查看: 4066|回复: 4
[室内导航记录]不常见的s6d1121 IC驱动2.4彩屏程序
  • 签到天数: 45 天
    [LV.5]常住居民I
    发表于 2013-9-2 22:03:22 | 显示全部楼层 |阅读模式
    最近一直在搞姿态仪,lcd是之前的研究过,鉴于s6d1121  IC 比较少见,所以贴出移植的lcd驱动程序也许对大家有用。xpt2046触摸程序稍后给大家贴出。
    void pin_init(void)                                    //引脚设置
      GPIO_InitTypeDef GPIO_InitStructure;
      RCC_AHB1PeriphClockCmd(RCC_AHB1Periph_GPIOE|RCC_AHB1Periph_GPIOD|RCC_AHB1Periph_GPIOA,ENABLE);
      GPIO_InitStructure.GPIO_Pin=GPIO_Pin_All;
      GPIO_InitStructure.GPIO_Mode=GPIO_Mode_OUT;
      GPIO_InitStructure.GPIO_OType=GPIO_OType_PP;
      GPIO_InitStructure.GPIO_Speed=GPIO_Speed_100MHz;
      GPIO_InitStructure.GPIO_PuPd=GPIO_PuPd_UP;
      GPIO_Init(GPIOE,&GPIO_InitStructure);
      GPIO_InitStructure.GPIO_Pin=GPIO_Pin_0|GPIO_Pin_1|GPIO_Pin_2|GPIO_Pin_3|GPIO_Pin_4;
      GPIO_Init(GPIOA,&GPIO_InitStructure);
      GPIO_InitStructure.GPIO_Pin=GPIO_Pin_12|GPIO_Pin_13|GPIO_Pin_14|GPIO_Pin_15;
      GPIO_Init(GPIOD,&GPIO_InitStructure);
    lcd驱动程序
    u16 BACK_COLOR, POINT_COLOR;   //背景色,画笔色
    #ifdef  Bus_16    //条件编译-16位数据模式
    void LCD_Writ_Bus(u8 VH,u8 VL)   //并行数据写入函数
        LCD_DataPortH=VH;
        LCD_DataPortL=VL;
        LCD_WR=0;
        LCD_WR=1;
    #else
    //条件编译-8位数据模式
        GPIO_Write(GPIOE,VH);;
        LCD_WR0;
        LCD_WR1;
        GPIO_Write(GPIOE,VL);;
        LCD_WR0;
        LCD_WR1;
    #endif
    void LCD_WR_DATA8(u8 VH,u8 VL) //发送数据-8位参数
        LCD_RS1;
        LCD_Writ_Bus(VH,VL);
    void LCD_WR_DATA(u16 da)
        LCD_RS1;
        LCD_Writ_Bus(da>>8,da);
    void LCD_WR_REG(u16 da)
        LCD_RS0;
    void LCD_WR_REG_DATA(u16 reg,u16 da)
        LCD_WR_REG(reg);
        LCD_WR_DATA(da);
    void Address_set( u16 x1,u16 y1,u16 x2, u16 y2)               //指定窗口显示图片x1,x2 ,y1,y2 分别为x轴,y轴起始
        //和终止坐标
        LCD_WR_REG(0x0046);LCD_WR_DATA8(x2,x1);
        LCD_WR_REG(0x0047);LCD_WR_DATA(y2);
        LCD_WR_REG(0x0048);LCD_WR_DATA(y1);
        LCD_WR_REG(0x0020);LCD_WR_DATA(x1);
        LCD_WR_REG(0x0021);LCD_WR_DATA(y1);
        LCD_WR_REG(0x0022);
    void Lcd_Init(void)                                                  //lcd初始化程序,详细命令参考数据手册。
        LCD_CS1;
        if(GPIO_ReadOutputDataBit(GPIOE,GPIO_Pin_1))
           LCD_WR_REG_DATA(0,0);
           LCD_ShowString(0,0," ");
           LCD_ShowNum(0,0,0,0);
           LCD_Show2Num(0,0,0,0);
           LCD_DrawPoint_big(0,0);
           LCD_DrawRectangle(0,0,0,0);
           Draw_Circle(0,0,0);
        LCD_REST1;
        delayms(5);
        LCD_REST0;
        delayms(5);
        LCD_REST1;
