查看: 1764|回复: 0
TY日记
发表于 2014-9-4 10:57:10 | 显示全部楼层 |阅读模式
公司简介:
     深圳市乾盛达科技有限公司为TY中国台湾半导体中国大陆唯一代理商。
TY中国台湾半导体有限公司于2002年成立于新北市,为专业之二、三极管封装厂。目前已通过ISO14001、TS16949及SONY GREEN PARTNER 等认证,产品为二、三极管封裝(SOT23、SOT523、SOT323、SOT23-5、SOT23-6、SOT143、SOT223、SOT89、SOD123、SOD323、SOD523 、SMA、SMB、SMC、0402、0603、0805、1206等等)。
免费服务热线:4008-318-123
QQ611720555
二极管、三极管、电容、电阻、电解、肖特基
2N5491    TO-220    2N5493    TO-220    2N6107    TO-220    2N6109    TO-220
2N6130    TO-220    2N6292    TO-220    2N6488    TO-220    2N6490    TO-220
2N6491    TO-220    2SA1010    TO-220    2SA1012    TO-220    2SA1069    TO-220
2SA1129    TO-220    2SA1328    TO-220    2SA1726    TO-220    2SA940    TO-220
2SA958    TO-220    2SA968    TO-220    2SB546    TO-220    2SB553    TO-220
2SB595    TO-220    2SB596    TO-220    2SB633    TO-220    2SB682    TO-220
2SB753    TO-220    2SB824    TO-220    2SB825    TO-220    2SB834    TO-220
2SB857    TO-220    2SB859    TO-220    2SB861    TO-220    2SC1061    TO-220
2SC2073    TO-220    2SC2233    TO-220    2SC2238    TO-220    2SC2275    TO-220
2SC2334    TO-220    2SC2336    TO-220    2SC2344    TO-220    2SC2373    TO-220
2SC2562    TO-220    2SC3345    TO-220    2SC4512    TO-220    2SD1061    TO-220
2SD1133    TO-220    2SD1138    TO-220    2SD2023    TO-220    2SD234    TO-220
2SD235    TO-220    2SD288    TO-220    2SD313    TO-220    2SD330    TO-220
2SD362    TO-220    2SD386    TO-220    2SD386A    TO-220    2SD401    TO-220
2SD402    TO-220    2SD475    TO-220    2SD526    TO-220    23D553    TO-220
2SD613    TO-220    2SD613    TO-220    2SD743    TO-220    2SD880    TO-220
BD201    TO-220    BD202    TO-220    BD239    TO-220    BD240    TO-220
BD241C    TO-220    BD242C    TO-220    BD243A    TO-220    BD243B    TO-220
BD243C    TO-220    BD244A    TO-220    BD244B    TO-220    BD244C    TO-220
BD277    TO-220    BD537    TO-220    BD538    TO-220    BD539    TO-220
BD539A    TO-220    BD539B    TO-220    BD539C    TO-220    BD544    TO-220
BD544A    TO-220    BD544B    TO-220    BD544C    TO-220    BD710    TO-220
BD711    TO-220    BD809    TO-220    BD810    TO-220    BD908    TO-220
BD910    TO-220    BD911    TO-220    BD912    TO-220    BD935    TO-220
