查看: 2570|回复: 0
提高m文件的运行速度(2)
发表于 2007-11-3 18:26:32 | 显示全部楼层 |阅读模式
m文件的不同编程风格对程序的运行速度也有比较大的影响,下面的代码比较了采用for 循环关系运算赋值,for循环+if 语句以及直接采用数组运算的运行速度。比较的结果第三种方法采用数组直接运算最快,第一种方法次之,第二种方法最慢。第一种方法的运行速度约为第三种方法的两到三倍,第二种方法为第三种方法的三到四倍。
具体在我的电脑中的一次运行结果为:0.28125秒,0.39063和0.09375。
function PerformanceComp()
Length = 10^7;
Source = round(rand(Length, 1)) * 2 - 1;
%% to evaluate the for loop time with memory allocation first
StartTime = cputime;
Res = zeros(Length, 1);
for i=1ength
    Res(i) = Source(i) >= 0;
end
EndTime = cputime;
Duration = EndTime - StartTime;
disp(['The for loop with memory allocation running time is ' num2str(Duration)]);
%  with if else clause
for i=1ength
    if Source(i) >= 0
        Res(i) = 1;
    else
        Res(i) = 0;
    end
end
EndTime = cputime;
disp(['The for loop with memory allocation running time' ...
    'with if clause is ' num2str(Duration)]);
%% to evaluate the array operation running time
Res = Source >= 0;
EndTime = cputime;
disp(['The array operation time is ' num2str(Duration)]);
GMT+8, 2025-2-19 07:00 , Processed in 0.099455 second(s), 15 queries , MemCache On.
