查看: 3077|回复: 3
STM32之硬件SPI,
  • 签到天数: 15 天
    [LV.4]偶尔看看III
    发表于 2013-8-24 12:33:21 | 显示全部楼层 |阅读模式
    最近起兴在调试硬件的通信接口,因为感觉硬件和软件模拟方式相比优点很明显,具体的不详说了,下面我上传一个百度上的文档,也是我在调试的时候遇到的一个问题,关于NSS端口电平的问题,我将硬件设置好后发现NSS端口一直是低电平,于是出现了无法连续转换数据的大问题。无奈之下百度之后找到原因,原来是单片机的原因啊……之后将NSS端口改为模拟方式控制,于是我我的程序是半硬件半模拟方式了,心碎啊,我也将核心程序贴
    1. #include "stm32f4xx.h"
    2. /** SPI1 GPIO Configuration
    3.                  PA4         ------> SPI1_NSS
    4.                  PA5         ------> SPI1_SCK
    5.                  PA6         ------> SPI1_MISO
    6.                  PA7         ------> SPI1_MOSI
    7.         */
    8. u8 SPIx_ReadWriteByte(u8 TxData);
    9. void spi_init(void)
    10. {
    11.                 GPIO_InitTypeDef GPIO_InitStruct;
    12.                 SPI_InitTypeDef SPI_InitStruct;
    13.                 RCC_AHB1PeriphClockCmd(RCC_AHB1Periph_GPIOA, ENABLE);
    14.                 RCC_APB2PeriphClockCmd(RCC_APB2Periph_SPI1, ENABLE);//spi1时钟使能
    15.         //Enable SCK, MOSI, MISO and NSS GPIO clocks
    16.                 GPIO_InitStruct.GPIO_Pin = GPIO_Pin_4;
    17.                 GPIO_InitStruct.GPIO_Mode = GPIO_Mode_OUT;
    18. //                GPIO_InitStruct.GPIO_OType = GPIO_OType_PP;
    19.                 GPIO_InitStruct.GPIO_PuPd = GPIO_PuPd_NOPULL;
    20.                 GPIO_InitStruct.GPIO_Speed = GPIO_Speed_50MHz;
    21.                 GPIO_Init(GPIOA, &GPIO_InitStruct);
    22.
    23.                 GPIO_InitStruct.GPIO_Pin = GPIO_Pin_5;
    24.                 GPIO_InitStruct.GPIO_Mode = GPIO_Mode_AF;
    25.                 GPIO_InitStruct.GPIO_OType = GPIO_OType_PP;
    26.                 GPIO_InitStruct.GPIO_PuPd = GPIO_PuPd_NOPULL;
    27.                 GPIO_InitStruct.GPIO_Speed = GPIO_Speed_50MHz;
    28.                 GPIO_Init(GPIOA, &GPIO_InitStruct);
    29.         //!!! GPIO_Init is commented because some parameters are missing
    30.                 GPIO_InitStruct.GPIO_Pin = GPIO_Pin_6;
    31.                 GPIO_InitStruct.GPIO_Mode = GPIO_Mode_AF;
    32.                 GPIO_InitStruct.GPIO_OType = GPIO_OType_OD;
    33.                 GPIO_InitStruct.GPIO_PuPd = GPIO_PuPd_NOPULL;
    34.                 GPIO_InitStruct.GPIO_Speed = GPIO_Speed_50MHz;
    35.                 GPIO_Init(GPIOA, &GPIO_InitStruct);
    36.         //!!! GPIO_Init is commented because some parameters are missing
    37.                 GPIO_InitStruct.GPIO_Pin = GPIO_Pin_7;
    38.                 GPIO_InitStruct.GPIO_Mode = GPIO_Mode_AF;
    39.                 GPIO_InitStruct.GPIO_OType = GPIO_OType_PP;
    40.                 GPIO_InitStruct.GPIO_PuPd = GPIO_PuPd_NOPULL;
    41.                 GPIO_InitStruct.GPIO_Speed = GPIO_Speed_50MHz;
    42.                 GPIO_Init(GPIOA, &GPIO_InitStruct);
    43.
