查看: 2342|回复: 3
STM32---FSMC
    擦汗
    2014-8-19 06:31
  • 签到天数: 296 天
    发表于 2013-8-27 22:06:24 | 显示全部楼层 |阅读模式
    求STM32 --FSMC引脚对应的GPIO---跪求大神
    昨天 08:13
  • 签到天数: 4094 天
    连续签到: 49 天
    [LV.Master]伴坛终老
    发表于 2013-8-28 07:06:19 | 显示全部楼层
    Datasheet不是有对应的管脚吗?
  • 签到天数: 692 天
    发表于 2013-8-28 10:08:17 | 显示全部楼层
    1        CS Chip selection input pin: Active "L"         I        FSMC_NE1        PD7
    2        RS LCD registor selector                        I        FSMC_A16        PD11
    3        WR Write signal                                 I        FSMC_NWE        PD5
    4        RD Read signal                                         I        FSMC_NOE        PD4
    5        RESET Reset signal: Active “L”                 I        GPIO                PE2
    6        DB00 Data Bus                                         I/O        FSMC_D0                PD14
    7        DB01 Data Bus                                         I/O        FSMC_D1                PD15
    8        DB02 Data Bus                                                I/O        FSMC_D2                PD0
    9        DB03 Data Bus                                         I/O        FSMC_D3                PD1
    10        DB04 Data Bus                                         I/O        FSMC_D4                PE7
    11        DB05 Data Bus                                         I/O        FSMC_D5                PE8
    12        DB06 Data Bus                                         I/O        FSMC_D6                PE9
    13        DB07 Data Bus                                         I/O        FSMC_D7                PE10
    14        DB08 Data Bus                                         I/O        FSMC_D8                PE11
    15        DB09 Data Bus                                         I/O        FSMC_D9                PE12
    16        DB10 Data Bus                                         I/O        FSMC_D10        PE13
    17        DB11 Data Bus                                         I/O        FSMC_D11        PE14
    18        DB12 Data Bus                                         I/O        FSMC_D12        PE15
    19        DB13 Data Bus                                         I/O        FSMC_D13        PD8
    20        DB14 Data Bus                                         I/O        FSMC_D14        PD9
    21        DB15 Data Bus                                         I/O        FSMC_D15        PD10
    擦汗
    2014-8-19 06:31
  • 签到天数: 296 天
     楼主| 发表于 2013-8-28 19:19:44 | 显示全部楼层
    2        RS LCD registor selector                        ...
    多谢----------------------------------------------
    GMT+8, 2025-1-26 07:58 , Processed in 0.144368 second(s), 21 queries , MemCache On.
