查看: 3645|回复: 0
W5300,W5100
发表于 2010-8-24 15:48:16 | 显示全部楼层 |阅读模式
Feature-W5300
            - Supports hardwired TCP/IP protocols TCP,UDP, ICMP, IPv4, ARP, IGMPv2, PPPoE, Ethernet
            - Supports 8 independent SOCKETs simultaneously
            - High network performance Up to 80Mbps (DMA)
            - Supports hybrid TCP/IP stack(software and hardware TCP/IP stack)
            - IP Fragmentation is not supported
            - Internal 128Kbytes memory for data communication(Internal TX/RX memory)
            - More flexible allocation internal TX/RX memory according to application throughput
            - Supports memory-to-memory DMA (only 16bit Data bus width & slave mode)
            - Embedded 10BaseT/100BaseTX Ethernet PHY
            - Supports auto negotiation (Full-duplex and half duplex)
            - Supports auto MDI/MDIX(Crossover)
            - Supports network Indicator LEDs (TX, RX, Full/Half duplex, Collision, Link, Speed)
            - Supports a external PHY instead of the internal PHY
            - Supports 16/8 bit data bus width
            - Supports 2 host interface mode(Direct address mode & Indirect address mode)
            - External 25MHz operation frequency (For internal PLL logic, period=40ns)
            - Internal 150MHz core operation frequency (PLL_CLK, period=about 6.67ns)
            - Network operation frequency (NIC_CLK 25MHz(100BaseTX) or 2.5MHz(10BaseT))
            - 3.3V operation with 5V I/O signal tolerance
            - Embedded power regulator for 1.8V core operation
            - 0.18 µm CMOS technology
            - 100LQFP 14X14 Lead-Free Package
             Support S/W TCP/IP Simultaneously
            W5100
Feature
                        - Support Hardwired TCP/IP Protocols TCP, UDP, ICMP, IPv4 ARP, IGMP, PPPoE, Ethernet
                        - 10BaseT/100BaseTX Ethernet PHY embedded
                        - Support Auto Negotiation (Full-duplex and half duplex)
                        - Support Auto MDI/MDIX
                        - Support ADSL connection (with support PPPoE Protocol with PAP/CHAP Authentication mode)
                        - Supports 4 independent sockets simultaneously
                        - Not support IP Fragmentation
                        - Internal 16Kbytes Memory for Tx/Rx Buffers
                        - Small 80 Pin LQFP Package
                        - Lead-Free Package
                        - Support Serial Peripheral Interface(SPI MODE 0, 3)Multi-function LED outputs (TX, RX, Full/Half duplex, Collision, Link, Speed)
W5300E01-ARM_V1 0.pdf
346.18 KB, 下载次数: 5
W5300E01-ARM_V1-2.pdf
310.9 KB, 下载次数: 9
W5100E01-AVR-1.pdf
128.79 KB, 下载次数: 5
W5300W7100.rar
123.47 KB, 下载次数: 8
GMT+8, 2025-1-8 12:10 , Processed in 0.122879 second(s), 17 queries , MemCache On.
