TA的每日心情 | 开心 2013-8-15 11:25 |
签到天数: 1 天 连续签到: 1 天 [LV.1]初来乍到
1、nokia5110显示器介绍
这款液晶显示屏是通过PCD8554驱动控制器来驱动的,主要的特征如下:
单芯片 LCD 控制/驱动
48 行,84 列输出
显示数据 RAM 48*84 位
芯片集成:
——LCD电压发生器(也可以使用外部电压供应)
——LCD偏置电压发生器
——振荡器不需要外接元件(也可以使用外部时钟)
外部 RES(复位)输入引脚
串行界面最高4.0Mbits/S
CMOS兼容输入
混合速率:48
逻辑电压范围VDD到 VSS:2.7V~3.3V
显示电压范围VLCD到 VSS:
——6.0~8.5V LCD内部电压发生器(充许电压发生器)
——6.0~9.0V LCD外部电压供应(电压发生器关闭)
低功耗,适用于电池供电系统
关于VLCD的温度补偿
使用温度范围:-25~70℃
PCD8544 是一块低功耗的CMOS LCD控制驱动器,设计为驱动48 行84 列的图形显示。所有必须的显示功能集成在一块芯片上,包括LCD 电压及偏置电压发生器,只须很少外部元件且功耗小。 PCD8544 与微控制器的接口使用串行总线。PCD8544 采用 CMOS工艺。
方框图:
引脚图:
2、STM32控制LCD_5110连接图
GPIOB5<======================>SCE
GPIOB6<======================>RES
GPIOB7<======================>DC
GPIOB8<======================>SDIN
GPIOB9<======================>SCLK
3、程序- //main.c
- /*芯片:STM32F407*/
- #include "stm32f4xx.h"
- #include "lcd5110.h"
- #include "delay.h"
- int main(void)
- GPIO_Configuration();
- LCD_init();
- LCD_clear();
- LCD_write_chinese(10,0,0);
- LCD_write_chinese(22,0,1);
- LCD_write_chinese(34,0,2);
- LCD_write_chinese(46,0,3);
- LCD_write_chinese(58,0,4);
- LCD_write_chinese(70,0,5);
- // LCD_write_Picture(tu);//display full screen picture.
- return 0;
复制代码- lcd5110.c
- file:lcd 5110 driver
- author:Allen
- 和大家分享,共同学习,一起进步。
- Share more,learn better.
- some code is referenced from network.
- unsigned char tu[]=
- 0x00,0x00,0x00,0x80,0x80,0xC0,0xC0,0x60,0x60,0x60,0x20,0x30,0x20,0x20,0x20,0x62,
- 0x62,0x72,0xCC,0xF7,0xF2,0x23,0x02,0xC4,0x78,0x0C,0xE6,0xF2,0xE3,0x02,0x02,0x02,
- 0x07,0x0C,0x3C,0xC2,0x02,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
- 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
- 0x00,0x00,0x00,0x00,0xF0,0xFC,0x0E,0x03,0x01,0x00,0x80,0x60,0x10,0x40,0x14,0x00,
- 0x00,0x00,0x00,0x00,0x20,0x38,0x18,0x58,0x19,0x59,0x23,0x03,0x07,0x0C,0x08,0x10,
- 0x30,0x30,0x30,0x90,0x38,0x5C,0x3F,0xF1,0xE0,0x80,0x00,0x00,0x00,0x00,0x00,0x00,
- 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x03,0x1F,0x3C,0x70,0xE0,0xC0,0xC2,0x8D,
- 0xA2,0x08,0x21,0x40,0x00,0x40,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
- 0x00,0x80,0x80,0xC0,0xE0,0x20,0x00,0x00,0x00,0x02,0x51,0x04,0xAB,0xFF,0xFE,0x00,
- 0x00,0x0A,0x3F,0xF3,0xD7,0xAF,0x5B,0x33,0xE3,0x42,0xDF,0xE6,0x86,0x82,0x82,0x82,
- 0xC3,0x7E,0x43,0x63,0x21,0x31,0x18,0x06,0x81,0x00,0x00,0xA0,0x80,0xC8,0xE1,0xF4,
- 0x7A,0x3F,0x0F,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
- 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x01,0x03,0x07,0x07,0x0E,0x0D,0x1C,0x1D,
