查看: 2008|回复: 0
[经验] timer输入捕获测频率,偶尔会得到真实值的一半
发表于 2020-9-6 17:10:35 | 显示全部楼层 |阅读模式
用了定时器的输入捕获功能来测得频率,有两个中断,上升沿中断和溢出中断, 第一次溢出后开始取数,用上这次上升沿的数值减去一次上升沿的数值得出信号源频率值,第二次计数器溢出后关闭中断和定时器。现在偶尔会出现捕获值翻倍,好像漏掉了一次上升沿一样,我开启了 捕获溢出判断也并没有进入贴一下中断服务函数
void TIMER2_IRQHandler(void)
           if(SET == timer_interrupt_flag_get(TIMER2,TIMER_INT_UP))
                         timer_interrupt_flag_clear(TIMER2,TIMER_INT_UP);
                         timer2_counter_overflow++;
       timer2_interrupt_clear();
                         update_flag++;
                  if(timer2_counter_overflow==2)
                         timer2_interrupt_disable(); //double time capture,????????g???????2.????????
                   timer_disable(TIMER2);
                         timer2_counter_overflow=0;
    if(SET == timer_interrupt_flag_get(TIMER2,TIMER_INT_CH0))
        /* clear channel 0 interrupt bit */
        timer_interrupt_flag_clear(TIMER2,TIMER_INT_CH0);
/* !!!!!!!!!! */interrupt_flag1++; /* !!!!!!!!!!!!!! */
            /* read channel 0 capture value */
                        if((timer2_counter_overflow==1) && (RESET == timer_flag_get(TIMER2,TIMER_INTF_CH0OF)))//wu yi chu
        if(0 == ccnumber0)
        CH0_CAPTURE_OLD = timer_channel_capture_value_register_read(TIMER2,TIMER_CH_0)+1;
         ccnumber0 = 1;
        else if(1 == ccnumber0)
        CH0_CAPTURE_NEW = timer_channel_capture_value_register_read(TIMER2,TIMER_CH_0)+1;
        if(CH0_CAPTURE_NEW > CH0_CAPTURE_OLD)
        ic1value = CH0_CAPTURE_NEW - CH0_CAPTURE_OLD;
        else{
                                                ic1value = ((0xFFFF - CH0_CAPTURE_OLD) + CH0_CAPTURE_NEW);
                                                fre_highcapture_1= 10000000/ ic1value;
/* !!!!!!!!!! */fre_highcapture_1_OLD=fre_highcapture_1;
            if(fre_highcapture_1<9980)
/* !!!!!!!!!! */int_CH0_flag=1;  /* !!!!!!!!!!!!!!!!! */
            if(fre_highcapture_1>10012)
              int_CH0_flag=1;
              ccnumber0 = 0;
                  if((timer2_counter_overflow==1) &&(SET == timer_flag_get(TIMER2,TIMER_INTF_CH0OF)))//you yi chu
                          timer_flag_clear(TIMER2,TIMER_INTF_CH0OF);
/* !!!!!!!!!! */fre_highcapture_1=fre_highcapture_1_OLD;
/* !!!!!!!!!! */timer2_interrupt_disable();  /* !!!!!!!!!! */
/* !!!!!!!!!! */timer_disable(TIMER2);       /* !!!!!!!!!!!!!!! */
                          int_CH0_flag=1;
                           ccnumber0 = 0;
    if(SET == timer_interrupt_flag_get(TIMER2,TIMER_INT_CH1))
        timer_interrupt_flag_clear(TIMER2,TIMER_INT_CH1);
/* !!!!!!!!!! */ interrupt_flag2++; /* !!!!!!!!!!!! */
                        if((timer2_counter_overflow==1) && (RESET == timer_flag_get(TIMER2,TIMER_INTF_CH1OF)))
        if(0 == ccnumber1)
        CH1_CAPTURE_OLD = timer_channel_capture_value_register_read(TIMER2,TIMER_CH_1)+1;
         ccnumber1 = 1;
        else if(1 == ccnumber1)
         CH1_CAPTURE_NEW = timer_channel_capture_value_register_read(TIMER2,TIMER_CH_1)+1;
         if(CH1_CAPTURE_NEW > CH1_CAPTURE_OLD)
                        ic2value = CH1_CAPTURE_NEW - CH1_CAPTURE_OLD;
       else{
          ic2value = ((0xFFFF - CH1_CAPTURE_OLD) + CH1_CAPTURE_NEW);
            fre_highcapture_2= 10000000/ ic2value;
/* !!!!!!!!!! */fre_highcapture_2_OLD=fre_highcapture_2;
            if(fre_highcapture_2<9980)