BD941    TO-220    D44H10    TO-220    D44H11    TO-220    D44H8    TO-220
D44VH10    TO-220    D45C12    TO-220    D45H10    TO-220    D45H11    TO-220
D45H8    TO-220    D45VH10    TO-220    H1061    TO-220    MJE2955T TO-220
TIP29C    TO-220    TIP30C    TO-220    TIP31C    TO-220    TIP32C    TO-220
TIP41C    TO-220    TIP42C    TO-220    IRF630    TO-220    IRF634    TO-220
IRF640    TO-220    IRF730    TO-220    IRF740    TO-220    IRF830    TO-220
IRF840    TO-220    IRFZ44    TO-220    50N06    TO-220    60N06    TO-220
MBR10100CT    TO-220    MBR20100CT    TO-220    MBR30100CT    TO-220
TIC216M    TO-220    TIC246N    TO-220    2P4M    TO-220    BT134    TO-220
BT136    TO-220    BT137    TO-220    BT138    TO-220    BT139    TO-220
BT151    TO-220    BTA08    TO-220    BTA12    TO-220    BTA16    TO-220
BTB04    TO-220    BTB06    TO-220    BTB08    TO-220    2N2219    TO-220
BC140-10    TO-220    BC161    TO-220    2N2102    TO-220
2N2905A    TO-220
CDRH6D28-22UH贴片功率电感    TY
SDRH6D28-22UH贴片功率电感    TY
CDRH127-33UH额定电流3A大功率电感器    TY
CDRH8D43-33UH贴片功率电感器     TY
功率电感CDRH6D38-22UH    TY
功率电感CDRH6D38-100UH(直径7MM,高度3.8MM)     TY
CD75-33UH(直径7.8MM,高度5.0MM)大功率电感线圈     TY
CD75-10UH大功率电感器     TY
CD31-100UH贴片功率电感线圈(直径3.5MM,高度1.6MM)     TY
直插式工字电感线圈SP0406-47UH     TY
直插式工字电感器SP0406-100UH     TY    CDRH6D38-4.7UH贴片功率电感     TY
SDRH6D38-4.7UH贴片功率电感     TY    CDRH6D38-10UH贴片功率电感     TY
SDRH6D38-10UH贴片功率电感     TY    CDRH104R-68UH贴片功率电感器     TY
CDRH8D43-22UH贴片功率电感器     TY    大功率贴片电感器CDRH73-100UH     TY
贴片电感CDRH6D28-100UH(直径7MM,高度2.8MM)     TY
功率电感CDRH6D28-15UH(直径7MM,高度2.8MM)     TY
CDRH5D28-10UH(直径6MM,高度2.8MM)大功率电感器     TY
CDRH4D28-100UH(直径5MM,高度2.8MM)大功率电感线圈     TY
CD1054-33UH电感(直径10MM,高度5.4MM)功率电感线圈     TY
大功率贴片电感器CDRH74-47UH     TY
CD53-10UH大功率电感器     TY
CD1054-10UH电感(直径10MM,高度5.4MM)功率电感器     TY
CD54-220UH额定电流0.35A     TY
CD43-100UH贴片大功率电感器     TY
CD31-47UH贴片功率电感线圈(直径3.5MM,高度1.6MM)     TY
CDRH5D28-100UH(直径6MM,高度2.8MM)大功率电感器     TY
CD75-100UH大功率电感器     TY    CD75-47UH大功率电感器     TY
CD75-220UH电感贴片电感     TY    CD43-10UH贴片大功率电感线圈     TY
CDRH104R-22UH    TY    CDRH8D43-47UH贴片功率电感     TY
CDRH104R-10UH贴片功率电感     TY    直插式工字电感器SP0810-1MH     TY
