查看: 2806|回复: 0
C语言宏定义技巧
发表于 2007-8-12 09:56:25 | 显示全部楼层 |阅读模式
写好C语言,漂亮的宏定义很重要,使用宏定义可以防止出错,提高可移植性,可读性,方便性 等等。下面列举一些成熟软件中常用得宏定义。。。。。。
1,防止一个头文件被重复包含
#ifndef COMDEF_H
#define COMDEF_H
  //头文件内容
#endif
2,重新定义一些类型,防止由于各种平台和编译器的不同,而产生的类型字节数差异,方便移植。
typedef  unsigned char      boolean;     /* Boolean value type. */
typedef  unsigned long int  uint32;      /* Unsigned 32 bit value */
typedef  unsigned short     uint16;      /* Unsigned 16 bit value */
typedef  unsigned char      uint8;       /* Unsigned 8  bit value */
typedef  signed long int    int32;       /* Signed 32 bit value */
typedef  signed short       int16;       /* Signed 16 bit value */
typedef  signed char        int8;        /* Signed 8  bit value */
//下面的不建议使用
typedef  unsigned char     byte;         /* Unsigned 8  bit value type. */
typedef  unsigned short    word;         /* Unsinged 16 bit value type. */
typedef  unsigned long     dword;        /* Unsigned 32 bit value type. */
typedef  unsigned char     uint1;        /* Unsigned 8  bit value type. */
typedef  unsigned short    uint2;        /* Unsigned 16 bit value type. */
typedef  unsigned long     uint4;        /* Unsigned 32 bit value type. */
typedef  signed char       int1;         /* Signed 8  bit value type. */
typedef  signed short      int2;         /* Signed 16 bit value type. */
typedef  long int          int4;         /* Signed 32 bit value type. */
typedef  signed long       sint31;       /* Signed 32 bit value */
typedef  signed short      sint15;       /* Signed 16 bit value */
typedef  signed char       sint7;        /* Signed 8  bit value */
3,得到指定地址上的一个字节或字
#define  MEM_B( x )  ( *( (byte *) (x) ) )
#define  MEM_W( x )  ( *( (word *) (x) ) )
4,求最大值和最小值
   #define  MAX( x, y ) ( ((x) > (y)) ? (x) : (y) )
   #define  MIN( x, y ) ( ((x)  field ) /*lint +e545 */
6,得到一个结构体中field所占用的字节数
#define FSIZ( type, field ) sizeof( ((type *) 0)->field )
7,按照LSB格式把两个字节转化为一个Word
#define  FLIPW( ray ) ( (((word) (ray)[0]) * 256) + (ray)[1] )
8,按照LSB格式把一个Word转化为两个字节
#define  FLOPW( ray, val ) \
  (ray)[0] = ((val) / 256); \
  (ray)[1] = ((val) & 0xFF)
9,得到一个变量的地址(word宽度)
#define  B_PTR( var )  ( (byte *) (void *) &(var) )
#define  W_PTR( var )  ( (word *) (void *) &(var) )
10,得到一个字的高位和低位字节
#define  WORD_LO(xxx)  ((byte) ((word)(xxx) & 255))
#define  WORD_HI(xxx)  ((byte) ((word)(xxx) >> 8))
11,返回一个比X大的最接近的8的倍数
#define RND8( x )       ((((x) + 7) / 8 ) * 8 )
12,将一个字母转换为大写
#define  UPCASE( c ) ( ((c) >= 'a' && (c) = '0' && (c) = '0' && (c) = 'A' && (c) = 'a' && (c)  (val)) ? (val)+1 : (val))
16,返回数组元素的个数
#define  ARR_SIZE( a )  ( sizeof( (a) ) / sizeof( (a[0]) ) )
17,返回一个无符号数n尾的值MOD_BY_POWER_OF_TWO(X,n)=X%(2^n)
#define MOD_BY_POWER_OF_TWO( val, mod_by ) \
           ( (dword)(val) & (dword)((mod_by)-1) )
18,对于IO空间映射在存储空间的结构,输入输出处理
  #define inp(port)         (*((volatile byte *) (port)))
  #define inpw(port)        (*((volatile word *) (port)))
  #define inpdw(port)       (*((volatile dword *)(port)))
  #define outp(port, val)   (*((volatile byte *) (port)) = ((byte) (val)))
  #define outpw(port, val)  (*((volatile word *) (port)) = ((word) (val)))
  #define outpdw(port, val) (*((volatile dword *) (port)) = ((dword) (val)))
[2005-9-9添加]
19,使用一些宏跟踪调试
A N S I标准说明了五个预定义的宏名。它们是:
_ L I N E _
_ F I L E _
_ D A T E _
_ T I M E _
_ S T D C _
如果编译不是标准的,则可能仅支持以上宏名中的几个,或根本不支持。记住编译程序
也许还提供其它预定义的宏名。
_ L I N E _及_ F I L E _宏指令在有关# l i n e的部分中已讨论,这里讨论其余的宏名。
_ D AT E _宏指令含有形式为月/日/年的串,表示源文件被翻译到代码时的日期。
源代码翻译到目标代码的时间作为串包含在_ T I M E _中。串形式为时:分:秒。
如果实现是标准的,则宏_ S T D C _含有十进制常量1。如果它含有任何其它数,则实现是
非标准的。
可以定义宏,例如:
当定义了_DEBUG,输出数据信息和所在文件所在行
#ifdef _DEBUG
#define DEBUGMSG(msg,date) printf(msg);printf(“%d%d%d”,date,_LINE_,_FILE_)
#else
#endif
20,宏定义防止使用是错误
用小括号包含。
例如:#define ADD(a,b) (a+b)
用do{}while(0)语句包含多语句防止错误
例如:#difne DO(a,b) a+b;\
                   a++;
应用时:if(….)
          DO(a,b); //产生错误
        else
解决方法: #difne DO(a,b) do{a+b;\
                   a++;}while(0)
GMT+8, 2024-11-25 10:24 , Processed in 0.107294 second(s), 15 queries , MemCache On.