- 0x3A,0x39,0xFA,0xF8,0x7A,0xB8,0x1A,0xB8,0x1C,0xAD,0x1C,0xBE,0x1E,0xBE,0x3F,0xF3,
- 0xE3,0xC1,0x81,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
- unsigned char tu1[]= {
- 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x3C,0xF8,0xF0,0xE0,0xC0,
- 0x80,0x80,0x80,0x80,0xC0,0xE0,0xFE,0xFF,0xFE,0xF0,0xC0,0x80,0x80,0x80,0x80,0xC0,
- 0xE0,0xF0,0xF8,0x7C,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
- 0x00,0x00,0x10,0x30,0x70,0xE0,0xE0,0xE0,0xE0,0xE0,0xE0,0xF0,0xFF,0x7F,0x3F,0x1F,
- 0x0F,0x07,0x07,0x07,0x03,0x03,0x03,0x03,0x03,0x03,0x03,0x03,0x07,0x07,0x07,0x0F,
- 0x1F,0x1F,0x7F,0xF8,0xF0,0xF0,0xF0,0xF0,0xF0,0xF0,0x78,0x38,0x18,0x08,0x00,0x00,
- 0x00,0x00,0x80,0x80,0xC0,0xC0,0xE3,0xFF,0xFF,0xFF,0x1F,0x03,0x00,0x00,0x00,0x00,
- 0x1E,0x3F,0x3F,0x3F,0x3F,0x1E,0x00,0x00,0x00,0x00,0x1E,0x3F,0x3F,0x3F,0x3F,0x1E,
- 0x00,0x00,0x00,0x00,0x03,0x0F,0xFF,0xFF,0xFF,0xF0,0xE0,0xE0,0xC0,0xC0,0xC0,0xC0,
- 0x03,0x03,0x03,0x03,0x07,0x07,0x0F,0xDF,0xFF,0xFF,0xF8,0xC0,0x00,0x00,0x00,0x1E,
- 0x7C,0xF0,0xE0,0xC0,0xC0,0x80,0x80,0x80,0x80,0x80,0x80,0x80,0xC0,0xE0,0xF0,0x7C,
- 0x3E,0x07,0x00,0x00,0x80,0xF0,0xFF,0xFF,0xFF,0x87,0x03,0x03,0x01,0x01,0x01,0x00,
- 0x00,0x00,0x00,0x38,0x18,0x1C,0x1F,0x0F,0x0F,0x0F,0x0F,0x0F,0x1F,0xFE,0xF8,0xF8,
- 0xF0,0xE0,0xE1,0xE1,0xC3,0xC7,0xC7,0xC7,0xC7,0xC7,0xC7,0xC3,0xC3,0xE1,0xE0,0xF0,
- 0xF8,0xF8,0xFC,0xFF,0x0F,0x07,0x07,0x07,0x07,0x07,0x0F,0x0E,0x0C,0x0C,0x00,0x00,
- 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x3C,0x1F,0x0F,0x07,
- 0x03,0x03,0x01,0x01,0x01,0x03,0x0F,0x7F,0xFF,0x7F,0x0F,0x03,0x01,0x01,0x01,0x01,
- 0x03,0x07,0x07,0x1F,0x3C,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
- unsigned char tu2[]={
- 0x00,0x00,0x80,0xC0,0xE0,0xF0,0x78,0xB8,0xBC,0xDC,0xDE,0xFF,0xEF,0xEF,0xEE,0xFE,
- 0xDE,0xDC,0xBC,0xB8,0x78,0xF0,0xE0,0xE0,0xE0,0xE0,0xF0,0x78,0xB8,0xBC,0xDC,0xDE,
- 0xEE,0xFF,0xEF,0xEF,0xFE,0xDE,0xDC,0xFC,0xB8,0x78,0xF0,0xE0,0xC0,0x80,0x00,0x00,
- 0xF0,0xFE,0xFF,0x0F,0xFB,0xFE,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,
- 0xFF,0xFF,0xFF,0xFF,0xFF,0xFE,0xFC,0xFB,0xFB,0xFD,0xFE,0xFF,0xFF,0xFF,0xFF,0xFF,
- 0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFE,0xFB,0x9F,0xFF,0xFE,0xF0,
- 0x1F,0xFF,0xFF,0xC5,0x3F,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,
- 0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,
- 0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0x3F,0xE2,0xFF,0xFF,0x1F,
