楼主: mmuuss586
[原创] 游名:Stm32F3+CA-IS3050 隔离CAN设计参考原理图/PCB图/教程/源...
  • 签到天数: 141 天
    [LV.7]常住居民III
     楼主| 发表于 2020-3-12 16:45:32 | 显示全部楼层
    按照公式计算,我们用的是1Mbps的波特率在通信,hcan.Init.Mode用来设置单片机工作模式(普通模式(CAN_MODE_NORMAL)和回环模式(CAN_MODE_LOOPBACK)等)。我们这里设置普通模式
    然后添加如下几个功能函数:
    void CAN_Filter_Init(CAN_FilterTypeDef * pFilter,
        uint32_t IdHigh,
        uint32_t IdLow,
        uint32_t MaskIdHigh,
        uint32_t MaskIdLow,
        uint32_t FIFOAssignment,
        uint32_t Bank,
        uint32_t Mode,
        uint32_t Scale,
        uint32_t Activation,
        uint32_t SlaveStartFilterBank)
        pFilter->FilterIdHigh         = 0;           //32 位 ID
        pFilter->FilterIdLow          = 0;
        pFilter->FilterMaskIdHigh     = 0;             //32 位 MASK
        pFilter->FilterMaskIdLow      = 0;
        pFilter->FilterFIFOAssignment = CAN_FILTER_FIFO0;   // FIFO0
        pFilter->FilterBank           = 0;
        pFilter->FilterMode           = CAN_FILTERMODE_IDMASK;
        pFilter->FilterScale          = CAN_FILTERSCALE_32BIT;  //32 位
        pFilter->FilterActivation     = ENABLE;          // //激活过滤器 0
        pFilter->SlaveStartFilterBank = 0;
  • 签到天数: 141 天
    [LV.7]常住居民III
     楼主| 发表于 2020-3-12 16:45:58 | 显示全部楼层
    首先是CAN过滤器的配置函数,
    /***********************CAN通信发送函数***************************/
    void CAN_TxMessage(CAN_HandleTypeDef *hcan, CAN_TxHeaderTypeDef * pTxHeader, uint8_t aData[], uint8_t DLC)
        uint32_t Tx_MailBox;
        pTxHeader->DLC    =    DLC;
        while(HAL_CAN_AddTxMessage(hcan, pTxHeader, aData, &Tx_MailBox) != HAL_OK)
            printf("TxMsg Failed!!");
                                    HAL_Delay(100);
        printf("\nSend Tx Message Success!!Tx_Mail:%d", Tx_MailBox);
    void User_CAN1_TxMessage(uint8_t aTxData[], uint8_t DLC)
            CAN_TxMessage(&hcan, &hCAN1_TxHeader, aTxData, DLC);
    /*********************** CAN启动测试函数****************************/
    void CAN_Configuration(CAN_TxHeaderTypeDef    * pTxHeader,
        uint32_t                StdId,
        uint32_t                ExtId,
        uint32_t                IDE,
        uint32_t                RTR,
        uint32_t                DLC,
        uint32_t                IdHigh,
        uint32_t                IdLow,
        uint32_t                MaskIdLow,
        uint32_t                Bank,
        uint32_t                Mode,
        uint32_t                Scale,
        CAN_TxHeader_Init(pTxHeader, StdId, ExtId, IDE, RTR, DLC);
        CAN_Filter_Init(pFilter, IdHigh, IdLow, MaskIdHigh, MaskIdLow, FIFOAssignment, Bank, Mode, Scale, Activation, SlaveStartFilterBank);
        HAL_CAN_ConfigFilter(&hcan, pFilter);
        while(HAL_CAN_Start(&hcan) != HAL_OK )
            printf("\nCAN_Start Failed!!");
                                    HAL_Delay(100);
        printf("\nCAN_Start Success!!");
        HAL_CAN_ActivateNotification(&hcan, CAN_IT_RX_FIFO0_MSG_PENDING);
  • 签到天数: 141 天
    [LV.7]常住居民III
     楼主| 发表于 2020-3-12 16:46:23 | 显示全部楼层
    //启动测试函数主要为测试单片机CAN功能是否能正常启动,启动成功与否通过串口发送出来,方便我们观测,所以需要包含usart.h文件;
    配置完成后,在stm32f3xx_it.c文件中添加CAN接收中断函数,
    void CAN_RX1_IRQHandler()
            HAL_CAN_RxFifo0MsgPendingCallback(&hcan);
    void HAL_CAN_RxFifo0MsgPendingCallback(CAN_HandleTypeDef *hcan)
        uint8_t aRxData[8], i;
        if(HAL_CAN_GetRxMessage(hcan, CAN_RX_FIFO0, &hCAN1_RxHeader, aRxData) == HAL_OK)
            printf("\nGet Rx Message Success!!\nData:");
            for(i=0; i<8; i++)
                printf("%x ", aRxData[i]);
  • 签到天数: 141 天
    [LV.7]常住居民III
     楼主| 发表于 2020-3-12 16:46:50 | 显示全部楼层
    中断服务函数中首先用if确定是否接收到数据,若没有接收到数据直接退出,接收到则使用串口将对应数据打印;由于我们在main函数中的发送数据为16进制数据,打印也用16进制数据打印,更便于观察;
    最后为main.c文件内容
    int main(void)
    uint8_t TxData[8] = {0x12, 0x23, 0x34, 0x45, 0x56, 0x67, 0x78, 0x89};
      HAL_Init();
      SystemClock_Config();
      MX_GPIO_Init();
      MX_CAN_Init();
      MX_USART1_UART_Init();
    __HAL_CAN_ENABLE_IT(&hcan,CAN_IT_RX_FIFO0_MSG_PENDING); //CAN中断使能函数
      User_CAN_Configuration();
      while (1)
            User_CAN1_TxMessage(TxData, 8);
            HAL_Delay(1000);
  • 签到天数: 141 天
    [LV.7]常住居民III
     楼主| 发表于 2020-3-12 16:47:09 | 显示全部楼层
    在main函数中,只要是对CAN通信的中断使能,只能之后前面写的中断服务函数才能正常起作用
    实验结果:
    程序编译成功后,下载到板卡,两块板卡其中一块可以将main.c的while中的User_CAN1_TxMessage(TxData, 8);函数屏蔽掉,专门用来接收数据,另一个则每隔1秒发送一次数据,打开两个串口通信助手,就可以看到如下信息;
  • 签到天数: 141 天
    [LV.7]常住居民III
     楼主| 发表于 2020-3-12 16:48:24 | 显示全部楼层
    GMT+8, 2025-1-13 13:51 , Processed in 0.229750 second(s), 33 queries , MemCache On.
