查看: 2328|回复: 1
打印 上一主题 下一主题
Communication Over a Wireless Network with Random Connections
跳转到指定楼层
楼主
发表于 2007-9-14 11:29:18 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
Abstract: We analyze a network of nodes in which pairs communicate over a shared wireless medium. We are interested in the maximum total aggregate traffic flow possible as given by the number of users multiplied by their data rate. Our model differs substantially from the many existing approaches in that the channel connections in our network are entirely random: we assume that, rather than being governed by geometry and a decay-versus-distance law, the strengths of the connections between nodes are drawn independently from a common distribution. Such a model is appropriate for environments where the first order effect that governs the signal strength at a receiving node is a random event (such as the existence of an obstacle), rather than the distance from the transmitter.
We show that the aggregate traffic flow as a function of the number of nodes "n" is a strong function of the channel distribution. In particular, for certain distributions the aggregate traffic flow is at least n/(\log n)^d for some d>0, which is significantly larger than the n^{1/2} results obtained for many geometric models. Our results provide guidelines for the connectivity that is needed for large aggregate traffic. We show how our model and distance-based models can be related in some cases.
network.pdf
248.32 KB, 下载次数: 7
举报
发表于 2009-3-11 15:36:26 | 只看该作者
RE:Communication Over a Wireless Network with Random Connections
Thank you very much,that's good.
举报
站长推荐上一条 2/5 下一条
「工聚四方·创见未来」欧时RS入驻四方维创新中心线下沙龙
查看 »
GMT+8, 2025-4-30 07:15 , Processed in 0.122956 second(s), 21 queries , MemCache On.