- 0x00,0x00,0x07,0x0F,0x3F,0x7C,0xF3,0xEF,0xDF,0xBF,0x7F,0xFF,0xFF,0xFF,0xFF,0xFF,
- 0xFF,0xFF,0xFF,0xFF,0xFF,0x7F,0xBF,0xDF,0xEF,0xF3,0x7C,0x3F,0x0F,0x03,0x00,0x00,
- 0x00,0x00,0x00,0x00,0x00,0x00,0x01,0x03,0x07,0x0F,0x1F,0x3E,0x7D,0xFB,0xF7,0xEF,
- 0xDF,0xBF,0x7F,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0x7F,0xBF,0xDF,
- 0xEF,0xF7,0xFB,0x7D,0x3E,0x1F,0x0F,0x07,0x03,0x01,0x00,0x00,0x00,0x00,0x00,0x00,
- 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x01,0x01,
- 0x03,0x07,0x0F,0x0E,0x1D,0x3B,0x77,0xEF,0xEF,0x77,0x3B,0x1D,0x0E,0x0F,0x07,0x03,
- 0x03,0x01,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
- //中文字模
- const unsigned char chinese_character[][24]=
- //hua
- {0x88,0x84,0xBE,0x91,0x90,0xC8,0xBF,0xA8,0xA4,0xA2,0xB8,0x00,0x00,0x00,0x00,0x00,0x00,0x07,0x00,0x00,0x00,0x00,0x00,0x00},
- //dong
- {0x02,0x22,0x32,0xAA,0x26,0xFB,0x22,0x62,0xA2,0x22,0x02,0x00,0x02,0x02,0x01,0x00,0x04,0x07,0x00,0x00,0x00,0x01,0x02,0x00},
- //li
- {0x12,0x12,0xFE,0x12,0x3F,0xA5,0xA5,0xFF,0xA5,0xA5,0x3F,0x00,0x02,0x02,0x01,0x05,0x04,0x04,0x04,0x07,0x04,0x04,0x04,0x00},
- //gong
- {0x00,0x02,0x02,0x02,0x02,0xFE,0x02,0x02,0x03,0x02,0x00,0x00,0x04,0x04,0x04,0x04,0x04,0x07,0x04,0x04,0x04,0x04,0x04,0x00},
- //da
- {0x08,0x08,0x08,0x08,0xC8,0x3F,0xC8,0x08,0x08,0x0C,0x08,0x00,0x04,0x04,0x02,0x01,0x00,0x00,0x00,0x01,0x02,0x04,0x04,0x00},
- //xue
- {0x9C,0x84,0x95,0x96,0x95,0xD6,0xB4,0x94,0x87,0x94,0x8C,0x00,0x00,0x00,0x00,0x04,0x04,0x07,0x00,0x00,0x00,0x00,0x00,0x00},
- //long
- {0x04,0x04,0x04,0xC4,0x3F,0x04,0xFC,0x45,0x26,0x14,0x04,0x00,0x04,0x02,0x01,0x02,0x02,0x01,0x07,0x04,0x04,0x04,0x07,0x00},
- //fei
- {0x01,0x01,0x01,0x01,0x01,0x7F,0x90,0x18,0x24,0x42,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x01,0x02,0x04,0x04,0x07,0x00},
- //6X8字库
- unsigned char font6x8[][6] =
- { 0x00, 0x00, 0x00, 0x00, 0x00, 0x00 },// sp
- { 0x00, 0x00, 0x00, 0x2f, 0x00, 0x00 },// !
- { 0x00, 0x00, 0x07, 0x00, 0x07, 0x00 },// "
- { 0x00, 0x14, 0x7f, 0x14, 0x7f, 0x14 },// #
- { 0x00, 0x24, 0x2a, 0x7f, 0x2a, 0x12 },// $
- { 0x00, 0x62, 0x64, 0x08, 0x13, 0x23 },// %
- { 0x00, 0x36, 0x49, 0x55, 0x22, 0x50 },// &
- { 0x00, 0x00, 0x05, 0x03, 0x00, 0x00 },// '
- { 0x00, 0x00, 0x1c, 0x22, 0x41, 0x00 },// (
- { 0x00, 0x00, 0x41, 0x22, 0x1c, 0x00 },// )
- { 0x00, 0x14, 0x08, 0x3E, 0x08, 0x14 },// *
- { 0x00, 0x08, 0x08, 0x3E, 0x08, 0x08 },// +
- { 0x00, 0x00, 0x00, 0xA0, 0x60, 0x00 },// ,
- { 0x00, 0x08, 0x08, 0x08, 0x08, 0x08 },// -
- { 0x00, 0x00, 0x60, 0x60, 0x00, 0x00 },// .
