TA的每日心情 | 开心 2019-11-4 13:48 |
签到天数: 14 天 连续签到: 1 天 [LV.3]偶尔看看II
按照回帖建议直接使用cube库里LAN8742里的驱动,然后对照不同PHY芯片寄存器查看,可以读到寄存器数据,但是网络一直没有调通,特别是gratuitous arp设备上线的广播都抓不到,更不谈能PING通设备了。
经过长达两周的反复测试和问题排查,直接问题出在MPU和CACHE处理上。现分享使能MPU、CACHE和不使能MPU、CACHE两种模式配置说明:
一、使能MPU、CACHE情况
1、main.c中 HAL_Init()上加上MPU和CACHE配置
/* USER CODE BEGIN 1 */
MPU_Config();
CPU_CACHE_Enable();
/* USER CODE END 1 */
/* Reset of all peripherals, Initializes the Flash interface and the Systick. */
HAL_Init();
/* USER CODE BEGIN 4 */
* @brief Configure the MPU attributes
* @param None
* @retval None
static void MPU_Config(void)
MPU_Region_InitTypeDef MPU_InitStruct;
/* Disable the MPU */
HAL_MPU_Disable();
/* Configure the MPU attributes as Device not cacheable
for ETH DMA descriptors */
MPU_InitStruct.Enable = MPU_REGION_ENABLE;
MPU_InitStruct.BaseAddress = 0x30040000;
MPU_InitStruct.Size = MPU_REGION_SIZE_256B;
MPU_InitStruct.AccessPermission = MPU_REGION_FULL_ACCESS;
MPU_InitStruct.IsBufferable = MPU_ACCESS_BUFFERABLE;
MPU_InitStruct.IsCacheable = MPU_ACCESS_NOT_CACHEABLE;
MPU_InitStruct.IsShareable = MPU_ACCESS_NOT_SHAREABLE;
MPU_InitStruct.Number = MPU_REGION_NUMBER0;
MPU_InitStruct.TypeExtField = MPU_TEX_LEVEL0;
MPU_InitStruct.SubRegionDisable = 0x00;
MPU_InitStruct.DisableExec = MPU_INSTRUCTION_ACCESS_ENABLE;
HAL_MPU_ConfigRegion(&MPU_InitStruct);
/* Configure the MPU attributes as Cacheable write through
for LwIP RAM heap which contains the Tx buffers */
MPU_InitStruct.BaseAddress = 0x30044000;
MPU_InitStruct.Size = MPU_REGION_SIZE_16KB;
MPU_InitStruct.IsBufferable = MPU_ACCESS_NOT_BUFFERABLE;
MPU_InitStruct.IsCacheable = MPU_ACCESS_CACHEABLE;
MPU_InitStruct.Number = MPU_REGION_NUMBER1;
/* Enable the MPU */
HAL_MPU_Enable(MPU_PRIVILEGED_DEFAULT);
* @brief CPU L1-Cache enable.
* @param None
* @retval None
static void CPU_CACHE_Enable(void)
/* Enable I-Cache */
SCB_EnableICache();
/* Enable D-Cache */
SCB_EnableDCache();
2、main.c中时钟配置中加上一句 使能SRAM3时钟
/* Enable D2 domain SRAM3 Clock (0x30040000 AXI)*/
__HAL_RCC_D2SRAM3_CLK_ENABLE();
3、ethernetif.c中DMARxDscrTab、DMATxDscrTab地址分配,注意和MPU对比
#if defined ( __ICCARM__ ) /*!< IAR Compiler */
#pragma location=0x30040000
ETH_DMADescTypeDef DMARxDscrTab[ETH_RX_DESC_CNT]; /* Ethernet Rx DMA Descriptors */
#pragma location=0x30040060
ETH_DMADescTypeDef DMATxDscrTab[ETH_TX_DESC_CNT]; /* Ethernet Tx DMA Descriptors */
#pragma location=0x30040200
uint8_t Rx_Buff[ETH_RX_DESC_CNT][ETH_RX_BUFFER_SIZE]; /* Ethernet Receive Buffers */
#elif defined ( __CC_ARM ) /* MDK ARM Compiler */
__attribute__((at(0x30040000))) ETH_DMADescTypeDef DMARxDscrTab[ETH_RX_DESC_CNT]; /* Ethernet Rx DMA Descriptors */
__attribute__((at(0x30040060))) ETH_DMADescTypeDef DMATxDscrTab[ETH_TX_DESC_CNT]; /* Ethernet Tx DMA Descriptors */
__attribute__((at(0x30040200))) uint8_t Rx_Buff[ETH_RX_DESC_CNT][ETH_RX_BUFFER_SIZE]; /* Ethernet Receive Buffer */
#elif defined ( __GNUC__ ) /* GNU Compiler */
ETH_DMADescTypeDef DMARxDscrTab[ETH_RX_DESC_CNT] __attribute__((section(".RxDecripSection"))); /* Ethernet Rx DMA Descriptors */
ETH_DMADescTypeDef DMATxDscrTab[ETH_TX_DESC_CNT] __attribute__((section(".TxDecripSection"))); /* Ethernet Tx DMA Descriptors */
uint8_t Rx_Buff[ETH_RX_DESC_CNT][ETH_RX_BUFFER_SIZE] __attribute__((section(".RxArraySection"))); /* Ethernet Receive Buffers */
#endif
4、low_level_output中
SCB_CleanInvalidateDCache();
HAL_ETH_Transmit(&heth, &TxConfig, 5);
5、low_level_input中
/* Clean and Invalidate data cache */
HAL_ETH_GetRxDataBuffer(&heth, &RxBuff);
HAL_ETH_GetRxDataLength(&heth, &framelength);
SCB_InvalidateDCache_by_Addr((uint32_t *)Rx_Buff, (ETH_RX_DESC_CNT*ETH_RX_BUFFER_SIZE));
6、lwipopts.h中,注意和MPU对比
#define LWIP_RAM_HEAP_POINTER (0x30044000)
7、ETH_RX_BUFFER_SIZE要一致
heth.Init.RxBuffLen = ETH_RX_BUFFER_SIZE;
p = pbuf_alloced_custom(PBUF_RAW, framelength, PBUF_POOL, &rx_pbuf[current_pbuf_idx], RxBuff.buffer, ETH_RX_BUFFER_SIZE);
8、keil配置RAM如下,勾线IRAM2,不勾选IRAM1
见附件。
二、不使能MPU、CACHE情况
上述1,4,5,6标红代码全部注释掉。
三、注意事项
1、网络相关管脚配置成高速,cube默认是低速
2、可以先禁止MPU和cache,屏蔽掉相关代码,待网络测通后再开启MPU和cache,进行对应配置
3、H7目前官方库支持不到位,特别是有些examples完全没有经过验证,需特别注意
4、使用MPU和cache时,多看看手册,弄懂机制避免入坑
