查看: 9071|回复: 0
ARM工具链中的概念——EABI
发表于 2012-3-13 16:23:32 | 显示全部楼层 |阅读模式
EABI(Embedded Application Binary Interface),嵌入式应用程序二进制接口。
ABI的定义
ABI描述应用程序与操作系统、应用程序与库、应用程序的组成部分之间的低层接口。ABI允许编译好的目标代码在使用兼容ABI的系统中无需改动就能运行。
EABI的具体定义
Codesourcery上有一个这样的QA:
https://support.codesourcery.com/GNUToolchain/kbentry32
Question
What is the ABI for the ARM Architecture? Is it the same as the ARM EABI?
Answer
The ABI for the ARM Architecture is a standard developed by ARM and  its partners that explains how compilers, assemblers, linkers, and other  similar tools should generate object files and executable files.
Tools that correctly implement the ABI for the ARM Architecture can  interoperate; i.e., object files built with one toolchain can be  combined with object files built with another toolchain if both  compilers use the ABI for the ARM Architecture and provided that the  code compiled observes certain conventions.
CodeSourcery was an active participant in the design of the ABI for  the ARM Architecture. (In fact, the C++ ABI used by ARM is derived from  the Itanium C++ ABI co-designed by CodeSourcery.) CodeSourcery continues  to work with ARM, Ltd. to validate interoperability between Sourcery  G++ and ARM's proprietary tools.
The "ARM EABI" is an informal name for the ABI for the ARM Architecture.
这里提到了所谓的ARM EABI就是针对 ARM 体系结构的应用程序二进制接口的非正式名称
在arm的infocenter可以找到ABI for the ARM architecture的相关文档:
http://infocenter.arm.com/help/index.jsp?topic=/com.arm.doc.subset.swdev.abi/index.html
用于针对ARM体系结构的应用程序二进制接口(ABI)ARM文档集,这些接口包括ARM 过程调用标准(APCS)ARM ELFARM DWARF、基础平台ABI(BPABI)C++ ABI、异常处理ABI、运行时ABICABI
在文档的Terms and abbreviations中有:
AEABI  (Embedded) ABI for the ARM architecture (this ABI…)
也证实了EABI就是Application Binary Interface for the ARM Architecture
EABI的内容
ABI for the ARM architecture是很多规范的合集:
AADWARF      DWARF for the ARM Architecture
AAELF         ELF for the ARM Architecture
AAPCS         Procedure Call Standard for the ARM Architecture
ADDENDA      Addenda to, and errata in, the ABI for the ARM Architecture
BPABI          Base Platform ABI for the ARM Architecture
BSABI          ABI for the ARM Architecture (Base Standard)
CLIBABI        C Library ABI for the ARM Architecture
CPPABI         C++ ABI for the ARM Architecture
EHABI          Exception Handling ABI for the ARM Architecture
EHEGI          Exception handling component specimen implementations
RTABI            Run-time ABI for the ARM Architecture
EABI的作用
EABI的目的是使不同的编译器编译出来的二进制文件可以互相使用(interoperability),比如Codesourcery,  RVCT,  RVDS这些编译器。符合EABI标准编译器编译出的库可以相互链接,这样软件开发人员就可以混合使用不同厂商提供的符合EABI标准的二进制库。
ARM 有助于 GNU 编译器项目,该项目跟踪 ARM 体系结构的发展,并确保为 ARM 提供高质 GNU 工具链。
该工具链支持目前的所有 ARM 体系结构和处理器(包括 Thumb-2 指令集和 ARM 体系结构第 7 版),并计划支持将来的处理器和体系结构。
该工具链符合最新的 ARM 应用程序二进制接口,因此可与 ARM RealView Development Suite 或符合 ABI 的任何其他工具链交互工作。用户可以配合使用 ARM 提供的商用、专业工具链的已优化代码大小与性能以及使用开源工具生成的代码。
可从 CodeSourcery 访问 GNU 编译器的源代码和预置版本,网址为:http://www.codesourcery.com/gnu_toolchains/arm
当然,EABI相对于以前的ABI性能也会改善。
EABI相对于以前的ABI的改进
Differences between v1 and v2 of the ABI for the ARM  Architecture列出了ABI for the ARM Architecture V1和V2两个版本的不同,这里的ABI for the  ARM Architecture V2就是EABI,V1也被称作Old ABI 或者Lagacy ABI。EABI2005年推出的,新是相对于以前的而言,从时间上看其实已经很——所以很多这些所谓的改变,其实现在已经是标准做法了,例如Exception Handling ABI的改进使浮点数的性能的改善,堆栈的8字节对齐,structure packing的改变等等。
GNU EABI
在很多地方有GNU EABI的说法,这是一个不同的ABI吗?
还是Codesourcery上的QA:
http://www.codesourcery.com/sgpp/lite/arm/portal/kbentry38
Question
Why is the configuration name for GNU/Linux arm-none-linux-gnueabi  instead of just arm-none-linux-eabi? Is there a GNU variant of the EABI?
Answer
The Free Software Foundation prefers that configuration names for  GNU/Linux contain both the string linux and the string gnu. The  configuration arm-none-linux-gnu refers to the legacy ARM ABI for  GNU/Linux. Some tools depend on the fact that configuration names have  at most three hyphens, so gnu and eabi were combined into a single word.
The ABI used on GNU/Linux is not a special GNU variant of the EABI; it is just the EABI.
GNU EABI就是EABI,ABI for the ARM architecture。
相关资料
Debian Wiki: ArmEabiPort
http://wiki.debian.org/ArmEabiPort/
Codesourcery上的ARM架构FAQ
http://www.codesourcery.com/sgpp/lite/arm/portal/target_arch?@action=faq&target_arch=arm
Wikipedia上的ABI
http://en.wikipedia.org/wiki/Application_binary_interface
CSDN hongjiujing的总结:ABI/EABI/OABI
http://blog.csdn.net/hongjiujing/archive/2008/07/21/2686556.aspx
EABI对浮点数性能的改善:Why ARM's EABI Matters
http://www.linuxfordevices.com/c/a/Linux-For-Devices-Articles/Why-ARMs-EABI-matters/
GMT+8, 2025-1-10 05:56 , Processed in 0.117889 second(s), 15 queries , MemCache On.