        LCD_CS1;
        LCD_RD1;
        LCD_WR1;
        delayms(5);
        LCD_CS0;  //打开片选使能
        LCD_WR_REG_DATA(0x11,0x2004);
        LCD_WR_REG_DATA(0x13,0xCC00);
        LCD_WR_REG_DATA(0x15,0x2600);
        LCD_WR_REG_DATA(0x14,0x252A);
    //  LCD_WR_REG_DATA(0x14,0x002A);
        LCD_WR_REG_DATA(0x12,0x0033);
        LCD_WR_REG_DATA(0x13,0xCC04);
        delayms(1);
        LCD_WR_REG_DATA(0x13,0xCC06);
        delayms(1);
        LCD_WR_REG_DATA(0x13,0xCC4F);
        delayms(1);
        LCD_WR_REG_DATA(0x13,0x674F);
        LCD_WR_REG_DATA(0x11,0x2003);
        delayms(1);
        LCD_WR_REG_DATA(0x30,0x2609);
        LCD_WR_REG_DATA(0x31,0x242C);
        LCD_WR_REG_DATA(0x32,0x1F23);
        LCD_WR_REG_DATA(0x33,0x2425);
        LCD_WR_REG_DATA(0x34,0x2226);
        LCD_WR_REG_DATA(0x35,0x2523);
        LCD_WR_REG_DATA(0x36,0x1C1A);
        LCD_WR_REG_DATA(0x37,0x131D);
        LCD_WR_REG_DATA(0x38,0x0B11);
        LCD_WR_REG_DATA(0x39,0x1210);
        LCD_WR_REG_DATA(0x3A,0x1315);
        LCD_WR_REG_DATA(0x3B,0x3619);
        LCD_WR_REG_DATA(0x3C,0x0D00);
        LCD_WR_REG_DATA(0x3D,0x000D);
        LCD_WR_REG_DATA(0x16,0x0007);
        LCD_WR_REG_DATA(0x02,0x0013);
        LCD_WR_REG_DATA(0x03,0x0003);
        LCD_WR_REG_DATA(0x01,0x0127);
        delayms(1);
        LCD_WR_REG_DATA(0x08,0x0303);
        LCD_WR_REG_DATA(0x0A,0x000B);
        LCD_WR_REG_DATA(0x0B,0x0003);
        LCD_WR_REG_DATA(0x0C,0x0000);
        LCD_WR_REG_DATA(0x41,0x0000);
        LCD_WR_REG_DATA(0x50,0x0000);
        LCD_WR_REG_DATA(0x60,0x0005);
        LCD_WR_REG_DATA(0x70,0x000B);
        LCD_WR_REG_DATA(0x71,0x0000);
        LCD_WR_REG_DATA(0x78,0x0000);
        LCD_WR_REG_DATA(0x7A,0x0000);
        LCD_WR_REG_DATA(0x79,0x0007);
        LCD_WR_REG_DATA(0x07,0x0051);
        delayms(1);
        LCD_WR_REG_DATA(0x07,0x0053);
        LCD_WR_REG_DATA(0x79,0x0000);
        LCD_WR_REG(0x0022);
    //清屏函数
    //Color:要清屏的填充色
    void LCD_Clear(u16 Color)
        u8 VH,VL;
        u16 i,j;
        VH=Color>>8;
        VL=Color;
        Address_set(0,0,LCD_W-1,LCD_H-1);
        for(i=0;i<LCD_W;i++)
          for (j=0;j<LCD_H;j++)
                 LCD_WR_DATA8(VH,VL);
    //在指定位置显示一个汉字(32*33大小)
    //dcolor为内容颜色,gbcolor为背静颜色
    void showhanzi(u16 x, u16 y, u8 index)
         u8 i,j;
         u8 *temp=hanzi;
        Address_set(x,y,x+31,y+31); //设置区域
        temp+=index*128;
        for(j=0;j<128;j++)
            for(i=0;i<8;i++)
                if((*temp&(1<<i))!=0)
                    LCD_WR_DATA(POINT_COLOR);
