查看: 439|回复: 0
AS3420音频开发板
发表于 2017-3-6 10:31:55 | 显示全部楼层 |阅读模式
主动降噪芯片AS3420是一个全差分ANC扬声器驱动器芯片,为单声道蓝牙应用程序专门设计,可直接连接到共同的SoC。它也可以应用于其他类型的无线耳机。完全模拟实现降低环境背景噪声,并达到最低的功耗及最佳语音质量。AS3420蓝牙扬声器驱动芯片可用于前馈和反馈配置。由于集成了低噪声放大器,该设备可实现简单的低阶滤波器以及复杂的多阶滤波器的开发。此外,麦克风输入具有全差分低噪声放大器的功能,可达到128级的可调增益,OTP(一次性可编程)ROM可实现出厂增益设置。Features Microphone Input „
  • 128 gain steps @ 0.375dB and MUTE with AGC
  • „ Differential, low noise microphone amplifier „
  • Single ended or differential mode „
  • Improved supply for electret microphone „
  • MIC gain OTP programmable
High Efficiency Headphone Amplifier „
  • 2x34mW, 0.1% THD @ 16Ω, 1.5V supply, 100dB SNR „
  • Bridged mode for e.g. 300Ω loads „
  • Click and pop less start-up and mode switching
Line Input „
  • Volume control via serial interface or volume pin „
  • 64 steps @ 0.75dB and MUTE, pop-free gain setting „
  • Single ended stereo or mono differential mode
ANC processing „
  • Feed-forward cancellation „
  • Feed-back cancellation with filter loop transfer function definable via simple RC components „
  • Simple in production SW calibration „
  • 12-30dB noise reduction (headset dependent) „
  • 10-2000Hz wide frequency active noise attenuation (headset dependent)
Monitor Function „
  • For assisted hearing, i.e. to monitor announcements „
  • Fixed (OTP prog.) ambient sound amplification to compensate headphone passive attenuation „
  • Volume controlled ambient sound amplification mixed with fixed (OTP prog.) attenuation of LineIn
Incremental Functions „
  • ANC with or without music on the receiving path „
  • Improved dynamic range playback „
  • OTP ROM for automatic trimming during production (4 times programbable)
Performance Parameter „
  • 5/3.8mA @ 1.5V stereo/mono ANC; <1µA quiescent „
  • Extended PSRR for 217Hz
Interfaces „
  • 2-wire serial control mode & volume inputs „
  • Calibration via Line-In or 2-wire serial interface (patent pending) „
  • Single cell or fixed 1.0-1.8V supply with internal CP
Package „
  • AS3400, AS3410 QFN24 [4x4mm] 0.5mm pitch „
  • AS3430 QFN32 [5.x5mm] 0.5mm pitch
AS3420 Datasheet.pdf
1.28 MB, 下载次数: 0
GMT+8, 2025-1-12 18:59 , Processed in 0.126417 second(s), 17 queries , MemCache On.
