查看: 9184|回复: 27
使用NXP COG PCA8538显示点阵:".EEBOARD.COM"
  • 签到天数: 257 天
    发表于 2013-8-27 03:43:29 | 显示全部楼层 |阅读模式
    RT:使用NXP COG PCA8538显示:".EEBOARD.COM"
    看了好几个小时的PCA8538资料,发现下边的点阵区域,其实就是点阵显示而已,找到规律,设置为1:8 MUX,直接一个竖线代表一个显示的RAM的字节。于是显示个字符串吧,当然选择的是:“。EEBOARD。COM“;
    核心程序如下:
    //w(0) w(1) w(2) .(3) e(4) e(5) b(6) o(7) a(8) r(9) d(10) .(11)
    unsigned char eeb[100]=
    {0xFF,0xFF,0xFF,0xFD,0xFD,0xFF,0xFF,0xFF,/*".",0*/
    0xFF,0x81,0xAD,0xAD,0xAD,0xAD,0xAD,0xBD,/*"E",1*/
    0xFF,0x81,0xAD,0xAD,0xAD,0xAD,0xAD,0xBD,/*"E",2*/
    0xFF,0x81,0xAD,0xAD,0xAD,0xAD,0xD3,0xFF,/*"B",3*/
    0xFF,0xC3,0x99,0xBD,0xBD,0x99,0xC3,0xFF,/*"O",4*/
    0xFD,0xF3,0xE7,0x97,0x97,0xE7,0xF3,0xFD,/*"A",5*/
    0xFF,0x81,0xB7,0xB7,0xB7,0xB7,0xC1,0xFF,/*"R",6*/
    0xFF,0x81,0xBD,0xBD,0xBD,0x99,0xC3,0xFF,/*"D",7*/
    0xFF,0xFF,0xFF,0xFD,0xFD,0xFF,0xFF,0xFF,/*".",8*/
    0xFF,0xC3,0x99,0xBD,0xBD,0xBD,0xD3,0xFF,/*"C",9*/
    0xFF,0xC3,0x99,0xBD,0xBD,0x99,0xC3,0xFF,/*"O",10*/
    0xFF,0x81,0x87,0xF9,0xF1,0xCF,0x81,0xFF};/*"M",11*/
      while(1)
       GPIO_ResetBits(GPIOA, GPIO_Pin_4);//选中 cs
       temp = SPI1_RWByte(0x20);
       temp = SPI1_RWByte(0x80);
       temp = SPI1_RWByte(0x3a);
       temp = SPI1_RWByte(0xd8);
       temp = SPI1_RWByte(0x18);
       temp = SPI1_RWByte(0xd4);
       temp = SPI1_RWByte(0xc9);
       temp = SPI1_RWByte(0x45);
       temp = SPI1_RWByte(0x73);
       temp = SPI1_RWByte(0x00);
       temp = SPI1_RWByte(0xd3);//1:8 mux   //d0
       temp = SPI1_RWByte(0xb4);//b3
       temp = SPI1_RWByte(0x39);
       temp = SPI1_RWByte(0x90);
       temp = SPI1_RWByte(0xa0);
       for(i=0;i<96;i++)temp = SPI1_RWByte(eeb);
       GPIO_SetBits(GPIOA, GPIO_Pin_4);//不选中 cs
       delay(1);
       delay(1);
       break;
    显示效果如下:
    评分
    参与人数 2声望 +10 与非币 +20 收起 理由
    GY@艳 + 5 + 10 很给力!
    小菜儿 + 5 + 10 很给力!
    查看全部评分
    昨天 10:14
  • 签到天数: 4089 天
    连续签到: 44 天
    [LV.Master]伴坛终老
    发表于 2013-8-27 06:53:28 | 显示全部楼层
    可以显示点阵,谢谢分享!
  • 签到天数: 692 天
    发表于 2013-8-27 07:50:55 | 显示全部楼层
    不错哦,顶你一个!{:soso_e100:}
  • 签到天数: 647 天
    发表于 2013-8-27 08:30:08 | 显示全部楼层
    厉害
  • 签到天数: 207 天
    [LV.7]常住居民III
    发表于 2013-8-27 09:01:43 | 显示全部楼层
    厉害,参考一下我也搞定了。谢谢,嘿嘿
    擦汗
    2021-6-1 08:44
  • 签到天数: 398 天
    连续签到: 2 天
    发表于 2013-8-27 09:25:57 | 显示全部楼层
    这个屏应该翻过来用,那样很多字符就是“正”的了,其实无所谓~~~
    慵懒
    2019-7-13 19:58
  • 签到天数: 1818 天
    [LV.Master]伴坛终老
    发表于 2013-8-27 09:29:43 | 显示全部楼层
    很好的板样,我们努力有了方向
  • 签到天数: 257 天
     楼主| 发表于 2013-8-27 09:56:32 | 显示全部楼层
    hjf2002 发表于 2013-8-27 06:53
    可以显示点阵,谢谢分享!
    呵呵,申请这个东西就是用来分享的嘛
  • 签到天数: 257 天
     楼主| 发表于 2013-8-27 09:59:11 | 显示全部楼层
    可以显示点阵,谢谢分享!
    这个要对照数据手册看的,此前我用过430的LCD驱动,看原理差不多类似的,就是控制字的不同而已。这个明显控制字过多,而且说的有点混乱,耗费我好几个小时去理解。
  • 签到天数: 257 天
     楼主| 发表于 2013-8-27 10:00:37 | 显示全部楼层
    fengye5340 发表于 2013-8-27 07:50
    不错哦,顶你一个!
    你也很厉害嘛,你很早就弄出来了……
    GMT+8, 2025-1-21 00:50 , Processed in 0.213950 second(s), 35 queries , MemCache On.
