
E6719A has been replaced by E6719B
E6719B has been replaced by E6719C |
