查看: 2579|回复: 0
How to define Altera EP1C20 to differential output?
发表于 2008-7-16 16:05:11 | 显示全部楼层 |阅读模式
Can every I/O pin be defined to a differential pin? And can any two I/O pins be defined into a pair of differential output pins? Can anyone supply datasheet about the altera EP1C20 application of differential output? Thanks for your attention!
GMT+8, 2024-12-28 09:26 , Processed in 0.119821 second(s), 15 queries , MemCache On.
