查看: 789|回复: 0
MyoWare肌肉电传感器开发板
发表于 2017-9-29 09:49:39 | 显示全部楼层 |阅读模式
MyoWare措施肌肉活动性通过肌肉的电势,通常被称为肌电图(EMG)。当你的大脑告诉你的肌肉弹性,它将有一个电信号发送给你的肌肉,开始招募电动机单位(肌纤维产生在你的肌肉的力量包)。你越弯曲,更多的运动单位被雇来产生更大的肌肉力量。运动单位的数量更大,更多的肌肉电活动增加。MyoWare将分析这个电活动和输出的模拟信号代表了弯曲的肌肉是多么困难。特性
  • Single supply - MyoWare won't need +/- voltage power supplies! Unlike our previous sensor, it can now be plugged directly into 3.3V through 5V development boards.
  • Embedded Electrode Connector - Electrodes now snap directly to MyoWare, getting rid of those pesky cables and making the MyoWare wearable!
  • RAW EMG Output - A popular request from grad students, the MyoWare now has a secondary output of the RAW EMG waveform.
  • Polarity Protected Power Pins - Our #1 customer request was to add some protection so the sensor chips don't burn out when the power is accidentally connected backwards.
  • LED Indicators - We've added two on-board LEDs one to let you know when the MyoWare's power is on and the other will brighten when your muscle flexes.
GMT+8, 2025-1-12 16:18 , Processed in 0.116897 second(s), 15 queries , MemCache On.
