查看: 3872|回复: 3
定位ARM Hard Fault 的方法(转)
    擦汗
    2014-2-12 10:49
  • 签到天数: 150 天
    [LV.7]常住居民III
    发表于 2013-8-28 09:54:47 | 显示全部楼层 |阅读模式
    为了定位ARM Hard Fault 可以说是愁的不行,看书、上网搜、论坛求助、群里询问。。。能想到的办法都做了,就是有点地方被绊住,就结了好几天了,一个偶然的机会看到了这个,心理说不出的激动。
    大家一起看看吧,相信对大家也会有很大的帮助。
    1,  用Keil的话,可以这样:
    先将fault中断函数的内容改为:
    HardFault_Handler\
                    PROC
                    ;EXPORT  HardFault_Handler         [WEAK]
                    ;B                  .
                                    IMPORT hard_fault_handler_c
                                    TST LR, #4
                                    ITE EQ
                                    MRSEQ R0, MSP
                                    MRSNE R0, PSP
                                    B hard_fault_handler_c
                    ENDP
    然后在源程序里添加下面的函数代码:
    // hard fault handler in C,
    // with stack frame location as input parameter
    void hard_fault_handler_c(unsigned int * hardfault_args)
    unsigned int stacked_r0;
    unsigned int stacked_r1;
    unsigned int stacked_r2;
    unsigned int stacked_r3;
    unsigned int stacked_r12;
    unsigned int stacked_lr;
    unsigned int stacked_pc;
    unsigned int stacked_psr;
    stacked_r0 = ((unsigned long) hardfault_args[0]);
    stacked_r1 = ((unsigned long) hardfault_args[1]);
    stacked_r2 = ((unsigned long) hardfault_args[2]);
    stacked_r3 = ((unsigned long) hardfault_args[3]);
    stacked_r12 = ((unsigned long) hardfault_args[4]);
    stacked_lr = ((unsigned long) hardfault_args[5]);
    stacked_pc = ((unsigned long) hardfault_args[6]);
    stacked_psr = ((unsigned long) hardfault_args[7]);
    printf ("[Hard fault handler]\n");
    printf ("R0 = %x\n", stacked_r0);
    printf ("R1 = %x\n", stacked_r1);
    printf ("R2 = %x\n", stacked_r2);
    printf ("R3 = %x\n", stacked_r3);
    printf ("R12 = %x\n", stacked_r12);
    printf ("LR = %x\n", stacked_lr);
    printf ("PC = %x\n", stacked_pc);
    printf ("PSR = %x\n", stacked_psr);
    printf ("BFAR = %x\n", (*((volatile unsigned long *)(0xE000ED38))));
    printf ("CFSR = %x\n", (*((volatile unsigned long *)(0xE000ED28))));
    printf ("HFSR = %x\n", (*((volatile unsigned long *)(0xE000ED2C))));
    printf ("DFSR = %x\n", (*((volatile unsigned long *)(0xE000ED30))));
    printf ("AFSR = %x\n", (*((volatile unsigned long *)(0xE000ED3C))));
    while(1)
    如果使用调试器,则可以在第一个printf处设置断点.没有的话看串口打印结果
    通过查看stacked_lr的内容可以知道程序运行到哪个位置出现fault
    然后查看编译后汇编代码,可以知道源程序是哪个函数哪一步出现问题,
    配合其它寄存器的内容来分析找出原因
    2.用IAR的话,把startup_ewarm.c文件中的FaultISR()函数的内容改为:
    volatile unsigned int stacked_r0;
    volatile unsigned int stacked_r1;
    volatile unsigned int stacked_r2;
    volatile unsigned int stacked_r3;
    volatile unsigned int stacked_r12;
    volatile unsigned int stacked_lr;
    volatile unsigned int stacked_pc;
    volatile unsigned int stacked_psr;
    //unsigned long cc;
      while(1)
    配合其它寄存器的内容来分析找出原因
  • 签到天数: 692 天
    发表于 2013-8-28 10:04:34 | 显示全部楼层
    这个资料必须得顶!在使用DFU选项功能时,经常碰到这个问题,确实找原因麻烦
  • 签到天数: 125 天
    [LV.7]常住居民III
    发表于 2013-8-28 11:23:52 | 显示全部楼层
    这个确实没有遇到过!
    擦汗
    2014-2-12 10:49
  • 签到天数: 150 天
    [LV.7]常住居民III
    发表于 2013-9-11 09:34:56 | 显示全部楼层
    l廖天一阁主 发表于 2013-8-28 11:23
    这个确实没有遇到过!
    总会遇到的
    GMT+8, 2025-1-11 12:43 , Processed in 0.132491 second(s), 20 queries , MemCache On.
