VS-RK3399嵌入式安卓主板修改并默认HDMI分辨率 过滤HDMI分辨率 驱动部分 kernel/drivers/gpu/drm/rockchip/dw_hdmi-rockchip.c static enum drm_mode_status dw_hdmi_rockchip_mode_valid(struct drm_connector *connector, struct drm_display_mode *mode) { struct drm_encoder *encoder = connector->encoder; enum drm_mode_status status = MODE_OK; struct drm_device *dev = connector->dev; struct rockchip_drm_private *priv = dev->dev_private; struct drm_crtc *crtc;
/* * Pixel clocks we support are always < 2GHz and so fit in an * int. We should make sure source rate does too so we don't get * overflow when we multiply by 1000. */ + if(!(!strcmp(mode->name, "4096x2160") || !strcmp(mode->name, "3840x2160") || + ((!strcmp(mode->name, "1920x1080")) && mode->vrefresh == 60)|| + ((!strcmp(mode->name, "1366x768")) && mode->vrefresh == 60)|| + ((!strcmp(mode->name, "1280x720")) && mode->vrefresh == 60))){ + printk(KERN_ERR"bad mode:%s, vrefresh:%dn",mode->name, mode->vrefresh); + return MODE_BAD; + }
默认HDMI分辨率 out/target/product/rk3399_mid/system/build.prop 添加persist.sys.resolution.aux=4096x2160p60