- { 0x00, 0x20, 0x10, 0x08, 0x04, 0x02 },// /
- { 0x00, 0x3E, 0x51, 0x49, 0x45, 0x3E },// 0
- { 0x00, 0x00, 0x42, 0x7F, 0x40, 0x00 },// 1
- { 0x00, 0x42, 0x61, 0x51, 0x49, 0x46 },// 2
- { 0x00, 0x21, 0x41, 0x45, 0x4B, 0x31 },// 3
- { 0x00, 0x18, 0x14, 0x12, 0x7F, 0x10 },// 4
- { 0x00, 0x27, 0x45, 0x45, 0x45, 0x39 },// 5
- { 0x00, 0x3C, 0x4A, 0x49, 0x49, 0x30 },// 6
- { 0x00, 0x01, 0x71, 0x09, 0x05, 0x03 },// 7
- { 0x00, 0x36, 0x49, 0x49, 0x49, 0x36 },// 8
- { 0x00, 0x06, 0x49, 0x49, 0x29, 0x1E },// 9
- { 0x00, 0x00, 0x36, 0x36, 0x00, 0x00 },// :
- { 0x00, 0x00, 0x56, 0x36, 0x00, 0x00 },// ;
- { 0x00, 0x08, 0x14, 0x22, 0x41, 0x00 },// <
- { 0x00, 0x14, 0x14, 0x14, 0x14, 0x14 },// =
- { 0x00, 0x00, 0x41, 0x22, 0x14, 0x08 },// >
- { 0x00, 0x02, 0x01, 0x51, 0x09, 0x06 },// ?
- { 0x00, 0x32, 0x49, 0x59, 0x51, 0x3E },// @
- { 0x00, 0x7C, 0x12, 0x11, 0x12, 0x7C },// A
- { 0x00, 0x7F, 0x49, 0x49, 0x49, 0x36 },// B
- { 0x00, 0x3E, 0x41, 0x41, 0x41, 0x22 },// C
- { 0x00, 0x7F, 0x41, 0x41, 0x22, 0x1C },// D
- { 0x00, 0x7F, 0x49, 0x49, 0x49, 0x41 },// E
- { 0x00, 0x7F, 0x09, 0x09, 0x09, 0x01 },// F
- { 0x00, 0x3E, 0x41, 0x49, 0x49, 0x7A },// G
- { 0x00, 0x7F, 0x08, 0x08, 0x08, 0x7F },// H
- { 0x00, 0x00, 0x41, 0x7F, 0x41, 0x00 },// I
- { 0x00, 0x20, 0x40, 0x41, 0x3F, 0x01 },// J
- { 0x00, 0x7F, 0x08, 0x14, 0x22, 0x41 },// K
- { 0x00, 0x7F, 0x40, 0x40, 0x40, 0x40 },// L
- { 0x00, 0x7F, 0x02, 0x0C, 0x02, 0x7F },// M
- { 0x00, 0x7F, 0x04, 0x08, 0x10, 0x7F },// N
- { 0x00, 0x3E, 0x41, 0x41, 0x41, 0x3E },// O
- { 0x00, 0x7F, 0x09, 0x09, 0x09, 0x06 },// P
- { 0x00, 0x3E, 0x41, 0x51, 0x21, 0x5E },// Q
- { 0x00, 0x7F, 0x09, 0x19, 0x29, 0x46 },// R
- { 0x00, 0x46, 0x49, 0x49, 0x49, 0x31 },// S
- { 0x00, 0x01, 0x01, 0x7F, 0x01, 0x01 },// T
- { 0x00, 0x3F, 0x40, 0x40, 0x40, 0x3F },// U
- { 0x00, 0x1F, 0x20, 0x40, 0x20, 0x1F },// V
