为了方便贴代码,将原始实例的代码做了精简; 为了探索其原理,修改/添加了少量代码。 主要代码如下#include <stdio.h> - <p style="line-height: 28px;"><font color="rgb(51, 51, 51)"><font face="" "=""></font></font></p><p style="line-height: 28px;"><font color="rgb(51, 51, 51)"><font face="" "="">#include <ti/ndk/inc/netmain.h>
- #include <ti/sysbios/BIOS.h>
- #include <ti/sysbios/knl/Task.h>
- #include <xdc/runtime/Error.h>
- #include <xdc/runtime/System.h>
- #include "ti/platform/platform.h"
- #include "ti/platform/resource_mgr.h"
- static int counter=0;
- static HANDLE hHello=0;
- char *HostName = "TMS320C6678";
- char *LocalIPAddr = "169.254.11.119"; // My PC Local IP
- char *LocalIPMask = "255.255.255.0"; // Not used when using DHCP
- char *GatewayIP = "192.168.2.101"; // Not used when using DHCP
- char *DomainName = "demo.net"; // Not used when using DHCP
- char *DNSServer = "0.0.0.0"; // Used when set to anything but zero
- Uint8 clientMACAddress[6] = {0x01, 0x02, 0x03, 0x04, 0x0C, 0xEF}; /* MAC Addr */
- static void NetworkOpen();
- static void NetworkClose();
- static void NetworkIPAddr(IPN IPAddr, uint IfIdx, uint fAdd);
- extern int dtask_udp_hello();
- void EVM_init()
- printf("\nEVM_Init()\n");
- platform_init_flags sFlags;
- platform_init_config sConfig;
- memset( (void *) &sFlags, 0, sizeof(platform_init_flags));
- memset( (void *) &sConfig, 0, sizeof(platform_init_config));
- sFlags.pll = 0; /* PLLs for clocking */
- sFlags.ddr = 0; /* External memory */
- sFlags.tcsl = 1; /* Time stamp counter */
- sFlags.phy = 1; /* Ethernet */
- sFlags.ecc = 0; /* Memory ECC */
- sConfig.pllm = 0; /* Use libraries default clock divisor */
- platform_init(&sFlags, &sConfig);
- Void Hello(UArg arg0, UArg arg1)
- while(1)
- printf("Hello\n");
- Task_sleep(2000);
- if(counter>=3) break;
- Void Test(UArg arg0,UArg arg1);
- int main()
- Task_Handle task1 = Task_create(Test, NULL, NULL);
- Task_Handle task2 = Task_create(Hello, NULL, NULL);
- if (task1==NULL || task2==NULL)
- printf("Task_create() failed!\n");
- BIOS_exit(0);
- BIOS_start();
- QMSS_CFG_T qmss_cfg;
- CPPI_CFG_T cppi_cfg;
- uint32_t coreID = platform_get_coreid();
- uint32_t master=(coreID==0)?1:0;
- qmss_cfg.master_core = master;
- qmss_cfg.max_num_desc = MAX_NUM_DESC;
- qmss_cfg.desc_size = MAX_DESC_SIZE;
- qmss_cfg.mem_region = Qmss_MemRegion_MEMORY_REGION0;
- cppi_cfg.master_core = master;
- cppi_cfg.dma_num = Cppi_CpDma_PASS_CPDMA;
- cppi_cfg.num_tx_queues = NUM_PA_TX_QUEUES;
- cppi_cfg.num_rx_channels = NUM_PA_RX_CHANNELS;
- res_mgr_init_qmss(&qmss_cfg);
- res_mgr_init_cppi(&cppi_cfg);
- res_mgr_init_pass();
- int rc = NC_SystemOpen( NC_PRIORITY_LOW, NC_OPMODE_INTERRUPT );
- if( rc!=0 )
- NC_SystemClose();
- return;
- HANDLE hCfg = CfgNew();
- if( !hCfg )
- NC_SystemClose();
- return;
- CfgAddEntry( hCfg,CFGTAG_SYSINFO,CFGITEM_DHCP_HOSTNAME,0,strlen(HostName),(UINT8*)HostName,0);
- CI_IPNET NA;
- bzero( &NA, sizeof(NA) );
- NA.IPAddr = inet_addr(LocalIPAddr);
- NA.IPMask = inet_addr(LocalIPMask);
- strcpy( NA.Domain, DomainName );
- NA.NetType = 0;
- CfgAddEntry( hCfg, CFGTAG_IPNET, 1, 0,sizeof(CI_IPNET), (UINT8 *)&NA, 0 );
- CI_ROUTE RT;
- bzero( &RT, sizeof(RT) );
- RT.IPDestAddr = 0;
