查看: 3741|回复: 0
将ADC转换值通过串口发送到PC端
  • 签到天数: 67 天
    [LV.6]常住居民II
    发表于 2013-9-4 09:24:36 | 显示全部楼层 |阅读模式
    主要硬件: EMSTM32V1+miniSTMV100(外部8MRC)
    编译环境: MDK3.10
    STM32是12位ADC,测量结果基本还可以!程序用了DMA来传输ADC转换值,调高了读取速度。
    #include
    #include
    #define ADC1_DR_Address ((u32)0x4001244C)
    #ifdef __GNUC__
    /* With GCC/RAISONANCE, small printf (option LD Linker->Libraries->Small printf
    set to 'Yes') calls __io_putchar() */
    #define PUTCHAR_PROTOTYPE int __io_putchar(int ch)
    #else
    #define PUTCHAR_PROTOTYPE int fputc(int ch, FILE *f)
    #endif /* __GNUC__ */
    vu16 ADC_ConvertedValue;
    void RCC_Config(void);
    void GPIO_Config(void);
    void USART_Config(void);
    void DMA_Config(void);
    void ADC_Config(void);
    void Put_String(u8 *p);
    void Delay(vu32 nCount);
    int main(void)
    RCC_Config();
    GPIO_Config();
    USART_Config();
    DMA_Config();
    ADC_Config();
    while(1)
    Delay(0x8FFFF);
    printf("ADC = %X Volt = %d mv\r\n", ADC_ConvertedValue, ADC_ConvertedValue*3300/4096);
    函数: void RCC_Config(void)
    功能: 配置系统时钟
    参数: 无
    返回: 无
    ErrorStatus HSEStartUpStatus;//定义外部高速晶体启动状态枚举变量
    RCC_DeInit();//复位RCC外部设备寄存器到默认值
    RCC_HSEConfig(RCC_HSE_ON); //打开外部高速晶振
    HSEStartUpStatus = RCC_WaitForHSEStartUp();//等待外部高速时钟准备好
    if(HSEStartUpStatus == SUCCESS)//外部高速时钟已经准别好
    RCC_HCLKConfig(RCC_SYSCLK_Div1);//配置AHB(HCLK)时钟=SYSCLK
    RCC_PCLK2Config(RCC_HCLK_Div1); //配置APB2(PCLK2)钟=AHB时钟
    RCC_PCLK1Config(RCC_HCLK_Div2);//配置APB1(PCLK1)钟=AHB 1/2时钟
    RCC_ADCCLKConfig(RCC_PCLK2_Div4);//配置ADC时钟=PCLK2 1/4
    RCC_PLLConfig(RCC_PLLSource_HSE_Div1, RCC_PLLMul_9);
    //配置PLL时钟 == 外部高速晶体时钟*9
    RCC_ADCCLKConfig(RCC_PCLK2_Div4);//配置ADC时钟= PCLK2/4
    RCC_PLLCmd(ENABLE);//使能PLL时钟
    while(RCC_GetFlagStatus(RCC_FLAG_PLLRDY) == RESET) //等待PLL时钟就绪
    RCC_SYSCLKConfig(RCC_SYSCLKSource_PLLCLK);//配置系统时钟 = PLL时钟
    while(RCC_GetSYSCLKSource() != 0x08) //检查PLL时钟是否作为系统时钟
    RCC_AHBPeriphClockCmd(RCC_AHBPeriph_DMA, ENABLE);//使能DMA时钟
    RCC_APB2PeriphClockCmd(RCC_APB2Periph_ADC1 | RCC_APB2Periph_GPIOC, ENABLE);
    //使能ADC1,GPIOC时钟
    RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOD | RCC_APB2Periph_AFIO, ENABLE);
    //打开GPIOD和AFIO时钟
    RCC_APB1PeriphClockCmd(RCC_APB1Periph_USART2, ENABLE);//使能串口2时钟
    函数: void GPIO_Config(void)
    功能: GPIO配置
    参数: 无
    返回: 无
    //设置RTS(PD.04),Tx(PD.05)为推拉输出模式
    GPIO_InitTypeDef GPIO_InitStructure; //定义GPIO初始化结构体
    GPIO_PinRemapConfig(GPIO_Remap_USART2, ENABLE);//使能GPIO端口映射USART2
    GPIO_InitStructure.GPIO_Pin = GPIO_Pin_4 | GPIO_Pin_5;//选择PIN4 PIN5
    GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz; //引脚频率50M
    GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF_PP;//引脚设置推拉输出
    GPIO_Init(GPIOD, &GPIO_InitStructure);//初始化GPIOD
    //配置CTS (PD.03),USART2 Rx (PD.06)为浮点输入模式
    GPIO_InitStructure.GPIO_Pin = GPIO_Pin_3 | GPIO_Pin_6;
    GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IN_FLOATING;
    //配置PC4为模拟输入
    GPIO_InitStructure.GPIO_Pin = GPIO_Pin_4;
    GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AIN;
    GPIO_Init(GPIOC, &GPIO_InitStructure);
    函数: void DMA_Config(void)
    功能: DMA配置
    参数: 无
    返回: 无
    DMA_InitTypeDef DMA_InitStructure;//定义DMA初始化结构体
    DMA_DeInit(DMA_Channel1);//复位DMA通道1
    DMA_InitStructure.DMA_PeripheralBaseAddr = ADC1_DR_Address; //定义 DMA通道外设基地址=ADC1_DR_Address