- { 0x00, 0x3F, 0x40, 0x38, 0x40, 0x3F },// W
- { 0x00, 0x63, 0x14, 0x08, 0x14, 0x63 },// X
- { 0x00, 0x07, 0x08, 0x70, 0x08, 0x07 },// Y
- { 0x00, 0x61, 0x51, 0x49, 0x45, 0x43 },// Z
- { 0x00, 0x00, 0x7F, 0x41, 0x41, 0x00 },// [
- { 0x00, 0x55, 0x2A, 0x55, 0x2A, 0x55 },// 55
- { 0x00, 0x00, 0x41, 0x41, 0x7F, 0x00 },// ]
- { 0x00, 0x04, 0x02, 0x01, 0x02, 0x04 },// ^
- { 0x00, 0x40, 0x40, 0x40, 0x40, 0x40 },// _
- { 0x00, 0x00, 0x01, 0x02, 0x04, 0x00 },// '
- { 0x00, 0x20, 0x54, 0x54, 0x54, 0x78 },// a
- { 0x00, 0x7F, 0x48, 0x44, 0x44, 0x38 },// b
- { 0x00, 0x38, 0x44, 0x44, 0x44, 0x20 },// c
- { 0x00, 0x38, 0x44, 0x44, 0x48, 0x7F },// d
- { 0x00, 0x38, 0x54, 0x54, 0x54, 0x18 },// e
- { 0x00, 0x08, 0x7E, 0x09, 0x01, 0x02 },// f
- { 0x00, 0x18, 0xA4, 0xA4, 0xA4, 0x7C },// g
- { 0x00, 0x7F, 0x08, 0x04, 0x04, 0x78 },// h
- { 0x00, 0x00, 0x44, 0x7D, 0x40, 0x00 },// i
- { 0x00, 0x40, 0x80, 0x84, 0x7D, 0x00 },// j
- { 0x00, 0x7F, 0x10, 0x28, 0x44, 0x00 },// k
- { 0x00, 0x00, 0x41, 0x7F, 0x40, 0x00 },// l
- { 0x00, 0x7C, 0x04, 0x18, 0x04, 0x78 },// m
- { 0x00, 0x7C, 0x08, 0x04, 0x04, 0x78 },// n
- { 0x00, 0x38, 0x44, 0x44, 0x44, 0x38 },// o
- { 0x00, 0xFC, 0x24, 0x24, 0x24, 0x18 },// p
- { 0x00, 0x18, 0x24, 0x24, 0x18, 0xFC },// q
- { 0x00, 0x7C, 0x08, 0x04, 0x04, 0x08 },// r
- { 0x00, 0x48, 0x54, 0x54, 0x54, 0x20 },// s
- { 0x00, 0x04, 0x3F, 0x44, 0x40, 0x20 },// t
- { 0x00, 0x3C, 0x40, 0x40, 0x20, 0x7C },// u
- { 0x00, 0x1C, 0x20, 0x40, 0x20, 0x1C },// v
- { 0x00, 0x3C, 0x40, 0x30, 0x40, 0x3C },// w
- { 0x00, 0x44, 0x28, 0x10, 0x28, 0x44 },// x
- { 0x00, 0x1C, 0xA0, 0xA0, 0xA0, 0x7C },// y
- { 0x00, 0x44, 0x64, 0x54, 0x4C, 0x44 },// z
- { 0x14, 0x14, 0x14, 0x14, 0x14, 0x14 }// horiz lines
- @brief:set and clear the control bits of 5110 lcd.
- @usage:you can use funtion set_XXX() to set a bit and use funtion clear_XXX() to clear a bit.
