查看: 2750|回复: 0
WIZ220IO
发表于 2010-8-24 15:36:13 | 显示全部楼层 |阅读模式
Webserver based IO control module
Key Features
  - Remote I/O Monitoring and Control with Ethernet
  - 8 Digital Input Ports
  - 8 Digital Output Ports
  - 2 Analog Input Ports (12 bit resolution)
  - 2 Analog Output Ports (12 bit resolution)
  - Supports Application Program
  - Supports WebServer
Specifications
Network Interface
10BaseT/100BaseTX
            Auto Negotiation (Full-duplex and half-duplex)
            Auto MDIX
Digital Input
Input Port 8 ports
            Input Type Voltage
            Low level input voltage -0.5V ~ 0.8V
            High level input voltage 2.0V ~ 5.5V
Digital Output
Output Port 8 ports
            Output Type Voltage
            Low level output voltage MAX 0.4V
            High level output voltage MIN 2.4V
Analog Input
Input Port 2 ports
            Resolution 12-bit
            Input Type Voltage
            Sampling Rate 100ksps
            Input Range 0 ~ 5V
Analog Output
Output Port 2 ports
            Resolution 12-bit
W5100E01-AVR-1.pdf
W5100E01-AVR-1.pdf
128.79 KB, 下载次数: 2
W5300E01-ARM_V1-2.pdf
310.9 KB, 下载次数: 2
W5100E01-AVR-1.pdf
128.79 KB, 下载次数: 2
W7100_ref_sch-20100821.pdf
100.72 KB, 下载次数: 2
GMT+8, 2025-1-8 12:27 , Processed in 0.129971 second(s), 17 queries , MemCache On.