- RT.IPDestMask = 0;
- RT.IPGateAddr = inet_addr(GatewayIP);
- CfgAddEntry( hCfg, CFGTAG_ROUTE, 0, 0,sizeof(CI_ROUTE), (UINT8 *)&RT, 0 );
- IPN IPTmp = inet_addr(DNSServer);
- if( IPTmp )
- CfgAddEntry( hCfg, CFGTAG_SYSINFO, CFGITEM_DHCP_DOMAINNAMESERVER,0, sizeof(IPTmp), (UINT8 *)&IPTmp, 0 );
- rc = DBG_WARN;
- CfgAddEntry(hCfg,CFGTAG_OS,CFGITEM_OS_DBGPRINTLEVEL,CFG_ADDMODE_UNIQUE, sizeof(uint),(UINT8 *)&rc,0);
- rc = 8192;
- CfgAddEntry(hCfg,CFGTAG_IP,CFGITEM_IP_SOCKUDPRXLIMIT,CFG_ADDMODE_UNIQUE,sizeof(uint),(UINT8 *)&rc,0);
- do
- rc = NC_NetStart( hCfg, NetworkOpen, NetworkClose, NetworkIPAddr );
- } while( rc > 0 );
- CfgFree( hCfg );
- NC_SystemClose();
- hHello = DaemonNew( SOCK_DGRAM,0,7,dtask_udp_hello,OS_TASKPRINORM,OS_TASKSTKNORM,0,1);
- DaemonFree( hHello );
- static void NetworkIPAddr( IPN IPAddr, uint IfIdx, uint fAdd )
- IPN IPTmp;
- if( fAdd ) printf("Network Added: ");
- else printf("Network Removed: ");
- IPTmp = ntohl( IPAddr );
- printf("If-%d:%d.%d.%d.%d\n", IfIdx,
- (UINT8)(IPTmp>>24)&0xFF,(UINT8)(IPTmp>>16)&0xFF,
- (UINT8)(IPTmp>>8)&0xFF, (UINT8)IPTmp&0xFF );
- int dtask_udp_hello( SOCKET s, UINT32 unused )
- printf("TASK execution %d\n",++counter);
- (void)unused;
- struct timeval tv;
- tv.tv_sec = 3;
- tv.tv_usec = 0;
- setsockopt(s,SOL_SOCKET,SO_SNDTIMEO,&tv,sizeof(tv));
- setsockopt(s,SOL_SOCKET,SO_RCVTIMEO,&tv,sizeof(tv));
- struct sockaddr_in sin1;
- int sz=sizeof(sin1);
- int recvSize;
- HANDLE hBuffer;
- unsigned char* pBuf;
- while(1)
- recvSize=recvncfrom( s, (void**)&pBuf, 0, (PSA)&sin1, &sz, &hBuffer );
- if(recvSize<=0) break;
- sendto( s, pBuf, recvSize, 0, (PSA)&sin1, sz );
- recvncfree( hBuffer );
- // Since the socket is still open, return "1"
- // (we need to leave UDP sockets open)
- return 1;
- }</font></font></p>
其中EVM_init()函数被设置为在main()函数之前执行,具体设置在一个*.cfg文件中, 部分内容如下 - var Memory = xdc.useModule('xdc.runtime.Memory');
- var BIOS = xdc.useModule('ti.sysbios.BIOS');
- var Task = xdc.useModule('ti.sysbios.knl.Task');
- var HeapBuf = xdc.useModule('ti.sysbios.heaps.HeapBuf');
- var Log = xdc.useModule('xdc.runtime.Log');
- //...省略...
- Program.sectMap["sharedL2"] = "DDR3";
- Program.sectMap["systemHeap"] = "DDR3";
- Program.sectMap[".sysmem"] = "DDR3";
- Program.sectMap[".args"] = "DDR3";
- Program.sectMap[".cio"] = "DDR3";
- Program.sectMap[".far"] = "DDR3";
- Program.sectMap[".rodata"] = "DDR3";
- Program.sectMap[".neardata"] = "DDR3";
- //...省略...
- Startup.lastFxns.$add('&EVM_init');
- BIOS.taskEnabled = true;
- Ecm.eventGroupHwiNum[0] = 7;
- Ecm.eventGroupHwiNum[1] = 8;
- Ecm.eventGroupHwiNum[2] = 9;
- Ecm.eventGroupHwiNum[3] = 10;
- Global.IPv6 = true;
注意其中的
在主函数中执行BIOS_start()会完成一些主动操作 (似乎是因为main函数在DSP中的地位和在PC上不一样) 总之,在执行完EVM_init()完成基本的初始化后,创建我们的主要任务: - Task_Handle task1 = Task_create(Test, NULL, NULL);
其中Hello任务只是为了演示一下,每隔2秒(sleep(2000))打印一个“Hello”字样
而Test任务则执行了QMSS、CPPI、PA等等的初始化,完成了基本网络配置 启动Network服务后,关联了dtask_udp_hello任务,等待以太网接口的连接 另一边使用PC执行测试,发送字符串进行交互。
因为我们的程序中设置了一个计数器counter 每次发送一个字符串,dtask_udp_hello()就执行一次,counter++ 在Hello任务中,一旦发现条件counter>=3满足了就会退出while()循环,它的使命也就终结了 (注意并不是真的终结,因为没有执行KillTask这样的命令,只是Hello任务不再执行任何操作罢了) 这样只剩下Test任务独自运行了 某次测试如下
