96Boards传感器夹层适配器兼容传感器和设备连接到任何96Boards底板并且简单方便。 它可以使Grove模块和Arduino兼容的shields板和接口连接到96Boards基板上运行的软件。它可以在96Boards平台上进行一切的开始试验和原型设计。On the board you will find sockets for 18 Grove modules, an Arduino-compatible shield socket, and two SPI headers. It also includes an ATMega328 microcontroller which can be programmed from the Arduino IDE and will run most Arduino UNO sketches unchanged. The shield connector and 10 of the Grove sockets are controlled by the microcontroller, while the remaining 8 Grove sockets are controlled directly by the baseboard. This makes it a flexible prototyping platform which supports both direct control of devices from application software, and offload to a microcontroller. It also provides a USB-UART interface to access the baseboard’s serial console.The Sensors board attached on top of a 96Boards CE or EE edition board using the 40pin low-speed expansion connector.Please note: A 96Boards baseboard is not included.This board has been tested and works with the Qualcomm Dragonboard 410c and the LeMaker HiKey boards.Features
- Integrated ATMEGA328p microcontroller (Arduino compatible)
- 18 Grove connectors
- http://www.seeedstudio.com/wiki/Grove_System
- 5x baseboard GPIO ports
- 5x I2C ports (1 for baseboard, 2 for microcontroller)
- 5 digital ports (for microcontroller)
- 3x analog ports (for microcontroller)
- 2x SPI connectors (1 to baseboard, 1 to microcontroller)
- Arduino UNO compatible shield connectors
- LED: Power, Reset, 2x baseboard GPIO, 1x microcontroller IO
- UART interface between baseboard and microcontroller
- USB-UART connector for baseboard console and control
