查看: 718|回复: 0
[经验] 数码管驱动芯片的芯片
  • 签到天数: 14 天
    发表于 2020-6-24 09:40:50 | 显示全部楼层 |阅读模式
    工作中经常要用到大量的数码管,点阵,LED
    一般都是用74系列的芯片去驱动,因为公司的项目需求找了这颗芯片现在分享驱动和原理图过
    • enum Brightness
    •     Level1 = 0x88,
    •     Level2,
    •     Level3,
    •     Level4,
    •     Level5,
    •     Level6,
    •     Level7,
    •     Level8,
    •     LEDOFF = 0x80
    • uint8_t NUM[11][5] =
    •   {0xFF, 0x41, 0x41, 0x41, 0xFF},//0
    •   {0x00, 0x00, 0x7F, 0x00, 0x00},//1
    •   {0x79, 0x49, 0x49, 0x49, 0x4F},//2
    •   {0x49, 0x49, 0x49, 0x49, 0xFF},//3
    •   {0x0F, 0x08, 0x08, 0x08, 0xFF},//4
    •   {0x4F, 0x49, 0x49, 0x49, 0x79},//5
    •   {0xFF, 0x49, 0x49, 0x49, 0x79},//6
    •   {0x01, 0x01, 0x01, 0x01, 0xFF},//7
    •   {0xFF, 0x49, 0x49, 0x49, 0xFF},//8
    •   {0x4F, 0x49, 0x49, 0x49, 0xFF},//9
    •   {0x00, 0x00, 0x22, 0x00, 0x00},//:
    • void TM1640_GPIO_Init(void)
    •   GPIO_Init(GPIOA, (GPIO_Pin_TypeDef)(GPIO_PIN_1), GPIO_MODE_OUT_PP_HIGH_FAST);
    •   GPIO_Init(GPIOA, (GPIO_Pin_TypeDef)(GPIO_PIN_2), GPIO_MODE_OUT_PP_HIGH_FAST);
    •   GPIO_Init(GPIOC, (GPIO_Pin_TypeDef)(T2_Din | T2_Clk), GPIO_MODE_OUT_PP_HIGH_FAST);
    • void Delay(uint16_t nCount)
    •   while (nCount != 0)
    •     nCount--;
    • void TM1640_Start(void)
    •   GPIO_WriteHigh(GPIOA, T1_Clk);
    •   Delay(10);
    •   GPIO_WriteHigh(GPIOA, T1_Din);
    •   Delay(10);
    •   GPIO_WriteLow(GPIOA, T1_Din);
    •   Delay(10);
    •   GPIO_WriteLow(GPIOA, T1_Clk);
    •   Delay(10);
    • void TM1640_Stop(void)
    •   Delay(10);
    •   Delay(10);
    •   Delay(10);
    •   Delay(10);
    • void TM1640_2_Start(void)
    •   GPIO_WriteHigh(GPIOC, T2_Clk);
    •   Delay(10);
    •   GPIO_WriteHigh(GPIOC, T2_Din);
    •   Delay(10);
    •   GPIO_WriteLow(GPIOC, T2_Din);
    •   Delay(10);
    •   GPIO_WriteLow(GPIOC, T2_Clk);
    •   Delay(10);
    • void TM1640_2_Stop(void)
    •   Delay(10);
    •   Delay(10);
    •   Delay(10);
    •   Delay(10);
    • void TM1640_Write_Byte(uint8_t dat)
    •   uint8_t i;
    •   for(i = 0; i < 8; i++)
    •     if(dat & 0x01)
    •     else
    •     Delay(10);
    •     Delay(10);
    •     dat >>= 1;
    •   Delay(10);
    • void TM1640_2_Write_Byte(uint8_t dat)
    •   uint8_t i;
    •     if(dat & 0x01)
    •     else
    •     Delay(10);
    •     Delay(10);
    •     dat >>= 1;
    •   Delay(10);
    • void TM1640_Init(void)
    •   TM1640_GPIO_Init();
    •   Delay(10);
    •   TM1640_Start();
    •   TM1640_Write_Byte(Level8);
    •   TM1640_Stop();
    •   TM1640_2_Start();
