All compatible Xilinx Platform USB Cable
True plug-and-play
Bus-powered USB device (no power supply required)
Selectable target clock frequency up to 24 MHz
Compatible with Full-Speed and Hi-Speed USB ports
USB-IF certified
Firmware downloadable over cable
Target power status LED
CE and FCC compliant
Compatible with target voltages in the range of +1.5 VDC to +3.3 VDC
iMPACT and ChipScope support in ISE 6.3.03i (Windows only)
Linux support in ISE 7.1i
Supports Boundary Scan and Slave-Serial configuration modes
SUPPORT:
Virtex Series Spartan Series CoolRunner XC9500 Config FLASH
Virtex-5 Spartan-3A CoolRunner-II XC9500XV Platform Flash
Virtex-4 Spartan-3E CoolRunner XPLA3 XC9500XL XC18Vxx Series
Virtex-II Pro Spartan-IIE XC9500
Virtex-II Spartan-II
Virtex-E Spartan
Virtex
