查看: 4478|回复: 10
已提交计划书的ID(全部)
发表于 2007-7-16 12:27:57 | 显示全部楼层 |阅读模式
ID.00294ID.00473ID.00328ID.00421ID.00479
ID.00295ID.00502ID.00349ID.00422ID.00489
ID.00302ID.00514ID.00350ID.00436ID.00496
ID.00303ID.00568ID.00351ID.00437ID.00531
ID.00304ID.00569ID.00352ID.00438ID.00532
ID.00306ID.00570ID.00359ID.00440ID.00533
ID.00307ID.00571ID.00407ID.00444ID.00534
ID.00308ID.00572ID.00408ID.00445ID.00535
ID.00313ID.00575ID.00409ID.00449ID.00536
ID.00317ID.00577ID.00410ID.00450ID.00538
ID.00318ID.00578ID.00411ID.00455ID.00539
ID.00320ID.00579ID.00412ID.00462ID.00540
ID.00321ID.00580ID.00413ID.00466ID.00541
ID.00322ID.00581ID.00414ID.00470ID.00544
ID.00324ID.00582ID.00420ID.00471ID.00545
 楼主| 发表于 2007-7-16 12:28:15 | 显示全部楼层
RE:已提交计划书的ID(全部)
ID.00547        ID.00019        ID.00063        ID.00115        ID.00161
ID.00548        ID.00020        ID.00067        ID.00120        ID.00162
ID.00549        ID.00021        ID.00073        ID.00121        ID.00165
ID.00550        ID.00023        ID.00082        ID.00124        ID.00167
ID.00551        ID.00026        ID.00087        ID.00128        ID.00168
ID.00553        ID.00027        ID.00090        ID.00131        ID.00169
ID.00555        ID.00030        ID.00091        ID.00133        ID.00171
ID.00556        ID.00031        ID.00094        ID.00143        ID.00174
ID.00558        ID.00032        ID.00095        ID.00145        ID.00177
ID.00564        ID.00039        ID.00098        ID.00151        ID.00180
ID.00001        ID.00044        ID.00103        ID.00152        ID.00181
ID.00002        ID.00048        ID.00106        ID.00153        ID.00182
ID.00004        ID.00049        ID.00107        ID.00154        ID.00186
ID.00008        ID.00060        ID.00108        ID.00155        ID.00188
ID.00010        ID.00061        ID.00113        ID.00160        ID.00191
 楼主| 发表于 2007-7-16 12:28:30 | 显示全部楼层
RE:已提交计划书的ID(全部)
ID.00192        ID.00239        ID.00281        ID.00338        ID.00383
ID.00193        ID.00240        ID.00282        ID.00341        ID.00386
ID.00200        ID.00242        ID.00284        ID.00342        ID.00388
ID.00203        ID.00247        ID.00285        ID.00343        ID.00389
ID.00208        ID.00257        ID.00287        ID.00347        ID.00391
ID.00209        ID.00258        ID.00290        ID.00353        ID.00392
ID.00210        ID.00259        ID.00291        ID.00354        ID.00394
ID.00214        ID.00261        ID.00292        ID.00355        ID.00395
ID.00217        ID.00265        ID.00310        ID.00357        ID.00397
ID.00225        ID.00270        ID.00311        ID.00358        ID.00398
ID.00226        ID.00271        ID.00327        ID.00369        ID.00402
ID.00230        ID.00272        ID.00332        ID.00377        ID.00403
ID.00233        ID.00273        ID.00333        ID.00378        ID.00405
ID.00235        ID.00275        ID.00336        ID.00379        ID.00435
ID.00237        ID.00277        ID.00337        ID.00380        ID.00451
发表于 2007-7-16 15:07:27 | 显示全部楼层
RE:已提交计划书的ID(全部)
好像蛮多的
发表于 2007-7-16 15:46:22 | 显示全部楼层
RE:已提交计划书的ID(全部)
挺多  啊 ~!
发表于 2007-7-16 17:40:09 | 显示全部楼层
RE:已提交计划书的ID(全部)
加上  ID.00158
 楼主| 发表于 2007-7-17 11:32:26 | 显示全部楼层
RE:已提交计划书的ID(全部)
ID.00158
ID.00571
ID.00576
发表于 2007-7-17 17:04:59 | 显示全部楼层
RE:已提交计划书的ID(全部)
179份,
发表于 2007-7-17 18:48:00 | 显示全部楼层
RE:已提交计划书的ID(全部)
有人还是提交2分的呢,你怎么计算啊?一切就等结果出来了~
发表于 2007-7-27 10:28:15 | 显示全部楼层
RE:已提交计划书的ID(全部)
GMT+8, 2024-11-22 10:03 , Processed in 0.203991 second(s), 33 queries , MemCache On.