直插式工字电感线圈SP0608-47UH     TY    CDRH127-22UH额定电流3.6大功率电感器     TY
大功率电感器CD1054-22UH     TY    CD54-22UH贴片电感器     TY
贴片功率电感器CD43-47UH     TY    CDRH3D16-100UH贴片功率电感     TY
CDRH6D28-2.2UH贴片功率电感     TY    CDRH4D18-68UH贴片功率电感     TY
CDRH5D18-22UH贴片功率电感     TY    贴片功率电感CDRH3D16-6.8UH     TY
CDRH6D28-220UH贴片功率电感     TY    CDRH4D18-22UH贴片功率电感     TY
贴片电感CDRH4D18-33UH     TY    功率电感器CDRH3D16-3.3UH     TY
直插功率电感SP0912-100UH    TY    直插功率电感SP0912-10UH     TY
CDRH6D38-2.2UH贴片功率电感     TY    CDRH5D18-6.8UH贴片功率电感     TY
CDRH6D28-100UH贴片功率电感     TY    贴片电感CDRH4D18-6.8UH     TY
CDRH104R-2.2UH贴片功率电感器     TY    CDRH104R-6.8UH贴片功率电感器     TY
CDRH104R-4.7UH贴片功率电感器     TY    直插功率电感SP0912-220UH     TY
CD75-22UH(7.8*7.2*5.0)     TY    一体成型大电流电感器0603-3R3M     TY
不带罩DO1608C-4R7M(0402-4.7UH)    TY    CDRH8D43-10UH贴片功率电感器     TY
直插功率电感SP0912-1000UH    TY    直插功率电感SP0912-22UH    TY
直插功率电感SP0912-33UH    TY    CDRH104R-33UH贴片功率电感器     TY
CDRH8D43-100UH贴片功率电感器     TY    CDRH8D43-2.2UH贴片功率电感器     TY
CDRH104R-220UH贴片功率电感器     TY    CDRH8D43-4.7UH贴片功率电感器     TY
原装台庆大电流电感SMPI 1205HW-6R8M     TY    原装台庆大电流电感SMPI 1004HW-1R5M     TY
原装台庆大电流电感SMPI 1004HW-5R6M     TY    原装台庆大电流电感SMPI 0603HW-1R5M     TY
原装TAI-TECH大电流电感SMPI 0603HW-3R3M     TY    原装台庆大电流电感SMPI 0603HW-4R7M     TY
原装台庆大电流电感SMPI 0603HW-2R2M     TY    大功率贴片电感器CDRH74-100UH     TY
CDRH74-10UH功率电感器     TY    CDRH7045-10UH功率电感器     TY
CD31-122M(CD3516-1.22MH贴片功率电感)     TY
CDRH5D28-22UH(直径6MM,高度2.8MM)大功率电感器     TY
CDRH5D18-4.7UH(直径6MM,高度1.8MM)大功率电感器     TY
CDRH5D28-2.2UH(直径6MM,高度2.8MM)大功率电感器     TY
CDRH5D18-2.2UH(直径6MM,高度1.8MM)大功率电感器     TY
CDRH4D28-4.7UH功率电感     TY
CDRH4D28-2.2UH贴片功率电感     TY
CDRH4D18-100UH(直径5MM,高度1.8MM)额定电流0.2A     TY
CDRH4D18-10UH(直径5MM,高度1.8MM)电感线圈电感器     TY
CDRH4D18-4.7UH(直径5MM,高度1.8MM)电感器     TY
CDRH4D18-2.2UH(直径5MM,高度1.8MM)大功率电感器     TY
CDRH3D16-22UH(直径4MM,高度1.6MM)大功率电感器     TY
大功率电感器CDRH3D16-10UH(直径4MM,高度1.6MM)     TY
CD53-47UH贴片大功率电感器     TY
CD42-4.7UH额定电流1.4A贴片功率电感器     TY
CD1040-10UH(直径10MM,高度4.0MM)大功率电感线圈     TY
CD75-470UH电感(直径7.8MM,高度5.0MM)贴片电感器     TY
CD75-4.7UH(直径7.8MM,高度5.0MM)额定电流4A电感器     TY
CD54-33UH贴片大功率电感器     TY
CD54-10UH贴片大功率电感器     TY
CD54-2.2UH大功率电感线圈     TY
CD32-47UH贴片功率电感器     TY
原装台庆大电流电感SMPI 1207HW-1R5M     TY