    44.                 /*Configure GPIO pin alternate function */
    45. //                GPIO_PinAFConfig(GPIOA, GPIO_PinSource4, GPIO_AF_SPI1);
    46.
    47.                 /*Configure GPIO pin alternate function */
    48.                 GPIO_PinAFConfig(GPIOA, GPIO_PinSource5, GPIO_AF_SPI1);
    49.                 /*Configure GPIO pin alternate function */
    50.                 GPIO_PinAFConfig(GPIOA, GPIO_PinSource6, GPIO_AF_SPI1);
    51.                 /*Configure GPIO pin alternate function */
    52.                 GPIO_PinAFConfig(GPIOA, GPIO_PinSource7, GPIO_AF_SPI1);
    53.
    54.
    55.                 SPI_InitStruct.SPI_Direction=SPI_Direction_2Lines_FullDuplex;//双向双线全双工
    56.                 SPI_InitStruct.SPI_Mode=SPI_Mode_Master;//主机模式
    57.                 SPI_InitStruct.SPI_DataSize = SPI_DataSize_8b;//8帧数据结构
    58.                 SPI_InitStruct.SPI_CPOL = SPI_CPOL_High;//时钟悬空高
    59.                 SPI_InitStruct.SPI_CPHA = SPI_CPHA_2Edge;//在第二个时钟捕获
    60.                 SPI_InitStruct.SPI_NSS = SPI_NSS_Soft;//软件控制CS
    61.                 SPI_InitStruct.SPI_BaudRatePrescaler = SPI_BaudRatePrescaler_256;//波特率分频256
    62.                 SPI_InitStruct.SPI_FirstBit = SPI_FirstBit_MSB;//从高位开始
    63.                 SPI_InitStruct.SPI_CRCPolynomial = 7;//计算的多项式
    64.                 SPI_Init(SPI1,&SPI_InitStruct);
    65.                 SPI_Cmd(SPI1, ENABLE);
    66.                 SPIx_ReadWriteByte(0xff);
    67. }
    68. //SPIx 写入一个数据
    69. //TxData:要写入的字节
    70. //返回值:读取到的字节
    71. u8 SPIx_ReadWriteByte(u8 TxData)
    72. {
    73.         u8 retry=0;
    74.         while (SPI_I2S_GetFlagStatus(SPI1, SPI_I2S_FLAG_TXE) == RESET)//发送缓存空标志位
    75.                 {
    76.                 retry++;
    77.                 if(retry>200)return 0;
    78.                 }
    79.         SPI_I2S_SendData(SPI1, TxData); //通过外设SPI发送
    80.         retry=0;
    81.         while (SPI_I2S_GetFlagStatus(SPI1, SPI_I2S_FLAG_RXNE) == RESET)//接收缓存空标志位
    82.                 {
    83.                 retry++;
    84.                 if(retry>200)return 0;
    85.                 }
    86.         return SPI_I2S_ReceiveData(SPI1); //通过spi接收的数据
    87. }
    上来了,请大家拍砖!
    STM32_SPI_NSS问题(二篇文章).pdf
    162.22 KB, 下载次数: 12
  • 签到天数: 15 天
    [LV.4]偶尔看看III
     楼主| 发表于 2013-8-24 12:34:48 | 显示全部楼层
    我是用的TPL0501数字电位能否正确转换作为是否通信成功的标志
  • 签到天数: 309 天
    发表于 2013-8-24 13:49:03 | 显示全部楼层
    好像NSS就是没办法自动拉高,ST的官方例程中没有用到硬件的NSS,看来只能软件解决了
  • 签到天数: 15 天
    [LV.4]偶尔看看III
     楼主| 发表于 2013-8-24 14:13:37 | 显示全部楼层
    qrs_yrj 发表于 2013-8-24 13:49
    好像NSS就是没办法自动拉高,ST的官方例程中没有用到硬件的NSS,看来只能软件解决了 ...
    恩恩   是的   我改进的就是用的软件方式
    GMT+8, 2025-2-6 00:11 , Processed in 0.139884 second(s), 22 queries , MemCache On.
