查看: 706|回复: 0
打印 上一主题 下一主题
[经验] 以太网控制器CRC校验模块实现代码
    无聊
    2018-11-16 10:48
  • 签到天数: 2 天
    跳转到指定楼层
    楼主
    发表于 2020-7-27 09:38:11 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
    crc校验模块计算产生发送数据需要的 CRC 校验序列。计算产生的 CRC 校验需要添加到数据帧上。这个模块同时被接收数据模块用来计算 CRC 校验序列,然后和接收到的 CRC 校验序列进行比较,从而判断传输过程中是否发生错误。CRC 校验模块的主要代码如下:
    • include "timescale.v"
    • module eth_crc (Clk, Reset, Data, Enable, Initialize, Crc, CrcError);
    • parameter Tp = 1;
    • //输入、输出信号
    • input Clk;
    • input Reset;
    • input [3:0] Data;
    • input Enable;
    • input Initialize;
    • output [31:0] Crc;
    • output CrcError;
    • reg [31:0] Crc;
    • wire [31:0] CrcNext;
    • //计算获得 CRC 序列
    • assign CrcNext[0] = Enable & (Data[0] ^ Crc[28]);
    • assign CrcNext[1] = Enable & (Data[1] ^ Data[0] ^ Crc[28] ^ Crc[29]);
    • assign CrcNext[2] = Enable & (Data[2] ^ Data[1] ^ Data[0] ^ Crc[28] ^ Crc[29] ^ Crc[30]);
    • assign CrcNext[3] = Enable & (Data[3] ^ Data[2] ^ Data[1] ^ Crc[29] ^ Crc[30] ^ Crc[31]);
    • assign CrcNext[4] = (Enable & (Data[3] ^ Data[2] ^ Data[0] ^ Crc[28] ^ Crc[30] ^ Crc[31]))^ Crc[0];
    • assign CrcNext[5] = (Enable & (Data[3] ^ Data[1] ^ Data[0] ^ Crc[28] ^ Crc[29] ^ Crc[31]))^ Crc[1];
    • assign CrcNext[6] = (Enable & (Data[2] ^ Data[1] ^ Crc[29] ^ Crc[30])) ^ Crc[ 2];
    • assign CrcNext[7] = (Enable & (Data[3] ^ Data[2] ^ Data[0] ^ Crc[28] ^ Crc[30] ^ Crc[31]))^ Crc[3];
    • assign CrcNext[8] = (Enable & (Data[3] ^ Data[1] ^ Data[0] ^ Crc[28] ^ Crc[29] ^ Crc[31]))^ Crc[4];
    • assign CrcNext[9] = (Enable & (Data[2] ^ Data[1] ^ Crc[29] ^ Crc[30])) ^ Crc[5];
    • assign CrcNext[10] = (Enable & (Data[3] ^ Data[2] ^ Data[0] ^ Crc[28] ^ Crc[30] ^ Crc[31]))^ Crc[6];
    • assign CrcNext[11] = (Enable & (Data[3] ^ Data[1] ^ Data[0] ^ Crc[28] ^ Crc[29] ^ Crc[31]))^ Crc[7];
    • assign CrcNext[12] = (Enable & (Data[2] ^ Data[1] ^ Data[0] ^ Crc[28] ^ Crc[29] ^ Crc[30]))^ Crc[8];
    • assign CrcNext[13] = (Enable & (Data[3] ^ Data[2] ^ Data[1] ^ Crc[29] ^ Crc[30] ^ Crc[31]))^ Crc[9];
    • assign CrcNext[14] = (Enable & (Data[3] ^ Data[2] ^ Crc[30] ^ Crc[31])) ^ Crc[10];
    • assign CrcNext[15] = (Enable & (Data[3] ^ Crc[31])) ^ Crc[11];
    • assign CrcNext[16] = (Enable & (Data[0] ^ Crc[28])) ^ Crc[12];
    • assign CrcNext[17] = (Enable & (Data[1] ^ Crc[29])) ^ Crc[13];
    • assign CrcNext[18] = (Enable & (Data[2] ^ Crc[30])) ^ Crc[14];
    • assign CrcNext[19] = (Enable & (Data[3] ^ Crc[31])) ^ Crc[15];
    • assign CrcNext[20] = Crc[16];
    • assign CrcNext[21] = Crc[17];
    • assign CrcNext[22] = (Enable & (Data[0] ^ Crc[28])) ^ Crc[18];
    • assign CrcNext[23] = (Enable & (Data[1] ^ Data[0] ^ Crc[29] ^ Crc[28])) ^ Crc[19];
    • assign CrcNext[24] = (Enable & (Data[2] ^ Data[1] ^ Crc[30] ^ Crc[29])) ^ Crc[20];
    • assign CrcNext[25] = (Enable & (Data[3] ^ Data[2] ^ Crc[31] ^ Crc[30])) ^ Crc[21];
    • assign CrcNext[26] = (Enable & (Data[3] ^ Data[0] ^ Crc[31] ^ Crc[28])) ^ Crc[22];
    • assign CrcNext[27] = (Enable & (Data[1] ^ Crc[29])) ^ Crc[23];
    • assign CrcNext[28] = (Enable & (Data[2] ^ Crc[30])) ^ Crc[24];
    • assign CrcNext[29] = (Enable & (Data[3] ^ Crc[31])) ^ Crc[25];
    • assign CrcNext[30] = Crc[26];
    • assign CrcNext[31] = Crc[27];
    • //初始化和复位 CRC 校验序列
    • always @ (posedge Clk or posedge Reset)
    • begin
    • IF (Reset)
    • Crc <= #1 32'hffffffff;
    • else
    • if(Initialize)
    • Crc <= #Tp 32'hffffffff;
    • else
    • Crc <= #Tp CrcNext;
    • end
    • //发生错误时的结果
    • assign CrcError = Crc[31:0] != 32'hc704dd7b; // CRC not equal to magic number
    • endmodule
    [color=rgb(51, 102, 153) !important]复制代码
    [url=][/url]0
    举报
    站长推荐上一条 1/4 下一条
    有奖活动|英飞凌智能座舱直播活动
    查看 »
    GMT+8, 2025-4-15 17:13 , Processed in 0.113945 second(s), 17 queries , MemCache On.
