查看: 671|回复: 0
MiCS5524气体传感器开发板
发表于 2018-1-16 11:04:39 | 显示全部楼层 |阅读模式
MiCS-5524是一个强大的MEMS传感器,用于室内一氧化碳和天然气泄漏检测,也适用于室内空气质量监测; 呼吸检查和早期火灾检测。Give your next sensor project a nose for gasses with the Adafruit MiCS-5524 Gas Sensor Breakout. This breakout makes it easy to use this nice sensor from SGX Sensortech. The MiCS-5524 is a robust MEMS sensor for indoor carbon monoxide and natural gas leakage detection, it's suitable also for indoor air quality monitoring; breath checker and early fire detection.Please note: This sensor is sensitive to CO ( ~ 1 to 1000 ppm), Ammonia (~ 1 to 500 ppm), Ethanol (~ 10 to 500 ppm), H2 (~ 1 - 1000 ppm), and Methane / Propane / Iso-Butane (~ 1,000++ ppm). However, it can't tell you which gas it has detected.This breakout board is not for any safety, medical or finished product usage. We're selling it for hobby education & experimentation and don't guarantee it for any other purpose! All gas sensors require calibration for precision output.Using it is easy: Power it with 5 VDC and read the analog voltage off of the output pin. When gasses are detected, the analog voltage will increase in proportion of detected gas. When powered, the heater draws about 25-35mA. You can use the EN pin to power it off (pull it high to 5V to turn off) to conserve energy. Just make sure to wait a second after turning the heater on to make sure its all heated before taking readings.Each order comes with one assembled and tested MiCS-5524 breakout and a bit of header. You'll need to do some light soldering to attach the header on - or you can use just plain wires.TECHNICAL DETAILS
  • App Note on Alcohol detection
  • MiCS5524 Datasheet
  • EagleCAD and Fritzing files available in tutorial
Adafruit-Mics5524-gas-Sensor-Breakout Manual.pdf
949.27 KB, 下载次数: 0
GMT+8, 2025-1-12 17:30 , Processed in 0.109442 second(s), 16 queries , MemCache On.