    •   TM1640_2_Write_Byte(Level8);
    •   TM1640_2_Stop();
    • void TM1640_Bit1(uint8_t *Dat)
    •   uint8_t i;
    •   TM1640_Start();
    •   TM1640_Write_Byte(0x40);
    •   TM1640_Stop();
    •   Delay(10);
    •   TM1640_Start();
    •   TM1640_Write_Byte(0xC0);
    •   for(i = 0; i < 5; i++)
    •     TM1640_Write_Byte(*(Dat++));
    •   TM1640_Stop();
    • void TM1640_Clear_C5(void)
    •   TM1640_Start();
    •   TM1640_Write_Byte(0x44);
    •   TM1640_Stop();
    •   Delay(10);
    •   TM1640_Start();
    •   TM1640_Write_Byte(0xC5);
    •   TM1640_Write_Byte(0x00);
    •   TM1640_Stop();
    •   TM1640_Start();
    •   TM1640_Stop();
    •   Delay(10);
    •   TM1640_Start();
    •   TM1640_Write_Byte(0xCD);
    •   TM1640_Stop();
    •   TM1640_2_Start();
    •   TM1640_2_Write_Byte(0xC4);
    •   TM1640_2_Write_Byte(0x00);
    •   TM1640_2_Stop();
    • void TM1640_ClearAll(void)
    •   uint8_t i;
    •   TM1640_Start();
    •   TM1640_Stop();
    •   Delay(10);
    •   TM1640_Start();
    •   for(i = 0; i < 16; i++)
    •   TM1640_Stop();
    •   TM1640_2_Start();
    •   TM1640_2_Write_Byte(0x40);
    •   TM1640_2_Stop();
    •   Delay(10);
    •   TM1640_2_Start();
    •   TM1640_2_Write_Byte(0xC6);
    •   TM1640_2_Stop();
    • void TM1640_Bit2(uint8_t *Dat)
    •   uint8_t i;
    •   TM1640_Start();
    •   TM1640_Stop();
    •   Delay(10);
    •   TM1640_Start();
    •   TM1640_Write_Byte(0xC6);
    •   TM1640_Stop();
    • void TM1640_Bit3(uint8_t En)
    •   TM1640_Start();
    •   TM1640_Stop();
    •   Delay(10);
    •   TM1640_Start();
    •   TM1640_Write_Byte(0xCC);
    •   if(En)
    •     TM1640_Write_Byte(NUM[10][2]);
    •   else
    •   TM1640_Stop();
    • void TM1640_2_Bit4(uint8_t *Dat)
    •   uint8_t i;
    •   TM1640_Start();
    •   TM1640_Stop();
    •   Delay(10);
    •   TM1640_Start();
    •   TM1640_Write_Byte(0xCE);
    •   TM1640_Stop();
    •   TM1640_2_Start();
    •   TM1640_2_Write_Byte(0x44);
    •   TM1640_2_Stop();
    •   Delay(10);
    •   TM1640_2_Start();
    •   TM1640_2_Write_Byte(0xC0);
    •   for(i = 1; i < 5; i++)
    •     TM1640_2_Write_Byte(*(Dat++));
    •   TM1640_2_Stop();
    • void TM1640_2_Bit5(uint8_t *Dat)
    •   uint8_t i;
    •   TM1640_2_Start();
    •   TM1640_2_Stop();
    •   Delay(10);
    •   TM1640_2_Start();
    •   TM1640_2_Write_Byte(0xC5);
    •   TM1640_2_Stop();
    [color=rgb(51, 102, 153) !important]复制代码
    调试器都忘记放啦,做了几十片,大家可以看一下
    GMT+8, 2024-11-26 02:54 , Processed in 0.114782 second(s), 15 queries , MemCache On.
