查看: 1076|回复: 3
[经验] 高电流应用电池测试仪参考设计包括BOM及层图
  • 签到天数: 14 天
    发表于 2020-4-2 10:12:31 | 显示全部楼层 |阅读模式
    描述
                Li-Ion battery formation and electrical testing require accurate voltage and current control, usually to better than ±0.05% over the specIFied temperature range.  This reference design proposes a solution for high-current (up to 50 A) battery tester applications supporting input (bus  (...)
    主要特色
    • Battery test subsystem with calibration control achieving 0.01% full scale current control accuracy
    • Supports up to 50-A applications with an input voltage (bus) from 8 V–16 V and output load (battery) from 0 V–4.5 V (5 V max)
    • LM5170 bidirectional buck, boost controller
    • Programmable high-precision  (...)
    游客,如果您要查看本帖隐藏内容请回复
    GMT+8, 2025-1-20 16:24 , Processed in 0.134961 second(s), 23 queries , MemCache On.
