查看: 2701|回复: 0
打印 上一主题 下一主题
Capacity of Differential versus Non-Differential Unitary Space-Time Modulation f
跳转到指定楼层
楼主
发表于 2007-9-14 11:49:19 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
Abstract: Differential Unitary Space-Time Modulation (DUSTM) and its earlier nondifferential counterpart, USTM, permit high-throughput MIMO communication entirely without the possession of channel state information (CSI) by either the transmitter or the receiver. For an isotropically random unitary input we obtain the exact closed-form expression for the probability density of the DUSTM received signal, which permits the straightforward Monte Carlo evaluation of its mutual information. We compare the performance of DUSTM and USTM through both numerical computations of mutual information and through the analysis of low- and high-SNR asymptotic expressions. In our comparisons the symbol durations of the equivalent unitary space-time signals are both equal to T, as are the number of receive antennas N. For DUSTM the number of transmit antennas is constrained by the scheme to be M = T/2, while USTM has no such constraint. If DUSTM and USTM utilize the same number of transmit antennas at high SNR's the normalized mutual information of the differential and the nondifferential schemes expressed in bits/sec/Hz are asymptotically equal, with the differential scheme performing somewhat better, while at low SNR's the normalized mutual information of DUSTM is asymptotically twice the normalized mutual information of USTM. If, instead, USTM utilizes the optimum number of transmit antennas then USTM can outperform DUSTM at sufficiently low SNR's.
cap_dustm.pdf
202.92 KB, 下载次数: 10
举报
站长推荐上一条 1/4 下一条
有奖活动|英飞凌智能座舱直播活动
查看 »
GMT+8, 2025-4-15 16:17 , Processed in 0.099400 second(s), 18 queries , MemCache On.