                else
                    LCD_WR_DATA(BACK_COLOR);
            temp++;
    //画点
    //POINT_COLOR:此点的颜色
    void LCD_DrawPoint(u16 x,u16 y)
        Address_set(x,y,x,y);//设置光标位置
    //画一个大点
    //POINT_COLOR:此点的颜色
    void LCD_DrawPoint_big(u16 x,u16 y)
        LCD_Fill(x-1,y-1,x+1,y+1,POINT_COLOR);
    //在指定区域内填充指定颜色
    //区域大小:
    //  (xend-xsta)*(yend-ysta)
    void LCD_Fill(u16 xsta,u16 ysta,u16 xend,u16 yend,u16 color)
        u16 i,j;
        Address_set(xsta,ysta,xend,yend);      //设置光标位置
        for(i=ysta;i<=yend;i++)
            for(j=xsta;j<=xend;j++)LCD_WR_DATA(color);//设置光标位置
    //画线
    //x1,y1:起点坐标
    //x2,y2:终点坐标
    void LCD_DrawLine(u16 x1, u16 y1, u16 x2, u16 y2)
        u16 t;
        u16 xerr=0,yerr=0,delta_x,delta_y,distance;
        u16 incx,incy,uRow,uCol;
        delta_x=x2-x1; //计算坐标增量
        delta_y=y2-y1;
        uRow=x1;
        uCol=y1;
        if(delta_x>0)incx=1; //设置单步方向
        else if(delta_x==0)incx=0;//垂直线
        else {incx=-1;delta_x=-delta_x;}
        if(delta_y>0)incy=1;
        else if(delta_y==0)incy=0;//水平线
        else{incy=-1;delta_y=-delta_y;}
        if( delta_x>delta_y)distance=delta_x; //选取基本增量坐标轴
        else distance=delta_y;
        for(t=0;t<=distance+1;t++ )//画线输出
            LCD_DrawPoint(uRow,uCol);//画点
            xerr+=delta_x ;
            yerr+=delta_y ;
            if(xerr>distance)
                xerr-=distance;
                uRow+=incx;
            if(yerr>distance)
                yerr-=distance;
                uCol+=incy;
    //画矩形
    void LCD_DrawRectangle(u16 x1, u16 y1, u16 x2, u16 y2)
        LCD_DrawLine(x1,y1,x2,y1);
        LCD_DrawLine(x1,y1,x1,y2);
        LCD_DrawLine(x1,y2,x2,y2);
        LCD_DrawLine(x2,y1,x2,y2);
    //在指定位置画一个指定大小的圆
    //(x,y):中心点
    //r    :半径
    void Draw_Circle(u16 x0,u16 y0,u8 r)
        u16 a,b;
        u16 di;
        a=0;b=r;
        di=3-(r<<1);             //判断下个点位置的标志
        while(a<=b)
            LCD_DrawPoint(x0-b,y0-a);             //3
            LCD_DrawPoint(x0+b,y0-a);             //0
            LCD_DrawPoint(x0-a,y0+b);             //1
            LCD_DrawPoint(x0-b,y0-a);             //7
            LCD_DrawPoint(x0-a,y0-b);             //2
            LCD_DrawPoint(x0+b,y0+a);             //4
            LCD_DrawPoint(x0+a,y0-b);             //5
            LCD_DrawPoint(x0+a,y0+b);             //6
            LCD_DrawPoint(x0-b,y0+a);
            a++;
            //使用Bresenham算法画圆
            if(di<0)di +=4*a+6;
            else
                di+=10+4*(a-b);