    DMA_InitStructure.DMA_MemoryBaseAddr = (u32)&ADC_ConvertedValue; //定义DMA通道存储器地址
    DMA_InitStructure.DMA_DIR = DMA_DIR_PeripheralSRC;//指定外设为源地址
    DMA_InitStructure.DMA_BufferSize = 1;//定义DMA缓冲区大小1
    DMA_InitStructure.DMA_PeripheralInc = DMA_PeripheralInc_Disable;//当前外设寄存器地址不变
    DMA_InitStructure.DMA_MemoryInc = DMA_MemoryInc_Disable;//当前存储器地址不变
    DMA_InitStructure.DMA_PeripheralDataSize = DMA_PeripheralDataSize_HalfWord;//定义外设数据宽度16位
    DMA_InitStructure.DMA_MemoryDataSize = DMA_MemoryDataSize_HalfWord; //定义存储器数据宽度16位
    DMA_InitStructure.DMA_Mode = DMA_Mode_Circular;//DMA通道操作模式位环形缓冲模式
    DMA_InitStructure.DMA_Priority = DMA_Priority_High;//DMA通道优先级高
    DMA_InitStructure.DMA_M2M = DMA_M2M_Disable;//禁止DMA通道存储器到存储器传输
    DMA_Init(DMA_Channel1, &DMA_InitStructure);//初始化DMA通道1
    DMA_Cmd(DMA_Channel1, ENABLE); //使能DMA通道1
    函数: void ADC_Config(void)
    功能: ADC配置
    参数: 无
    返回: 无
    ADC_InitTypeDef ADC_InitStructure;//定义ADC初始化结构体变量
    ADC_InitStructure.ADC_Mode = ADC_Mode_Independent;//ADC1和ADC2工作在独立模式
    ADC_InitStructure.ADC_ScanConvMode = ENABLE; //使能扫描
    ADC_InitStructure.ADC_ContinuousConvMode = ENABLE;//ADC转换工作在连续模式
    ADC_InitStructure.ADC_ExternalTrigConv = ADC_ExternalTrigConv_None;//有软件控制转换
    ADC_InitStructure.ADC_DataAlign = ADC_DataAlign_Right;//转换数据右对齐
    ADC_InitStructure.ADC_NbrOfChannel = 1;//转换通道为通道1
    ADC_Init(ADC1, &ADC_InitStructure); //初始化ADC
    ADC_RegularChannelConfig(ADC1, ADC_Channel_14, 1, ADC_SampleTime_28Cycles5);
    //ADC1选择信道14,音序器等级1,采样时间239.5个周期
    ADC_DMACmd(ADC1, ENABLE);//使能ADC1模块DMA
    ADC_Cmd(ADC1, ENABLE);//使能ADC1
    ADC_ResetCalibration(ADC1); //重置ADC1校准寄存器
    while(ADC_GetResetCalibrationStatus(ADC1));//等待ADC1校准重置完成
    ADC_StartCalibration(ADC1);//开始ADC1校准
    while(ADC_GetCalibrationStatus(ADC1));//等待ADC1校准完成
    ADC_SoftwareStartConvCmd(ADC1, ENABLE); //使能ADC1软件开始转换
    函数: void USART_Config(void)
    功能: USART配置
    参数: 无
    返回: 无
    USART_InitTypeDef USART_InitStructure; //定义串口初始化结构体
    USART_InitStructure.USART_BaudRate = 115200;//波特率9600
    USART_InitStructure.USART_WordLength = USART_WordLength_8b;//8位数据
    USART_InitStructure.USART_StopBits = USART_StopBits_1;//1个停止位
    USART_InitStructure.USART_Parity = USART_Parity_No ; //无校验位
    USART_InitStructure.USART_HardwareFlowControl = USART_HardwareFlowControl_None;
    //禁用RTSCTS硬件流控制
    USART_InitStructure.USART_Mode = USART_Mode_Rx | USART_Mode_Tx;//使能发送接收
    USART_InitStructure.USART_Clock = USART_Clock_Disable; //串口时钟禁止
    USART_InitStructure.USART_CPOL = USART_CPOL_Low; //时钟下降沿有效
    USART_InitStructure.USART_CPHA = USART_CPHA_2Edge;//数据在第二个时钟沿捕捉
    USART_InitStructure.USART_LastBit = USART_LastBit_Disable;
    //最后数据位的时钟脉冲不输出到SCLK引脚
    USART_Init(USART2, &USART_InitStructure);//初始化串口2
    USART_Cmd(USART2, ENABLE);//串口2使能
    函数: void Put_String(void)
    功能: 向串口输出字符串
    参数: 无
    返回: 无
    while(*p)
    USART_SendData(USART2, *p++);
    while(USART_GetFlagStatus(USART2, USART_FLAG_TXE) == RESET)
    函数: void Delay(vu32 nCount)
    功能: 延时指定时间
    参数: vu32 nCount 延时指定时间
    返回: 无
    for(; nCount != 0; nCount--);
    函数:PUTCHAR_PROTOTYPE
    功能: 重定向C库printf函数
    参数: 无
    返回: 无
    PUTCHAR_PROTOTYPE
    USART_SendData(USART2, (u8) ch);//发送一字节数据
    }//等待发送完成
    return ch;
    GMT+8, 2024-11-25 19:34 , Processed in 0.107504 second(s), 15 queries , MemCache On.
