查看: 3179|回复: 3
[教程] 问一下msp430g2553的命名规则
  • 签到天数: 3 天
    发表于 2013-8-14 18:18:14 | 显示全部楼层 |阅读模式
    请问msp430g2553的g代表什么,2553又代表什么?
    慵懒
    2024-5-20 16:09
  • 签到天数: 665 天
    发表于 2013-8-14 22:03:40 | 显示全部楼层
    在TI官网有如下解释:
    再参照下列表格:
    Processor Family CC = Embedded RF Radio
    MSP = Mixed Signal Processor
    XMS = Experimental Silicon
    430 MCU Platform TI’s Low Power Microcontroller Platform
    Device Type
    Memory Type
    C = ROM
    F = FLASH
    FR = FRAM
    G = FLASH (Value Line)
    L = No Nonvolatile Memory
    Specialized Application
    AFE = Analog Front End
    BT = Pre-programmed with Bluetooth
    BQ = Contactless Power
    CG = ROM Medical
    FE = Flash Energy Meter
    FG = Flash Medical
    FW = Flash Electronic Flow Meter
    Series
    1 Series = Up to 8 MHz
    2 Series = Up to 16 MHz
    3 Series = Legacy OTP
    4 Series = Up to 16 MHz w/ LCD
    5 Series = Up to 25 MHz
    6 Series = Up to 25 MHz w/ LCD
    0 = Low Voltage Series
    Feature Set
    Various Levels of Integration within a Series
    A = Revision optional
    N/A
    Temperature Range optional
    S = 0°C to 50°C
    C = 0°C to 70°C
    I = -40°C to 85°C
    T = -40°C to 105°C
    Packagingwww.ti.com/packaging
    Tape and Reel optional
    T = Small Reel (7-in)
    R = Large Reel (11-in)
    No Markings = Tube or Tray
    Additional Featuresoptional
    *-EP = Enhanced Product (-40°C to 105°C)
    *-HT = Extreme Temperature Parts (-55°C to 150°C)
    MSP430G2553,可以分拆为
    Processor Family(MSP),
    430MCU Platform(430),
    Device Type(G),
    Series(2),
    Feture Set(553)。这样对照上表就一目了然了。
  • 签到天数: 648 天
    连续签到: 2 天
    发表于 2013-8-14 22:35:55 | 显示全部楼层
    G代表value line,2代表2系列,同一系列具有相同的结构,在后面就是具体的型号了,型号不同资源不同。
  • 签到天数: 3 天
    发表于 2014-7-24 15:10:52 | 显示全部楼层
    很好看   很实用  看看
    GMT+8, 2024-12-22 15:13 , Processed in 0.134361 second(s), 22 queries , MemCache On.