- void set_SCE(void)
- GPIO_WriteBit(GPIOB, GPIO_Pin_5, Bit_SET);
- void clear_SCE(void)
- GPIO_WriteBit(GPIOB, GPIO_Pin_5, Bit_RESET);
- void set_RES(void)
- GPIO_WriteBit(GPIOB, GPIO_Pin_6, Bit_SET);
- void clear_RES(void)
- GPIO_WriteBit(GPIOB, GPIO_Pin_6, Bit_RESET);
- void set_DC(void)
- GPIO_WriteBit(GPIOB, GPIO_Pin_7, Bit_SET);
- void clear_DC(void)
- GPIO_WriteBit(GPIOB, GPIO_Pin_7, Bit_RESET);
- void set_SDIN(void)
- GPIO_WriteBit(GPIOB, GPIO_Pin_8, Bit_SET);
- void clear_SDIN(void)
- GPIO_WriteBit(GPIOB, GPIO_Pin_8, Bit_RESET);
- void set_SCLK(void)
- GPIO_WriteBit(GPIOB, GPIO_Pin_9, Bit_SET);
- void clear_SCLK(void)
- GPIO_WriteBit(GPIOB, GPIO_Pin_9, Bit_RESET);
- *函数名: GPIO_Configuration
- *参 数:无
- *功 能: 配置GPIO
- *返回值:无
- *备 注:无
- *日 期:2013/07/23
- GPIO_InitTypeDef GPIO_InitStructure;
- void GPIO_Configuration(void)
- RCC_AHB1PeriphClockCmd(RCC_AHB1Periph_GPIOB, ENABLE);
- GPIO_InitStructure.GPIO_Pin=GPIO_Pin_5|GPIO_Pin_6|GPIO_Pin_7|GPIO_Pin_8|GPIO_Pin_9;
- GPIO_InitStructure.GPIO_Speed = GPIO_Speed_2MHz;
- GPIO_InitStructure.GPIO_Mode = GPIO_Mode_OUT;
- GPIO_InitStructure.GPIO_OType = GPIO_OType_PP;
- GPIO_Init(GPIOB, &GPIO_InitStructure);
- *函数名: LCD_write_byte *
- *参 数:data:写入的数据 *
- * cmd: 1-数据/0-命令 *
- *功 能: 向5110LCD写入数据 *
- *返回值:无 *
- *日 期:2013/07/23 *
- void LCD_write_byte(unsigned char data,unsigned char cmd)
- unsigned char i;
- clear_SCE();
- if(cmd)
- set_DC();
- else
- clear_DC();
- for(i=0;i<8;i++)
- if(data&0x80) //如果一个字节的最高位是1
- set_SDIN(); //则设置SDIN=1
- else
- clear_SDIN();//否则设置SDIN=0;SDIN是即将写入数据DDRAM的值
- data = data<<1; //将传送的一个字节数据的每一位进行左移一位,等待下一次传输
- clear_SCLK(); //SDIN在SCLK的上升沿写入DDRAM
- set_SCLK(); //
- clear_SCLK(); //
- *函数名: LCD_init *
- *参 数:无 *
- *功 能: 初始化LCD *
- *返回值:无 * *
- *日 期:2013/07/23 *
- void LCD_init(void)
- set_SCE();
- set_RES();
- delay_us(200);
- clear_RES();
- delay_ms(20);
- set_RES();
- delay_us(200);
- LCD_write_byte(0x21,0);//LCD功能设置:芯片活动,水平寻址,使用扩展指令
- LCD_write_byte(0xd0,0);//设置VOP值,室温下的编程范围为3.00-10.68
- //Vlcd=3.06+(VOP)*0.06,本例VOP为0B01010000为十进制的80,Vlcd=7.86V
- LCD_write_byte(0x20,0);//LCD功能设置:芯片活动,水平寻址,使用基本指令
- LCD_write_byte(0x0c,0);//设定显示配置:普通模式
- set_SCE();//SCE为高电平时串行口被初始化,SCLK时钟不起作用,串行接口不消耗电力,所以最后都将SCE置高电平
- *函数名: LCD_set_XY *
- *参 数:X:列 *
- * Y:行 *
- *功 能: 选择写入液晶位置 *
- *返回值:无 *
- *日 期:2013/07/23 *
- void LCD_set_XY(unsigned char X, unsigned char Y)
- LCD_write_byte(0x40 | Y, 0);// 行
- LCD_write_byte(0x80 | X, 0);// 列
- set_SCE();
- *函数名: LCD_clear *
- *参 数:无 *
- *功 能: 清屏 *
- *返回值:无 *
- *备 注:无 *
- *日 期:2013/07/23 *
- void LCD_clear(void)
- unsigned char t;
- unsigned char k;
- LCD_set_XY(0,0);
- for(t=0;t<6;t++)
- for(k=0;k<84;k++)
- LCD_write_byte(0x00,1);
- set_SCE();
- *函数名: LCD_write_char *
- *参 数:c:需写入的字符 *
- *功 能: 写入字符命令 *
- *返回值:无 *
- *日 期:2013/07/23 *
- void LCD_write_char(unsigned char c)
- unsigned char c_line;
- c-=32;
- for (c_line=0; c_line<6; c_line++)
- LCD_write_byte(font6x8[c][c_line], 1);
- *函数名: LCD_write_String *
- *参 数:X:设置写入字符串列位置 *
- * Y:设置写入字符串行位置 *
- * *s:写入字符串首地址 *
- *功 能: LCD显示字符串 *
- *返回值:无 *
- *日 期:2013/07/23 *
- void LCD_write_String(unsigned char X,unsigned char Y,char *s)
- LCD_set_XY(X,Y);
- while (*s)
- LCD_write_char(*s);
- s++;
- *函数名: LCD_write_chinese *
- *参 数:X:设置写入汉字列位置 *
- * Y:设置写入汉字行位置 *
- *功 能: LCD显示汉字 *
- *返回值:无 *