原装台庆大电流电感SMPI 1004HW-6R8M     TY
原装台庆大电流电感SMPI 1004HW-R30M     TY
原装台庆大电流电感SMPI 1004HW-100M     TY
大功率贴片电感器CDRH73-22UH     TY
大功率贴片电感器CDRH73-47UH     TY
大功率贴片电感器CDRH74-220UH     TY
CDRH5D28-470UH(直径6MM,高度2.8MM)大功率电感器     TY
CDRH5D28-33UH(直径6MM,高度2.8MM)大功率电感器     TY
CDRH5D18-10UH(直径6MM,高度1.8MM)大功率电感器     TY
CDRH4D28-33UH(直径5MM,高度2.8MM)大功率电感线圈     TY
CDRH4D28-68UH(直径5MM,高度2.8MM)大功率电感线圈     TY
CDRH4D18-47UH(直径5MM,高度1.8MM)电感器     TY
CDRH3D16-4.7UH功率电感器     TY
CD42-47UH大功率电感器     TY
CD1054-100UH(直径10MM,高度5.4MM)大功率贴片电感器     TY
CD54-68UH贴片大功率电感器     TY    CD54-4.7UH贴片大功率电感     TY
CD43-220UH额贴片大功率电感器     TY
CD43-33UH(直径4.5MM,高度3.2MM)贴片大功率电感器     TY
CD43-2.2UH(直径4.5MM,高度3.2MM)贴片大功率电感线圈     TY
CD32-220UH贴片功率电感器     TY
CD32-100UH贴片功率电感器(直径3.5MM,高度2.1MM)     TY
CD31-22UH贴片功率电感器(直径3.5MM,高度1.6MM)     TY
原装台庆大电流电感SMPI 1207HW-1R0M     TY
原装台庆大电流电感SMPI 1207HW-8R0M     TY
原装台庆大电流电感SMPI 1004HW-1R0M     TY
CDRH74-22UH SMD功率电感器     TY
CDRH74-4.7UH贴片功率电感器     TY
CDRH6D28-10UH(直径7MM,高度2.8MM)大功率电感器     TY
CDRH5D28-220UH(直径6MM,高度2.8MM)大功率电感器     TY
CDRH6D28-4.7UH贴片电感(直径7MM,高度2.8MM)     TY
CDRH4D28-220UH(直径5MM,高度2.8MM)大功率电感器     TY
CDRH4D28-47UH(直径5MM,高度2.8MM)大功率电感器     TY
CDRH6D28-22UH(直径7MM,高度2.8MM)大功率电感线圈     TY
CDRH6D28-47UH(直径7MM,高度2.8MM)大功率电感线圈     TY
CDRH5D28-47UH(直径6MM,高度2.8MM)大功率电感线圈     TY
CDRH5D28-4.7UH(直径6MM,高度2.8MM)大功率电感线圈     TY
CDRH5D18-47UH(直径6MM,高度1.8MM)大功率电感线圈     TY
CDRH4D28-470UH(直径5MM,高度2.8MM)大功率电感器     TY
CDRH4D28-10UH大功率电感器     TY
CDRH4D28-22UH(直径5MM,高度2.8MM)大功率电感器     TY
CDRH3D16-47UH(直径4MM,高度1.6MM)大功率电感线圈     TY
CDRH3D16-2.2UH(直径4MM,高度1.6MM)大功率电感线圈     TY
CD1054-220UH(直径10MM,高度5.4MM)大功率贴片电感器     TY
CD54-100UH额定电流0.52A贴片功率电感器     TY
CD54-6.8UH(直径5.8MM,高度4.5MM)贴片大功率电感器     TY
CD43-4.7UH贴片大功率电感器     TY
CD1054-330UH(直径10MM,高度5.4MM)大功率电感器     TY
CD1054-47UH(直径10MM,高度5.4MM)大功率贴片电感器     TY
CD31-2.2UH贴片功率电感器(直径3.5MM,高度1.6MM)     TY
CD32-4.7UH贴片功率电感线圈(直径3.5MM,高度2.1MM)     TY
电感CD73-47UH特价现货供应     TY
批量订做0520-2R2M一体成型大电流电感器     TY
批量订做0402-1R0M一体成型大电流电感线圈     TY
批量订做0402-1R5M一体成型大电流电感器     TY
批量订做0402-2R2M一体成型大电流电感器     TY
量订做0520-1R0M一体成型大电流电感线圈     TY
批量订做0520-6R8M大电流电感器     TY
批量订0520-3R3M一体成型大电流电感器     TY
特价订做0520-4R7M一体成型大电流电感线圈     TY
批量订做0520-5R6M一体成型大电流电感线圈     TY
