查看: 2488|回复: 1
打印 上一主题 下一主题
Capacity and Character Expansions: Moment Generating Function and Other Exact Re
跳转到指定楼层
楼主
发表于 2007-9-14 11:22:10 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
Abstract: We apply a promising new method from the field of representations of Lie groups to calculate integrals over unitary groups, which are important for multi-antenna communications. To demonstrate the power and simplicity of this technique, we first re-derive a number of results that have been used recently in the community of wireless information theory, using only a few simple steps. In particular, we derive the joint probability distribution of eigenvalues of the matrix GG , with G a semicorrelated Gaussian random matrix or a Gaussian random matrix with a non-zero mean. These joint probability distribution functions can then be used to calculate the moment generating function of the mutual information for Gaussian MIMO channels with these probability distribution of their channel matrices G. We then turn to the previously unsolved problem of calculating the moment generating function of the mutual information of MIMO channels, which are correlated at both the receiver and the transmitter. From this moment generating function we obtain the ergodic average of the mutual information and study the outage probability. These methods can be applied to a number of other problems. As a particular example, we examine unitary encoded space-time transmission of MIMO systems and we derive the received signal distribution when the channel matrix is correlated at the transmitter end.
simon.pdf
235.91 KB, 下载次数: 15
举报
发表于 2009-3-11 15:40:39 | 只看该作者
RE:Capacity and Character Expansions: Moment Generating Function and Other Exact
Thank you very much,that's good.
举报
站长推荐上一条 2/5 下一条
「工聚四方·创见未来」欧时RS入驻四方维创新中心线下沙龙
查看 »
GMT+8, 2025-4-30 03:58 , Processed in 0.132483 second(s), 21 queries , MemCache On.
