查看: 1786|回复: 4
STM8 控制电脑风扇转速 4PIN PWM
    无聊
    2018-11-16 10:48
  • 签到天数: 2 天
    发表于 2020-7-10 18:16:23 | 显示全部楼层 |阅读模式
    个很简单的例子读取电位器电压,然后调整占空比
    游客,如果您要查看本帖隐藏内容请回复
    程序代码:
    • #include "stm8s.h"
    • #include "stm8s_gpio.h"
    • #define PWM_F  640
    • uint8_t HexTable[]={'0','1','2','3','4','5','6','7','8','9','A','B','C','D','E','F'};
    • uint16_t CCR1_Val = 100;
    • void DelayApi(uint16_t uwDelayCnt);
    • void TIM2_Config(void);
    • void Init_UART1(void)
    •         UART1_DeInit();
    •         UART1_Init((u32)9600, UART1_WORDLENGTH_8D, UART1_STOPBITS_1, UART1_PARITY_NO, UART1_SYNCMODE_CLOCK_DISABLE, UART1_MODE_TX_ENABLE);
    • //        UART1_Cmd(ENABLE);
    • void Send(uint8_t dat)
    •     while(( UART1_GetFlagStatus(UART1_FLAG_TXE)==RESET));
    •     UART1_SendData8(dat);
    • void Init_ADC(void)
    •         //GPIO_Init(GPIOD, GPIO_PIN_2, GPIO_MODE_IN_FL_NO_IT);
    •         ADC1_DeInit();
    •         ADC1_Init(ADC1_CONVERSIONMODE_SINGLE, ADC1_CHANNEL_3, ADC1_PRESSEL_FCPU_D2, ADC1_EXTTRIG_TIM, DISABLE, ADC1_ALIGN_RIGHT, ADC1_SCHMITTTRIG_CHANNEL3, ENABLE);
    •         ADC1_Cmd(ENABLE);
    • void UART1_sendhex(unsigned char dat)
    •     Send('0');
    •     Send('x');
    •     Send(HexTable[dat>>4]);
    •     Send(HexTable[dat&0x0f]);
    •     Send(' ');
    • void UART1_sendstr(unsigned char *dat)
    •     while(*dat!='\0')
    •       Send(*dat);
    •       dat++;
    •       //delay2us();
    • void main(void)
    •     //FlagStatus flag_status;
    •     u16 u16_adc1_value;
    •     //Init_UART1();
    •     Init_ADC();
    •     CLK_HSIPrescalerConfig(CLK_PRESCALER_HSIDIV1);//16/1=16MHZ
    •     GPIO_DeInit(GPIOD);
    •     GPIO_Init(GPIOD,GPIO_PIN_2,GPIO_MODE_IN_PU_NO_IT);
    •     //GPIO_DeInit(GPIOD);
    •     GPIO_Init(GPIOD,GPIO_PIN_4,GPIO_MODE_OUT_PP_HIGH_SLOW);
    •     TIM2_Config();
    •     TIM2_SetCompare1(CCR1_Val);
    • /* Infinite loop */
    •     while (1)
    •                 //Send(0xf0);
    •          ADC1_StartConversion();
    •          //flag_status = ADC1_GetFlagStatus(ADC1_FLAG_EOC);
    •         // while(flag_status == RESET); // SET or RESET
    •          while(RESET == ADC1_GetFlagStatus(ADC1_FLAG_EOC));
    •              u16_adc1_value = ADC1_GetConversionValue();
    •          //CCR1_Val=u16_adc1_value*2/3-66;
    •          //CCR1_Val=101+u16_adc1_value*10/19;
    •          /*if(u16_adc1_value<180)
    •             CCR1_Val=70+u16_adc1_value*2;
    •          }else
    •           CCR1_Val=460+(u16_adc1_value-180)*10/47;
    •           if(u16_adc1_value<180)
    •             if(u16_adc1_value<100){u16_adc1_value=100;}
    •             CCR1_Val=u16_adc1_value+((u16_adc1_value-100)*36/10);
    •           }else
    •          if(CCR1_Val>30000)
    •            CCR1_Val=0;
    •          if(CCR1_Val>PWM_F && CCR1_Val<2000)
    •            CCR1_Val=PWM_F-2;
    •          //UART1_sendhex((u16_adc1_value>>8));
    •          //UART1_sendhex((u16_adc1_value&0xff));
    •          //UART1_sendstr("\r\n");
    •          //GPIO_WriteReverse(GPIOB,GPIO_PIN_5);
    •   TIM2_TimeBaseInit(TIM2_PRESCALER_1, PWM_F);
    •   TIM2_OC1Init(TIM2_OCMODE_PWM1, TIM2_OUTPUTSTATE_ENABLE,CCR1_Val, TIM2_OCPOLARITY_HIGH);
    •   TIM2_OC1PreloadConfig(ENABLE);
    • //  TIM2_OC2Init(TIM2_OCMODE_PWM1, TIM2_OUTPUTSTATE_ENABLE,CCR2_Val, TIM2_OCPOLARITY_HIGH);
    • //  TIM2_OC2PreloadConfig(ENABLE);
    • //  TIM2_OC3Init(TIM2_OCMODE_PWM1, TIM2_OUTPUTSTATE_ENABLE,CCR3_Val, TIM2_OCPOLARITY_HIGH);
    • //  TIM2_OC3PreloadConfig(ENABLE);
    •   TIM2_ARRPreloadConfig(ENABLE);
    •   TIM2_Cmd(ENABLE);
    •   while(uwDelayCnt--);
    • #ifdef USE_FULL_ASSERT
    •   * @brief  Reports the name of the source file and the source line number
    •   *   where the assert_param error has occurred.
    •   * @param file: pointer to the source file name
    •   * @param line: assert_param error line source number
    •   * @retval : None
    • void assert_failed(u8* file, u32 line)
    •   /* User can add his own implementation to report the file name and line number,
    •      ex: printf("Wrong parameters value: file %s on line %d\r\n", file, line) */
    •   while (1)
    • #endif
    [color=rgb(51, 102, 153) !important]复制代码
  • 签到天数: 1371 天
    连续签到: 3 天
    发表于 2020-7-13 09:08:25 | 显示全部楼层
    然后调整占空比
    GMT+8, 2024-11-22 17:38 , Processed in 0.152648 second(s), 25 queries , MemCache On.