/* !!!!!!!!!! */int_CH1_flag=1;  /* !!!!!!!!!!!!!!!!! */
            if(fre_highcapture_2>10012)
            int_CH1_flag=1;
            ccnumber1 = 0;
                   if((timer2_counter_overflow==1) &&(SET == timer_flag_get(TIMER2,TIMER_INTF_CH1OF)))
                    timer_flag_clear(TIMER2,TIMER_INTF_CH1OF);
                    fre_highcapture_2=fre_highcapture_2_OLD;
                    int_CH1_flag=1;
                     ccnumber1 = 0;
    if(SET == timer_interrupt_flag_get(TIMER2,TIMER_INT_CH2))
     timer_interrupt_flag_clear(TIMER2,TIMER_INT_CH2);
/* !!!!!!!!!! */ interrupt_flag3++;/* !!!!!!!!!! */
                        if((timer2_counter_overflow==1) && (RESET == timer_flag_get(TIMER2,TIMER_INTF_CH2OF)))
        if(0 == ccnumber2)
        CH2_CAPTURE_OLD = timer_channel_capture_value_register_read(TIMER2,TIMER_CH_2)+1;
         ccnumber2 = 1;
        else if(1 == ccnumber2)
         CH2_CAPTURE_NEW = timer_channel_capture_value_register_read(TIMER2,TIMER_CH_2)+1;
         if(CH2_CAPTURE_NEW > CH2_CAPTURE_OLD)
                      ic3value = CH2_CAPTURE_NEW - CH2_CAPTURE_OLD;
                     else
                            ic3value = ((0xFFFF - CH2_CAPTURE_OLD) + CH2_CAPTURE_NEW);
                                fre_highcapture_3= 10000000/ ic3value;
                                if(fre_highcapture_3<9980)
/* !!!!!!!!!! */int_CH2_flag=1;  /* !!!!!!!!!!!!!!!!! */
                                if(fre_highcapture_3>10012)
                                int_CH2_flag=1;
                                ccnumber2 = 0;
                if((timer2_counter_overflow==1) && (SET == timer_flag_get(TIMER2,TIMER_INTF_CH2OF)))
                        timer_flag_clear(TIMER2,TIMER_INTF_CH2OF);
/* !!!!!!!!!! */fre_highcapture_3=fre_highcapture_3_OLD;
                        int_CH2_flag=1;
                        ccnumber2 = 0;
    if(SET == timer_interrupt_flag_get(TIMER2,TIMER_INT_CH3))
        timer_interrupt_flag_clear(TIMER2,TIMER_INT_CH3);
/* !!!!!!!!!! */interrupt_flag4++;/* !!!!!!!!!! */
                        if((timer2_counter_overflow==1) && (RESET == timer_flag_get(TIMER2,TIMER_INTF_CH3OF)))
        if(0 == ccnumber3)
         CH3_CAPTURE_OLD = timer_channel_capture_value_register_read(TIMER2,TIMER_CH_3)+1;
         ccnumber3 = 1;
        else if(1 == ccnumber3)
         CH3_CAPTURE_NEW = timer_channel_capture_value_register_read(TIMER2,TIMER_CH_3)+1;
         if(CH3_CAPTURE_NEW > CH3_CAPTURE_OLD)
                        ic4value = CH3_CAPTURE_NEW - CH3_CAPTURE_OLD;
        else{
            ic4value = ((0xFFFF - CH3_CAPTURE_OLD) + CH3_CAPTURE_NEW);
          fre_highcapture_4 = 10000000/ ic4value;
/* !!!!!!!!!! */fre_highcapture_4_OLD=fre_highcapture_4;
            if(fre_highcapture_4<9980)
/* !!!!!!!!!! */int_CH3_flag=1;  /* !!!!!!!!!!!!!!!!! */
            if(fre_highcapture_4>10012)
            int_CH3_flag=1;
            ccnumber3 = 0;
                 if((timer2_counter_overflow==1) && (SET == timer_flag_get(TIMER2,TIMER_INTF_CH3OF)))
                        timer_flag_clear(TIMER2,TIMER_INTF_CH3OF);
/* !!!!!!!!!! */fre_highcapture_4=fre_highcapture_4_OLD;/* !!!!!!!!!! */
                        int_CH3_flag=1;
                        ccnumber3 = 0;
GMT+8, 2025-1-29 08:03 , Processed in 0.112348 second(s), 15 queries , MemCache On.