台庆大电流电感SMPI 1354P3-4R7M     TY    (BUJEON)BDS-3412E-681MH-CO电感器     TY
进口超薄SDR5010-6R8M     TY    进口超薄SDR5010-100M     TY
进口超薄SDR5010-4R7M     TY    国产订做DV0630     TY
RH1608C-1UH大功率贴片电感器     TY    RH1608-6.8UH大功率贴片电感器     TY
RH1608-22UH大功率贴片电感线圈     TY    RH1608C-22UH大功率贴片电感器     TY
RH1608-470UH大功率贴片电感线圈     TY    CDRH104R-47UH电感器     TY
CDRH104R-100UH电感    TY    CDRH105R-10UH    TY
RH6028-4.7UH大功率贴片电感器     TY    CDRH103R-100UH    TY
RH6028-150UH大功率贴片电感器     TY    RH6028-330UH大功率贴片电感器     TY
CDRH74B-100UH     TY    直插式工字电感SP1016-100UH电感线圈     TY
直插式工字电感器SP0810-2.2MH     TY    直插式工字电感器SP0912-150UH     TY
直插式工字电感器SP0912-330UH     TY    直插式工字电感线圈SP0912-33UH     TY
直插式工字电感SP0810-470UH     TY    直插式工字电感器SP1016-330UH     TY
直插式工字电感SP0810-150UH     TY    直插式工字电感线圈SP0912-47UH     TY
直插式工字电感SP0810-330UH     TY    直插式工字电感SP0810-22UH     TY
直插式工字电感SP0810-220UH     TY    直插式工字电感器SP0406-330UH     TY
直插式工字电感线圈SP0608-22UH     TY    直插式工字电感器SP0608-100UH     TY
直插式工字电感器SP0608-10UH     TY    直插式工字电感SP0608-15UH     TY
直插式工字电感SP0810-100UH     TY    直插式工字电感SP0810-47UH     TY
直插式工字电感器SP0608-470UH     TY    直插式工字电感SP0406-22UH     TY
直插式工字电感SP0810-10UH     TY    直插式工字电感器SP0608-1MH     TY
直插式工字电感器SP0406-220UH     TY    直插式工字电感线圈SP0608-150UH     TY
直插式工字电感SP0406-15UH     TY    直插式工字电感SP0406-10UH     TY
RH3316-3.3UH     TY    DRH124-100UH额定电流1.2A大功率电感器     TY
CDRH125-470UH额定电流0.58A大功率电感器     TY    CDRH124-33UH额定电流2.7A大功率电感器     TY
CDRH125-68UH额定电流1.5A大功率电感器     TY    CDRH125-330UH额定电流0.68A大功率电感器     TY
CDRH125-150UH额定电流1A大功率电感器     TY    CDRH125-100UH额定电流1.3A大功率电感器     TY
CDRH125-10UH额定电流4A大功率电感器     TY    CDRH125-22UH额定电流2.8A大功率电感器     TY
CDRH125-3.3UH额定电流8A大功率电感器     TY    CDRH125-4.7UH额定电流4.6A大功率电感器     TY
CDRH127-330UH额定电流0.95A大功率电感器     TY    CDRH125-2.2UH额定电流7.8A大功率电感器     TY
CDRH127-470UH额定电流0.79A大功率电感器     TY    CDRH127-150UH功率电感器     TY
CDRH125-220UH额定电流0.8A大功率电感器     TY    CDRH125-33UH额定电流2.1A大功率电感器     TY
CDRH125-15UH额定电流3.3A大功率电感器     TY    CDRH125-47UH大功率电感器     TY
CDRH127-68UH额定电流2.1A大功率电感器     TY    CDRH127-220UH额定电流1.16A大功率电感器     TY
CDRH127-3.3UH额定电流6.6A大功率电感器     TY    CDRH127-2.2UH额定电流8A大功率电感器     TY
CDRH127-10UH额定电流5.4A大功率电感器     TY    CDRH127-6.8UH额定电流6.6A大功率电感器     TY
