查看: 1216|回复: 0
TMS320F28335_ADEXAMPLE
发表于 2013-1-15 10:48:22 | 显示全部楼层 |阅读模式
#include "DSP2833x_Device.h"     // DSP2833x Headerfile Include File
#include "DSP2833x_Examples.h"   // DSP2833x Examples Include File
// Determine when the shift to right justify the data takes place
// Only one of these should be defined as 1.
// The other two should be defined as 0.
#define POST_SHIFT   0  // Shift results after the entire sample table is full
#define INLINE_SHIFT 1  // Shift results as the data is taken from the results regsiter
#define NO_SHIFT     0  // Do not shift the results
#define LED (*(unsigned short int *)0x180000)
TMS320F28335_ADEXAMPLE.pdf
396.57 KB, 下载次数: 5
GMT+8, 2024-12-25 21:17 , Processed in 0.130162 second(s), 17 queries , MemCache On.