- *日 期:2013/07/23 *
- void LCD_write_chinese(unsigned char X, unsigned char Y,char n)
- int i;
- LCD_set_XY(X,Y);
- for(i = 0;i < 12; i++)
- LCD_write_byte(chinese_character[n][i],1);
- LCD_set_XY(X,Y+1);
- for(i = 12; i < 24; i++)
- *函数名: LCD_write_Picture *
- *功 能: 写整屏的图片 *
- *返回值:无 *
- *日 期:2013/07/23 *
- void LCD_write_Picture(unsigned char *c)
- unsigned i,j;
- for(i=0;i<6;i++)
- LCD_set_XY(0,i);
- for(j=0;j<84;j++)
- LCD_write_byte(c[i*84+j],1);
复制代码- delay.c
- __IO u16 ntime;
- void delay_ms(u16 nms)
- ntime=nms;
- SysTick_Config(168000);//1ms产生一次中断
- while(ntime);
- SysTick->CTRL=0x00;
- void delay_us(u32 nus)
- ntime=nus;
- SysTick_Config(168);//1us产生一次中断
- while(ntime);
- void Delay(u32 count)
- while(count--);
复制代码- /**
- * @file LCD5110.h
- * @author Allen
- * @version V1.0.0
- * @date 22-July-2012,21:30 IN ECUST
- * @brief This file contains all the functions prototypes for the 5110 LCD driver
- @NOTE:
- *THIS FILE IS JUST FOR STUDY,CREATED BY LONGFEI WHICH HAS SOME REFERENCE FROM NETWORK
- /* Define to prevent recursive inclusion -------------------------------------*/
- #ifndef __LCD5110_H
- #define __LCD5110_H
- extern unsigned char tu[];
- extern unsigned char tu1[];
- extern unsigned char tu2[];
- /* Exported functions --------------------------------------------------------*/
- /* Funtion used to Configuration GPIO ----------------------------------------*/
- void GPIO_Configuration(void);
- /* Funtion used to SET SCE----------------------------------------------------*/
- void set_SCE(void);
- /* Funtion used to CLEAR SCE--------------------------------------------------*/
- void clear_SCE(void);
- /* Funtion used to SET RES----------------------------------------------------*/
- void set_RES(void);
- /* Funtion used toCLEAR SCE--------------------------------------------------*/
- void clear_RES(void);
- /* Funtion used toSET DC-----------------------------------------------------*/
- void set_DC(void);
- /* Funtion used toCLEAR DC---------------------------------------------------*/
- void clear_DC(void);
- /* LCD_write_byte funtion---------------------------------------------------*/
- void LCD_write_byte(unsigned char data,unsigned char cmd);
- /* LCD_Init function--------------------------------------------------------*/
- void LCD_init(void);
- /* LCD_set_XY---------------------------------------------------------------*/
- void LCD_set_XY(unsigned char X,unsigned char Y);
- /* LCD_clear function-------------------------------------------------------*/
- void LCD_clear(void);
- /* LCD_write_char function--------------------------------------------------*/
- void LCD_write_char(unsigned char c);
- /* LCD_write_string function-----------------------------------------------*/
- void LCD_write_String(unsigned char X,unsigned char Y,char *s);
- /* LCD_write_chinese function------------------------------------------ ---*/
- void LCD_write_chinese(unsigned char X,unsigned char Y,char n);
- /* LCD_write_Picture function------------------------------------------ ---*/
- void LCD_write_Picture(unsigned char *c);
- #endif
复制代码- <div class="blockcode"><blockquote>//delay.h
- #ifndef __DELAY_H
- #define __DELAY_H
- #include "stm32f4xx_conf.h"
- void delay_ms(u16 nms);
- void delay_us(u32 nus);
- void Delay(u32 count);
- #endif
