l PB3(CLK),PB4(MOSI),PB5(MISO)初始化为复用功能(可以使用复用SPI接口或者SPI3接口,因为SPI1和SPI3控制器的相关引脚都在这三个IO上,见GPIO接口图)
2 初始化程序分析(1) 代码展示
void SPI1_Init(void)
GPIO_InitTypeDef GPIO_InitStructure;
SPI_InitTypeDef SPI_InitStructure;
RCC_AHB1PeriphClockCmd(RCC_AHB1Periph_GPIOB,ENABLE);//使能GPIOB时钟
RCC_APB2PeriphClockCmd(RCC_APB2Periph_SPI1,ENABLE);//使能SPI1时钟
//GPIOFB3,4,5初始化设置
GPIO_InitStructure.GPIO_Pin= GPIO_Pin_3|GPIO_Pin_4|GPIO_Pin_5;
GPIO_InitStructure.GPIO_Mode= GPIO_Mode_AF;//复用功能
GPIO_InitStructure.GPIO_OType= GPIO_OType_PP;//推挽输出
GPIO_InitStructure.GPIO_Speed= GPIO_Speed_100MHz;//100MHz
GPIO_InitStructure.GPIO_PuPd= GPIO_PuPd_UP;//上拉
GPIO_Init(GPIOB,&GPIO_InitStructure);//初始化
GPIO_PinAFConfig(GPIOB,GPIO_PinSource3,GPIO_AF_SPI1);//PB3复用为 SPI1
GPIO_PinAFConfig(GPIOB,GPIO_PinSource4,GPIO_AF_SPI1);//PB4复用为 SPI1
GPIO_PinAFConfig(GPIOB,GPIO_PinSource5,GPIO_AF_SPI1);//PB5复用为 SPI1
RCC_APB2PeriphResetCmd(RCC_APB2Periph_SPI1,ENABLE);//复位SPI1
RCC_APB2PeriphResetCmd(RCC_APB2Periph_SPI1,DISABLE);//停止复位SPI1
SPI_InitStructure.SPI_Direction= SPI_Direction_2Lines_FullDuplex;
SPI_InitStructure.SPI_Mode= SPI_Mode_Master; //设置SPI工作模式:设置为主SPI
SPI_InitStructure.SPI_DataSize= SPI_DataSize_8b;
SPI_InitStructure.SPI_CPOL= SPI_CPOL_High;
SPI_InitStructure.SPI_CPHA= SPI_CPHA_2Edge; //串行同步时钟的第二个跳变沿(上升或下降)数据被采样
SPI_InitStructure.SPI_NSS= SPI_NSS_Soft; //NSS信号由硬件(NSS管脚)还是软件(使用SSI位)管理:内部NSS信号有SSI位控制 SPI_InitStructure.SPI_BaudRatePrescaler= SPI_BaudRatePrescaler_256; //定义波特率预分频的值:波特率预分频值为256 SPI_InitStructure.SPI_FirstBit= SPI_FirstBit_MSB; //指定数据传输从MSB位还是LSB位开始:数据传输从MSB位开始 SPI_InitStructure.SPI_CRCPolynomial= 7; //CRC值计算的多项式
SPI_Init(SPI1,&SPI_InitStructure);
SPI_Cmd(SPI1, ENABLE); //使能SPI外设
SPI1_ReadWriteByte(0xff);//启动传输
void W25QXX_Init(void){
//GPIOB0 GPIO_InitStructure.GPIO_Pin =GPIO_Pin_0;//PB0
GPIO_InitStructure.GPIO_Mode =GPIO_Mode_OUT;//输出
GPIO_InitStructure.GPIO_OType =GPIO_OType_PP;//推挽输出
GPIO_InitStructure.GPIO_Speed =GPIO_Speed_100MHz;//100MHz
GPIO_InitStructure.GPIO_PuPd =GPIO_PuPd_UP;//上拉
GPIO_Init(GPIOB, &GPIO_InitStructure);//初始化
W25QXX_CS=1; //SPI FLASH不选中
SPI1_Init(); //初始化SPI
SPI1_SetSpeed(SPI_BaudRatePrescaler_2); //设置为42M时钟,高速模式
W25QXX_TYPE=W25QXX_ReadID(); //读取FLASH ID.
(2) 代码分析1. 初始化代码总体分析由展示的代码,我们可以看出,对W25Q16的初始化主要使用了两个函数,主要调用函数void W25QXX_Init(void)对W25Q16进行初始化,而该函数又调用了SPI1_Init()函数对SPI1接口进行初始化。代码主要流程图如下:
通过以上流程图,我们可以看出对W25Q16的初始化,主要是初始化SPI接口。下面对代码具体说明。
2. 代码详细分析(我们主要分析SPI1接口的初始化函数)我们先分析函数voidSPI1_Init(void),对该函数里面的没一行代码进行详细说明l GPIO_InitTypeDef GPIO_InitStructure;
代码分析:首先定义了两个结构体变量,这两个结构体的类型定义在GPIO和SPI的库函数中,主要作为GPIO和SPI初始化调用的参数,我们一会详细分析。
l RCC_AHB1PeriphClockCmd(RCC_AHB1Periph_GPIOB, ENABLE);//使能GPIOB时钟
代码分析:STM32有着强大且细分的时钟系统,我们可以单独的对每一个控制器的时钟进行使能,这样可以更好的降低功耗。因此,这两句分别使能GPIOB和SPI1的时钟。关于时钟库函数的说明,请看我的《STM32库函数说明及示例-RCC篇》
l GPIO_InitStructure.GPIO_Pin = GPIO_Pin_3|GPIO_Pin_4|GPIO_Pin_5;
GPIO_InitStructure.GPIO_PuPd= GPIO_PuPd_UP;//上拉GPIO_Init(GPIOB,&GPIO_InitStructure);