CDRH127-47UH额定电流2.5A大功率电感器     TY    CDRH127-15UH功率电感器     TY
CDRH127-4R7额定电流6.8A大功率电感器     TY    MP3,MP4常用电感器CD32-10UH(不印字不编带)     TY
CD32-2.2UH大功率贴片电感器(直径3.5MM,高度2.1MM)     TY
CD31-3.3UH大功率贴片电感器(直径3.5MM,高度1.6MM)     TY
大功率电感器CD31-10UH(直径3.5MM,高度1.6MM)     TY    CD43-22UH额定电流0.76A电感     TY
CD32-22UH额定电流0.63A     TY    工作电流9安,饱和电流16安1205-10UH特大电流贴片电感器     TY
工作电流10安,饱和电流18安1205-8.2UH特大电流贴片电感器     TY
工作电流11安,饱和电流21安1205-6.8UH特大电流贴片电感器     TY
供应工作电流12安,饱和电流22安1205-5R6特大电流电感器     TY
供应工作电流12安,饱和电流27安1205-4R7特大电流电感器     TY
供应工作电流15安,饱和电流32安1205-3.3UH特大电流电感器     TY
供应工作电流17安,饱和电流32安1205-2.2UH特大电流电感器     TY
供应工作电流19安,饱和电流40安1205-1.8UH特大电流电感器     TY
供应工作电流23安,饱和电流48安1205-1R5特大电流电感器     TY
特价供应特电电流12X12X5-1R2,工作电流25A饱和电流48A     TY
特价供应特电电流12X12X5-1R0,工作电流29A饱和电流49A电感器     TY
供应一体成型特大电流1205-R68(工作电流34A,饱和电流54A)     TY
供应工作电流36安,饱和电流55安1205-R56特大电流电感线圈     TY
供应特大电流1205-R33(工作电流42A,饱和电流80A)电感器     TY
特价供应特电电流12X12X5-R22,工作电流51A     TY
特价供应特电电流12X12X5-R10,工作电流15A     TY
特价供应大电流电感器SD0603-10UH,工作电流3A     TY
特价供应特大电流电感器DS0603-8.2U,电流4A     TY
特价供应特大电流电感器SD0603-6.8UH     TY
特价供应特大电流电感线圈SD0603-4.7UH,工作电流4.8安     TY
特价供应SD0603-2.2UH,特大工作电流6.8安大功率电感器     TY
特价供应大电流电感0603-1R5,工作电流7.7安电感线圈     TY
价供应特大电流电感SD0603-1UH,工作电流9.5A     TY
特价供应SD0603-0.68UH特大工作电流12.6A电感     TY
供应特大电流SD1004-10UH(工作电流2.5A,饱和电流5.5A)电感器     TY
供应特大电流SD1004-1.5uh(工作电流12A,饱和电流19A)电感器     TY
供应特大电流SD1004-8.2UH(工作电流5A,饱和电流7A)电感线圈     TY
供应特大电流SD1004-6R8(工作电流7A,饱和电流10A)电感器     TY
供应特大电流SD1004-4.7UH(工作电流8A,饱和电流13A)电感器     TY
供应特大电流SD1004-3R3(工作电流10A,饱和电流14A)电感器     TY
供应特大电流SD1004-2.2uh(工作电流11A,饱和电流17A)电感线圈     TY
供应特大电流SD1004-1uh(工作电流19A,饱和电流25A)电感器     TY
供应特大电流SD1004-0.68uh(工作电流22A,饱和电流330A)电感     TY
物价供应线艺74B-10UH大功率电感器     TY
供应工作电流38安,饱和电流65安1205-R47大电流电感     TY
贴片功率电感器:2D11-10UH     TY
贴片功率电感:CD32-10UH(直径3.5MM,高度2.1MM)     TY
贴片电感:6028-100UH     TY
CD31-4.7UH功率贴片电感(直径3.5MM,高度1.6MM)     TY
CDRH2D14-10UH功率贴片电感器     TY    CD54-47UH功率贴片电感     TY
CDRH3316-3.3UH功率贴片电感器     TY    CDRH3316-2.2UH功率贴片电感器     TY
CDRH5022-330UH功率贴片电感     TY    CDRH127-100UH贴片电感器     TY
CDRH53LB-10UH功率贴片电感     TY    CDRH104R-15UH     TY
GMT+8, 2024-12-28 19:02 , Processed in 0.109345 second(s), 15 queries , MemCache On.
