查看: 1312|回复: 0
基于STHV748S高电压脉冲评估板
发表于 2018-2-28 11:23:00 | 显示全部楼层 |阅读模式
STEVAL-IME011V2评估板基于STHV748S 4通道5电平高电压脉冲发生器而设计,这是一款专为超声成像应用设计的最先进的设备。这块电路板中新的图形用户界更便于评估超声波脉冲发生器IC,一旦配置了输出波形,可以通过将示波器探头连接到相应的BNC将其直接显示在示波器上。Key Features
  • 4-channel outputs: high voltage and low voltage BNC connectors
  • Up to 4 memory locations to store own designed waveforms
  • USB connector to download on the board own waveforms
  • Dedicated connectors to supply high voltage and low voltage to the STHV748 output stage
  • 4 key button to select quickly the preferred program
  • RoHS compliant
Evaluation board based on the STHV748S high voltage pulser.pdf
263.64 KB, 下载次数: 3
Getting started with the STEVAL-IME011V2 evaluation board based on the STHV748S ultrasound pulser.pdf
4.41 MB, 下载次数: 3
GMT+8, 2025-1-12 12:30 , Processed in 0.123985 second(s), 16 queries , MemCache On.