                b--;
    //在指定位置显示一个字符
    //num:要显示的字符:" "--->"~"
    //mode:叠加方式(1)还是非叠加方式(0)
    //在指定位置显示一个字符
    void LCD_ShowChar(u16 x,u16 y,u8 num,u8 mode)
        u8 temp;
        u8 pos,t;
        u16 x0=x;
        u16 colortemp=POINT_COLOR;
        if(x>LCD_W-16||y>LCD_H-16)return;
        //设置窗口
        num=num-' ';//得到偏移后的值
        Address_set(x,y,x+8-1,y+16-1);      //设置光标位置
        if(!mode) //非叠加方式
            for(pos=0;pos<16;pos++)
                temp=asc2_1608[(u16)num*16+pos];         //调用字体库
                for(t=0;t<8;t++)
                    if(temp&0x01)POINT_COLOR=colortemp;
                    else POINT_COLOR=BACK_COLOR;
                    temp>>=1;
                    x++;
                x=x0;
                y++;
        }else//叠加方式
                temp=asc2_1608[(u16)num*16+pos];         //调用1608字体
                for(t=0;t<8;t++)
                    if(temp&0x01)LCD_DrawPoint(x+t,y+pos);//画一个点
                    temp>>=1;
    //m^n函数
    u32 mypow(u8 m,u8 n)
        u32 result=1;
        while(n--)result*=m;
        return result;
    //显示2个数字
    //x,y :起点坐标
    //len :数字的位数
    //color:颜色
    //num:数值(0~4294967295);
    void LCD_ShowNum(u16 x,u16 y,u32 num,u8 len)
        u8 t,temp;
        u8 enshow=0;
        num=(u16)num;
        for(t=0;t<len;t++)
            temp=(num/mypow(10,len-t-1))%10;
            if(enshow==0&&t<(len-1))
                if(temp==0)
                    LCD_ShowChar(x+8*t,y,' ',0);
                    continue;
                }else enshow=1;
            LCD_ShowChar(x+8*t,y,temp+48,0);
    //显示2个数字
    //x,y:起点坐标
    //num:数值(0~99);
    void LCD_Show2Num(u16 x,u16 y,u16 num,u8 len)
        u8 t,temp;
        for(t=0;t<len;t++)
            LCD_ShowChar(x+8*t,y,temp+'0',0);
    //显示字符串
    //x,y:起点坐标
    //*p:字符串起始地址
    //用16字体
    void LCD_ShowString(u16 x,u16 y,const u8 *p)
        while(*p!='\0')
            if(x>LCD_W-16){x=0;y+=16;}
            if(y>LCD_H-16){y=x=0;LCD_Clear(RED);}
            LCD_ShowChar(x,y,*p,0);
            x+=8;
            p++;
    控制器资料-S6D1121.pdf
    3.3 MB, 下载次数: 49
    ic
  • 签到天数: 45 天
    [LV.5]常住居民I
     楼主| 发表于 2013-9-2 22:05:49 | 显示全部楼层
    虽然不怎么样但是自顶
  • 签到天数: 173 天
    [LV.7]常住居民III
    发表于 2013-9-2 22:52:12 | 显示全部楼层
    没有硬件,也没法测试,帮顶吧!
    无聊
    2017-12-28 22:36
  • 签到天数: 43 天
    [LV.5]常住居民I
    发表于 2013-10-14 17:37:41 | 显示全部楼层
    顶楼主,继续努力!!
  • 签到天数: 9 天
    发表于 2013-12-1 19:47:24 | 显示全部楼层
    顶楼主,继续努力!!
    GMT+8, 2025-1-29 08:48 , Processed in 0.143407 second(s), 23 queries , MemCache On.
